    Unsolved Paneldue 5i dead
    PanelDue
    124
    • marcus3d
      marcus3d last edited by
      Hello! My paneldue was working as it should. Though i pushed the erasebutton to be able to update the firmware and now it is completely dead. No response when in my 2 computers with multiple tries with different cables. What to do?
      wilriker 1 Reply Last reply Reply Quote 0
        Have you tried disconnecting the PanelDue from the Duet, and then connecting the PanelDue to the PC using a USB cable?
        marcus3d 1 Reply Last reply Reply Quote 0
          Did you follow the entire firmware update procedure?
          https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
          • marcus3d
            marcus3d @dc42 last edited by
            Yes i have @dc42
            • marcus3d
              marcus3d @Phaedrux last edited by
              I didnt get that far .@Phaedrux
              • wilriker
                wilriker @marcus3d last edited by
                @marcus3d I have seen a similar behavior if the PanelDue was still connected to the Duet but not powered. Powering the PanelDue via USB to use it worked but after pressing the erase button it would not show up as a serial device unless I turned on power on the printer (reliably worked) or disconnect it from the printer (only once did not work).
                When you say completely dead: does background light turn on when you apply power to it?
                Manuel
                My Tool Collection
                • marcus3d
                  marcus3d @wilriker last edited by
                  @wilriker
                  No there is no backlight when connected to the printer either.
                    When and where was your PanelDue purchased?
                    • marcus3d
                      Hi!
                      It is purchased e3donline.com. 5 March 2020 at 13:07:15 GMT
                      SKU: E-DUET-P-DUE-4
                      orderid 002088422
                        Please contact E3D and initiate a warranty exchange. You can link them to this thread as authorization.
