    GREAT job on G2
    • alankilian
      alankilian last edited by alankilian
      I've been using G2 for a while now, and have started using it to do X,Y,Z moves and it works perfectly.
      Most of the online GCODE previewers don't render this correctly, neither does Simplify3D.
      This previewer does render them correctly.
      https://nraynaud.github.io/webgcode/
      So, thank you for allowing my SeemeCNC Rostock Max V3.2/Duet to perform the proper motions to allow me to make things. (That seam has gone away since I started doing X,Y and Z moves for each semicircle.)
      This object had a diameter of 2 inches and there are 178 G2 semicircles in each layer.
      IMG_5724.jpg spiralG2.gcode
        Nice print! How are you generating the Gcode that uses G2 commands?
        • alankilian
          I write little programs in C that generate GCODE.
