Failed to initialise WiFi module and SD card
  • Hi,
    I think my Duet2 Wifi SD card reader is dead. I was configuring
    it via the network interface while it suddenly disconnected. The
    blue led of the wifi module stopped and rebooting the SD card did
    not fixed it. Then I connected the board via USB (Vin
    disconnected) to replay the initialization process via the
    terminal. And the first error message that I get is
    "RepRapFirmware for Duet 2 WiFi/Ethernet Version 3.1.1 dated
    2020-05-19b2
    Cannot initialise SD card 0: Card is unusable"
    I nevertheless tried to start the WiFi again (M552 S0), but I get the
    message "Error: Failed to initialise WiFi module, code -2"
    So I tried to reload the wifi firmware and the firmware of the
    board but it never found the firmware on the SD card, while I can
    see it in the /sys folder when I connect the SD card directly to
    my computer. I erased the SD card and reinstalled fresh data on
    it, but no change occured, still the " Cannot initialise SD card
    0: Card is unusable" message. And I tried with another SD card,
    but no change. Another example : "Error: M21: Cannot initialise
    It seems that I am not the first one to experiment this issue
    (https://forum.duet3d.com/topic/2646/cannot-initialise-sd-card-0-card-is-unusable/4).
    Regarding the card itself, I simply connected it to my motors,
    endtops and heatbed + sensor to begin the firmware configuration.
    No manual movement of the printing head, no ESD or other bad
    treatment...
    Am I missing something out or is it a warranty relevant issue ? I bought my Duet2 WiFi last month and was configuring it. Never printed with it yet. But until the WiFi module disconnected and shut down, I had no issue to access it and configure it following the dozuki guide.
    Thanks ahead for any help 😰
  • If the duet can't access the SD card then you won't be able to flash the wifi firmware either.
    Do you get the same error if you run M552 S1 if you start the Duet with no SD card?
    Also please run M122 (with the SD card inserted at boot) and share the whole output.
  • Moderator
    When and where did you purchase the board?
    You can try these diagnostic steps:
    https://duet3d.dozuki.com/Wiki/SD_Card#Section_Troubleshooting_SD_Card_issues
    Can you post a photo of the SD card slot solder points? You can see an example of what I mean in that link above.
    From your description it does sound like a problem with the SD card slot since the card seems to be working in your PC, however, can you also try with a fresh SD card just to rule that out?
  • @bearer Hi, the M552 S1 command return the same issue :
    "WiFi module started Error: Failed to initialise WiFi module, code -2"
    And the M122 returns the following output :
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
    Board ID: 08DLM-996RU-N85S4-7J9FA-3SN6L-1V9RR
    Used output buffers: 1 of 24 (1 max)
    Static ram: 27980
    Dynamic ram: 92268 of which 20 recycled
    Exception stack ram used: 256
    Never used ram: 10548
    Tasks: NETWORK(ready,1884) HEAT(blocked,1476) MAIN(running,2712) IDLE(ready,80)
    Owned mutexes:
    Last reset 00:01:37 ago, cause: power up
    Last software reset at 2020-10-08 23:50, reason: User, spinning module GCodes, available RAM 9880 bytes (slot 0)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
    SError status: 0
    MCU temperature: min 51.9, current 67.8, max 67.9
    Supply voltage: min 0.7, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
    Driver 0: ok, SG min/max not available
    Driver 1: ok, SG min/max not available
    Driver 2: ok, SG min/max not available
    Driver 3: ok, SG min/max not available
    Driver 4: ok, SG min/max not available
    Cache data hit count 161777938
    Slowest loop: 0.15ms; fastest: 0.09ms
       **=== Storage ===
    Free file entries: 10
    SD card 0 detected, interface speed: 12.0MBytes/sec
    SD card longest read time 0.0ms, write time 0.0ms, max retries 0**
    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
    === MainDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
    === AuxDDARing ===
    Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is ready with "M122" in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    Daemon is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 0.14ms; fastest: 0.00ms
    HTTP sessions: 0 of 8
    - WiFi -
    Network state is disabled
    WiFi module is disabled
    Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
  • @Phaedrux Hi, I bought the card to E3D on August 25th (this year). There does not seems to be any issue with the solderings as you can see... But I have tried with two different SD cards which are working well on my PC so I do not see what it can be else.
  • @Phaedrux OK so according to your link, I have a 12MB/s speed so there might be an issue with my card. I will replay the command with my other SD card to compare. What I don't understand is the write time of zero. Do you have any idea of what it can mean ?
  • What I don't understand is that with the SD card unplugged, I get (with M122) this :
    SD card 0 not detected, interface speed: 12.0MBytes/sec
    And with the SD card plugged :
    So the Duet "feels" the SD card, but that's it. And the 12MBytes/sec value should reveal a SD card issue, but if it is the same with and without SD card mounted, what is the point ?? Nevertheless regarding the SD card, i tried to run a speed test on the SD card (M122 P104 S2) I get :
    Error: Failed to create folder 0:/gcodes in path 0:/gcodes/test.tst
    Error: M122: Failed to create file
    And a complete (again) SD card erase (complete, not fast erase) changed nothing. Could any Duet Team help me to confirm with E3D that it is a hardware issue (warranty relevant) ?
  • Moderator
    Please contact E3D and initiate a warranty claim. Include a link to this thread as authorization.
  • @Phaedrux OK thank you
