    Cant get duet 2 in corexy to move correctly
    114
    • Szwalkiewicz
      Szwalkiewicz last edited by
      If i send it a M669 it sends me
      m669
      Kinematics is CoreXY, matrix:
      1.00 1.00 0
      1.00 -1.00 0
      0 0 1.00
      and the motor outputs are not correct
      if i move in X, X moves at a 45° and 1 Z motor moves
      if i move in Y, Y moves at a 45° and other Z motor moves
      I have never got both x and y motors to move at the same time when i move the machine
      could use someones help if you got time, there is something i'm not understanding
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Oct 16 2020 22:33:42 GMT-0500 (Central Daylight Time)
      M550 P"My Printer" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P4 S1 ; physical drive 3 goes forwards
      M584 X0 Y1 Z2:4 E3 ; set drive mapping
      M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X300 Y300 Z300 S0 ; set axis maxima
      M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
      M574 Y2 S1 P"!ystop" ; configure active-high endstop for high end on Y via pin ystop
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 P9 C"^zprobe.in" H5 F120 T1500 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X2 Y-43 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X25:275 Y25:275 S75 ; define mesh grid
      1ri 1 Reply Last reply Reply Quote 0
      • Veti
        Veti last edited by
        please verify that you are on firmware version 3.1.1
        using m115
        Szwalkiewicz 1 Reply Last reply Reply Quote 0
        • Veti
          Veti last edited by
          @Szwalkiewicz said in Cant get duet 2 in corexy to move correctly:
          unrelated but your thermistor config is wrong. find your correct beta value in the technical documentation of your thermistor.
          • Szwalkiewicz
            Szwalkiewicz @Veti last edited by
            @Veti
            m115
            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
            • Veti
              Veti last edited by
              what is the command you issued?
              • 1ri
                1ri @Szwalkiewicz last edited by
                @Szwalkiewicz
                greetings
                I see that in the M669 command of config.g you only define the kinematics type as corexy (K1) but you do not define the motion matrix.
                i use the following command on my corexy printer and it works fine for me
                M669 K1 X1: 1 Y1: -1
                the console output it gives me is as follows:
                M669
                1.00 1.00 0 0
                1.00 -1.00 0 0
                0 0 1.00 0
                0 0 0 1.00
                I hope it serves
                • Veti
                  Veti last edited by
                  for the default corexy M669 K1 does not need parameters.
                  you seem to need it because you have 4 axis.
                  • Szwalkiewicz
                    @Veti
                    how i moved it was:
                    the printer is a 300x300x300 so i moved it to the center on x,y and z and (by hand) and sent a g92 of 150 on all three and then used the paneldue jog screen on move around
                      https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
                      • Szwalkiewicz
                        The dzuki is always a good place to start, but movment on Z when i move the X or Y I think shows of a larger underlying problem
                        I tried it on two seperate duet2wifi's one on 2.xx and 3.xx firmware with the same outcome I must have missed a step some where
                        I'm going to hard reset one and reload the firmware
                        Veti 1 Reply Last reply Reply Quote 0
                        • Veti
                          Veti @Szwalkiewicz last edited by
                          @Szwalkiewicz
                          change out of corexy mode and test each motor seperately
                          • Szwalkiewicz
                            @Veti I like you idea so I erased a board reloaded firmware to start fresh on and rebuild the sd card files. On Cartesian Kinematics I set the motor output to M584 Z0 Y1 X2 E3 (to match board silkscreen) and placed to motor wires on the board to match and everything works as planed 🙂 then thats when i powered down the board and on reboot with no changes Z and X swaped places? now the motor output is not matching the M584?
                            Veti Phaedrux 2 Replies Last reply Reply Quote 0
                            • Veti
                              M584
                              run the command in the console and see if it matches
                                Phaedrux Moderator @Szwalkiewicz last edited by Phaedrux
                                M584 Z0 Y1 X2 E3
                                0 is not the Z driver. The default would be M584 X0 Y1 Z2 E3:4
                                So when you are seeing movement of the Z axis it's probably because you have the x or y motor connected to the z stepper or z axis motor to the x stepper.
                                • Szwalkiewicz
                                  Szwalkiewicz @Phaedrux last edited by
                                  @Phaedrux Thanks Phaedrux and Veti for your time and help. I incorrectly assumed the drive assignments
