    Warning High Temperature reported by driver(s) 2
    • Sculpt Fabricator
      Sculpt Fabricator last edited by
      We keep getting a warning over and over
      But we are not showing any faults and temperatures are good
      Is driver(s) 2, heater 2? or is this not the driver 2 but 2 drivers? and if so is there way to find out which drivers and how to fix the warning?
      MCU is running at 36C
      Duet WiFi 1.02 or later + DueX5 Firmware Version: 2.05 (2019-12-13b1)
      Thank You
      • Veti
        Veti last edited by
        https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/4k56ZjaaAHrTJI6Z.huge
        drive 2 is the z stepper driver
        • Sculpt Fabricator
          Do you know at what temperature they will give the warning? and without a thermistor is this something the board is reading through the motor wires or is it the connection at the board that is getting hot?
          • Veti
            Veti last edited by
            the tmc driver has inbuild temperature sensing. i believe its around 100C
            basically if you can touch the chip and its to hot to touch, its a problem.
