Taz Workhorse + Duet Wifi -> Mesh Bed Leveling Issues?
  • I purchased a taz workhorse second-hand that had been upgraded with a duet wifi and PanelDue. This is my first printer with duet control, and I'm inclined to believe I'm doing something wrong, but I've ran through the gcode/config/etc and am at a loss. It appears that mesh bed leveling is not being applied to the first layer. Any help would be greatly appreciated!
    I have verified that the heightmap is successfully being saved and updated each time I run a G29. However, these are my results using the settings I have listed below:
    Left Closeup Full Bed Right Closeup
    left full bed right
    Here is my config.g:
    G90                                                    ; send absolute coordinates...
    M83                                                    ; ...but relative extruder moves
    M550 P"Taz Workhorse"                                  ; set printer name
    M308 S11 P"mcu-temp" Y"mcu-temp" A"Duet Board"         ; Configure MCU sensor
    M552 S1                                                ; enable network
    M586 P0 S1                                             ; enable HTTP
    M586 P1 S0                                             ; disable FTP
    M586 P2 S0                                             ; disable Telnet
    M569 P0 S0                                             ; physical drive X goes backwards
    M569 P1 S0                                             ; physical drive Y goes backwards
    M569 P2 S1                                             ; physical drive Z1 goes forwards
    M569 P3 S0                                             ; physical drive E0 goes backwards
    M569 P4 S0                                             ; physical drive Z2 goes backwards
    ; Dual Z Axis
    M584 X0 Y1 Z2:4 E3                                     ; two Z motors connected to driver outputs Z and E1
    M671 X-100:400 Y150:150 S4                             ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
    ; Motor settings
    M350 X32 Y32 Z32:32 E32 I0                             ; configure microstepping without interpolation
    M92 X200.00 Y200.00 Z1000.00 E819.20                   ; set steps per mm
    M566 X480.00 Y480.00 Z300.00 E12000                    ; set maximum instantaneous speed changes (mm/min)
    M203 X12000.00 Y12000.00 Z3000.00 E1500.00             ; set maximum speeds (mm/min)
    M201 X4500.00 Y4500.00 Z50.00 E10000.00                ; set accelerations (mm/s^2)
    M906 X1000 Y1000 Z1250 E850 I30                        ; set motor currents (mA) and motor idle factor in per cent
    M84 S30                                                ; Set idle timeout
    M208 X-50 Y-20 Z-5 S1                                  ; set axis minima
    M208 X300 Y315 Z300 S0                                 ; set axis maxima
    M574 X1 S1 P"xstop"                                    ; configure active-high endstop for low end on X via pin xstop
    M574 Y1 S1 P"ystop"                                    ; configure active-high endstop for low end on Y via pin ystop
    M574 Z1 S2                                             ; configure Z-probe endstop for low end on Z
    M950 S0 C"exp.heater3"                                 ; create servo pin 0 for BLTouch
    M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000          ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X-4.15 Y-57.4 Z1.70                           ; set Z probe trigger value, offset and trigger height
    M557 X20:260 Y20:250 P3:3                              ; define mesh grid
    M308 S0 P"bedtemp" Y"thermistor" T100000 B3974         ; configure sensor 0 as thermistor on pin bedtemp
    M950 H0 C"bedheat" T0                                  ; create bed heater output on bedheat and map it to sensor 0
    M307 H0 B0 S1.00                                       ; disable bang-bang mode for the bed heater and set PWM limit
    M140 H0                                                ; map heated bed to heater 0
    M143 H0 S120                                           ; set temperature limit for heater 0 to 120C
    M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
    M950 H1 C"e0heat" T1                                   ; create nozzle heater output on e0heat and map it to sensor 1
    M307 H1 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
    M143 H1 S300                                           ; Set temperature limit for extruder to 300C
    M141 H2                                                ; Assign chamber heater to heater 2
    M307 H2 B1                                             ; chamber heater operates in bang-bang mode
    M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin e1temp
    M950 H2 C"e1heat" T2                                   ; create chamber heater output on e0heat and map it to sensor 2
    M143 H2 S70                                            ; Set temperature limit for chamber to 60C
    M950 F0 C"fan0" Q500                                   ; create fan 0 on pin fan0 and set its frequency
    M106 P0 S0 H-1                                         ; set fan 0 value. Thermostatic control is turned off
    M950 F1 C"fan1" Q500                                   ; create fan 1 on pin fan1 and set its frequency
    M106 P1 S0 H11 T38                                     ; set fan 1 value. Thermostatic control is turned on
    M563 P0 S"Extruder" D0 H1 F0                           ; define tool 0
    G10 P0 X0 Y0 Z0                                        ; set tool 0 axis offsets
    G10 P0 R0 S0                                           ; set initial tool 0 active and standby temperatures to 0C
    M575 P1 B57600 S1
    M501                                                   ; load saved parameters from non-volatile memory
    T0                                                     ; select first tool
    Here is my start gcode in Slic3r PE:
    ;M141  S{first_layer_bed_temperature[0]-45}
    M104 R{first_layer_temperature[0]-60}
    M190 S{first_layer_bed_temperature[0]} ; bed heating up
    G28
    ;G1 X150 Y150 Z10
    ;G1 E-2
    G32
    G29
    G28 XY
    G1 X20 Y0 Z3 F3000
    M109 R{first_layer_temperature[0]}
    G1 E1 F75 ; prime tiny bit of filament into the nozzle
    G1 X20 Z0.5 E5 F500 ; start purge line
    G1 X50 E15 Z0.5 F500 ; finish purge line
    My bed.g gcode looks like such:
    M561
    G28                                      ; home
    G30 P1 X10 Y130 Z-99999                 ; probe near a leadscrew, half way along Y axis
    G30 P0 X270 Y130 Z-99999 S2             ; probe near a leadscrew and calibrate 2 motors
    Thank you for any help you might be able to provide!
  • Moderator
    What is in your homeall?
    Does it appear to be doing the tilt correction correctly?
    It's usually a good idea to do a single G30 at the center of the bed (same place you probe during homeall) to readjust the Z0 position since it will have changed slightly from the tilt correction.
  • @Phaedrux Thanks for the quick reply.
    Here is my homeall:
    G91                                 ; relative positioning
    G1 H2 Z15 F6000                     ; lift Z relative to current position
    G1 H1 X-345 Y-340 F4000             ; move quickly to X and Y axis endstops and stop there (first pass)
    G1 H2 X5 Y5 F6000                   ; go back a few mm
    G1 H1 X-345 Y-340 F2000             ; move slowly to X and Y axis endstops once more (second pass)
    G90                                 ; absolute positioning
    G1 X150 Y190   F6000                  ; go to first bed probe point and home Z
    G30                                 ; home Z by probing the bed
    ;G91                                ; relative positioning
    ;G1 Z5 F100                         ; lift Z relative to current position
    ;G90                                ; absolute positioning
    Regarding your comment of running the G30, I should just be able to invoke G28 without the XY params, which should run the homeall script, correct? Instead of just homing x and y?
  • Moderator
    @elli said in Taz Workhorse + Duet Wifi -> Mesh Bed Leveling Issues?:
    Yes, but if you do that move the G29 to after the G28.
    Or just add this to the end of your bed.g
  • Thank you for the help! Going to go experiment!
    PS hyper light drifter is one of my favorites.
  • Moderator
    Your grid is also only using 3x3 points, which is quite sparse. Try increasing the number of points to get a more detailed mesh.
    If the bed is stable you can load the saved heightmap with G29 S1 rather than creating a new one each time. That way you can do a very detailed heightmap once and not have to re-probe every time.
  • Foolish of me to make two changes at once. I updated the grid to be 4x4 and also added the gcode to bed.g. Now however, my bltouch is reporting 1000 in the console and i'm getting an error stating that it is already deployed. Not sure what I broke 😞
  • Moderator
    Post your current config.g
    It can also be useful to send M98 P"config.g" to see if there are any syntax errors in your config.
  • ; Configuration file for Duet WiFi (firmware version 3)
    ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jun 13 2020 22:43:12 GMT-0500 (Central Daylight Time)
    ; Dual Z Axis
    ; Motor settings
    M557 X20:260 Y20:250 P4:4                              ; define mesh grid
    M575 P1 B57600 S1
    Only modification here was the M557 P3:3 -> P4:4
    Output of M98 P"config.g":
    M98 P"config.g"
    HTTP is enabled on port 80
    FTP is disabled
    TELNET is disabled
    Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
    Warning: Heater 2 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
  • Moderator
    Try changing your M558 to this: M558 P9 C"^zprobe.in" H5 F120 T6000
  • Welp. That got the probe to start working again. Not Running a test print to check if it's respecting bed leveling. Are there any resources you could point to as to why the M558 command that you provided worked, and why a problem arose then?
  • Moderator
    The only real difference between mine and yours is that mine has the ^ to enable the pullup resistor. The +zprobe.mod on yours was superfluous and likely just ignored anyway.
    Without the pullup resistor it may only work occasionally? That's the best I got.
