How to run gcode commands remotely on a Duet3 + RPi?
  • I have a Duet3 6HC board connected with a Raspberry Pi. It works, I can print files, view the web interface, etc. Is there a way I can programmatically (Python) run commands remotely on this setup? I have it set up where I can telnet into the RPi, but obviously entering gcode commands in the console doesn't work.
    I also have a Duet2 Wifi board where I can telnet into the board and just send commands to run them. I'm essentially looking for the same functionality on the Duet3 + SBC setup.
  • There is a phyton api if you search the forum
    and if you just want to run code from the console then on the pi do/opt/dsf/bin/CodeConsole (sudo if needed?)
  • Running sudo /opt/dsf/bin/CodeConsole from the console seems to work.
    Here's my code to log in using Python with the default user/pass. After this, sending commands works:
    tn = telnetlib.Telnet(printer_ip)
    print(tn.read_until(b"login: ").decode('utf=8', errors='ignore'))
    tn.write(b'pi\n')
    print(tn.read_until(b"Password: ").decode('utf=8', errors='ignore'))
    tn.write(b'raspberry\n')
    print(tn.read_until(b"$ ").decode('utf=8', errors='ignore'))
    tn.write(b'sudo /opt/dsf/bin/CodeConsole\n')
    print(tn.read_until(b"Connected!").decode('utf=8', errors='ignore'))
    tn.write(b'M114\n')
    sleep(1.0)
    print(tn.read_very_eager().decode('utf=8', errors='ignore'))
  • @TDK said in How to run gcode commands remotely on a Duet3 + RPi?:
    they've started moving away from running as root so wasn't sure if that applied to CodeConsole or not.
    you can also pipe commands for a one off echo M114 | sudo /opt/dsf/bin/CodeConsole
    (edit: you could also run the whole thing securely over ssh from another host as single command ssh pi@printer_ip "echo M114 | sudo /opt/dsf/bin/CodeConsole" (use with public key in authorized_keys (ssh-keygen and ssh-copy-id pi@printer_ip) and specify ssh -t or set up sudo on the remote host to not require password for the command in question))
