    SOLVED Do Linear Rails Perform Well Under Cantilever Loads?
    409
    • Turbo
      Turbo last edited by
      So recently on my d-bot, I've ditched the v rollers on the z axis in favor of linear rails. Now my main concern is that linear rails arent designed for cantilever forces right? hence the name linear. Im wondering if it would be better in the long run to install 2 more rails on the front side, so that there are 4 rails instead of 2, eliminating the cantilever design in favor for a voron2 style system with rails on all 4 corners.
      1st image is just to show the printer itself, before linear rails
      Now its got rails, and this is how they're mounted. Any advice on a better design is welcome. I'm no expert
      Cant stop tuning wont stop tuning.
      Dbot, Custom i3, Voron 0&2
      JoergS5 1 Reply Last reply Reply Quote 0
      • JoergS5
        JoergS5 @Turbo last edited by
        @Turbo I expect that it is more important that the belt is placed nearer to the linear guide, because of the rule which is called 2:1 rule: https://www.machinedesign.com/mechanical-motion-systems/article/21836017/linear-bearings-understanding-the-21-ratio-and-how-to-overcome-the-stickslip-phenomenon
        Turbo 1 Reply Last reply Reply Quote 0
        • Turbo
          Turbo @JoergS5 last edited by
          @JoergS5 it is indeed following the 2:1 rule.
          • JoergS5
            JoergS5 @Turbo last edited by JoergS5
            @Turbo this is good.
            The weight of the print bed is caught by the belt instead of the linear guide, so I would expect you have no win installing 2 additional linear guides. To the contrary, the risk to get stuck is much higher with 4 instead of 2 guides if they are not exactly precise parallel (to few micrometers). You can check (and correct) whether the weight focus of the bed is at the belt position. This would lower the force on the linear guide, so the guide fulfils only the taks to guide in the Z direction.
            achrn 1 Reply Last reply Reply Quote 0
            • achrn
              achrn last edited by
              I don't think the 'linear' of linear rails is anything to do with load capacity, I think it relates to the fact that the rail permits linear movement.
              The rail manufacturer might (ought to, but getting good spec details is difficult on lots of stuff made in china) (though that might be getting it in english is difficult) specify the capacity.
              For an example of good detail, if it's genuine Hiwin: https://www.hiwin.com/pdf/linear_guideways.pdf
              Page 89 of the file has the popular MGN12 rails, and show your rated moment for that type loading - if it's MGN 12H (which I pick only because that's what is on my delta) you've got a rating of 36 Nm. (Assuming I've udnerstood your photos right - I think you're worrying about what the data calls M.y).
              If your lever arm is say 250mm and your load is say 2kg per bearing at that lever (figures I pluck from thin air), then you're applying 5 Nm, so you've got a factor of seven in hand.
              I have no idea how the stated static rated load relates to actual in-service reliability, but a factor of seven seems likely to be sufficient. I observe that the basic load (which I assume is direct load perpendicular to the face of the carriage) has a factor of about 1.6 between static and dynamic. In teh absence of anything else, we could apply that, and your factor drops to 4.5.
              None of this addresses flexibility though - even if the rail has sufficient strength, a cantilevering arrangement is possibly a good deal more flexible than a spanning arrangement.
              • achrn
                achrn @JoergS5 last edited by
                @JoergS5 said in Do Linear Rails Perform Well Under Cantilever Loads?:
                Is it? Is there a belt carrying the weight at the far end of the member?
                Turbo JoergS5 2 Replies Last reply Reply Quote 0
                • Turbo
                  Turbo @achrn last edited by Turbo
                  @achrn I think? the center of gravity or the bed and anything attached to it, is where the belts lie. I can (shouldn't, but i can) actually print without the linear guides due to the balance, but the ringing is comical.
                  JoergS5 achrn 2 Replies Last reply Reply Quote 0
                  • JoergS5
                    JoergS5 @achrn last edited by
                    @achrn I think so, the belts are carrying all the weight. The linear guide takes some of the load like a "inclined plane", .
                    • JoergS5
                      @Turbo my recommeded two linear guides in total and belt in the middle of the focus weight would mean, the belt remains where it is (or where the middle of the bed is) and the linear rails left and right of the belts.
                      • achrn
                        achrn @Turbo last edited by
                        @Turbo said in Do Linear Rails Perform Well Under Cantilever Loads?:
                        @achrn I think? the center of gravity or the bed and anything attached to it, is where the belt lies. I can (shouldn't, but i can) actually print without the linear guides due to the balance, but the ringing is comical.
                        In that case I don't think there can be any (significant) moment on the guides, they are just being guides. I definitely wouldn't want to set up any opportunity for two linear guides to be fighting each other.
                        • JoergS5
                          JoergS5 @achrn last edited by JoergS5
                          @achrn you could install two guides "fighting each other", but then better as in a CNC machine one as fixed bearing and floating bearing solution. But imho in this case there is not much win, because there is not much load.
                          • Turbo
                            @achrn @JoergS5 So what im getting from this is that so long as I'm off-putting the main load onto something else, and primarily using the rails just as an alignment factor, it's fine. Sound about right?
                            JoergS5 fcwilt achrn 3 Replies Last reply Reply Quote 0
                            • JoergS5
                              @Turbo from my view, this is correct.
                              Turbo 1 Reply Last reply Reply Quote 1
                              • Turbo
                                Turbo @JoergS5 last edited by Turbo
                                @JoergS5 Awesome, thanks for the input. I suppose i now need to convert my other printer to a linear rail z axis with my extra rails 🙂
                                • JoergS5
                                  @Turbo I like them, but there are quality differences. I discovered one yesterday which is rusted, it is worth to maintain them a bit.
                                  • Turbo
                                    @JoergS5 I find that keeping a thin layer of lubricant on the rails helps with rusting. But yeah I actually have some surface rust on some other rails that sat for some months I was gone and no one cleaned them at all. These are LDO Rails from Printed Solid's shop. 400mm. Good Stuff
                                    • fcwilt
                                      fcwilt @Turbo last edited by
                                      @Turbo
                                      There many different designs out there in the real world, some good, some bad.
                                      I had a DBot for a while but didn't like it's design, so I took it apart and started over.
                                      I tried 4 guide rods (12mm dia) with two lead screws (8mm dia, 8mm pitch), one Z stepper, like my FT-5.
                                      I tried 4 guide rods (12mm dia) with three lead screws (8mm dia, 8mm pitch) and three Z steppers for auto-leveling.
                                      I now have 4 linear guides and two lead screws (12mm dia 2mm pitch), one Z stepper.
                                      That is working pretty well but I'm still getting some minor Z banding (I think that is what it is).
                                      My next experiment, if I get the motivation, is to try two lead screws (8mm dia, 8mm pitch) with attached steppers, to eliminate the belt in the current single stepper design which places a sideways load on the lead screws.
                                      I may even try three of the lead screw/stepper combos and give auto-leveling another go.
                                      I'm having fun.
                                      Printers: A FT-5 with the 713 upgrade bits. A custom MarkForged style. A small Utilmaker style and a CoreXY from kits. Various hotends. All with a variety of Duets (2 and 3) running 3.3.0
                                      • Turbo
                                        Turbo @fcwilt last edited by
                                        @fcwilt sounds like a fun project. Ever since I saw the Voron2, I've loved the idea of a belted Z axis, and it is really nice. No z banding to worry about assuming everything else it running smooth. Maybe consider what ive done and go belted. No lead screws to mess with
                                        fcwilt 1 Reply Last reply Reply Quote 0
                                        • fcwilt
                                          I'm always up for trying different things.
                                          How many belts? How many steppers?
                                          Thanks.
                                          • Turbo
                                            @fcwilt two belts. One stepper, which is geared 5:1, and a large rod to sync them up.
                                            Here's a section view of one side.
                                            fcwilt 2 Replies Last reply Reply Quote 1
                                            • fcwilt
                                              @Turbo
                                              Interesting?
                                              What size belts?
                                              Where did you get that kind of stepper?
                                              Part #?
                                              Thanks much.
                                              • Turbo
                                                @fcwilt
                                                • Gt2 9mm width x 2. Dont know the exact length offhand
                                                • Motor part # --> 17hs15-1684s-pg5
                                                  *Link to motor --> https://www.omc-stepperonline.com/nema-17-stepper-motor-bipolar-l38mm-w-gear-raio-51-planetary-gearbox-17hs15-1684s-pg5.html
                                                • fcwilt
                                                  @fcwilt
                                                  Thanks VERY much for that info.
                                                  I may have to try this as it is unlike any other approach I have used.
                                                  • achrn
                                                    (I think you've already reached this conclusion, but...) From the 3D picture, and assuming the linear rails have replaced the four wheel carriage that's back central in that view, yes, I think that rail is actually carrying next to no loads in any direction - it's just stopping the platform swinging round on the belt. (Though it obviously doesn't swing free since the belt is restrained top and bottom). My initial understanding (assumption) was that you had the belt only on one side (i.e. as if the diagram shows the whole drive mechanism) - then there would have been a significant moment on the carriage.
                                                    • fcwilt
                                                      I've decided to go ahead and try belts of my Z axis.
                                                      Do you have any link(s) to more images or 3D models of your printer that I could look at?
                                                      Thanks.
