    Z Probe deploy
    171
    • micktol
      micktol last edited by
      I have a duet 2 ethernet running rrf v3. I am trying to set up a z probe which is a servo controlled as here https://www.thingiverse.com/thing:3303618 .
      When I send g30 the probe does not deploy and I receive the probe already triggered message.
      M401 and M402 work correctly and if I deploy the probe then send M30 it probes and retracts at the end.
      How can I get the probe to deploy before the error?
      • fcwilt
        fcwilt last edited by
        I think with this kind of probe you have to use the M40x codes to deploy/retract the probe.
        Did you try this:
        M401
        G30
        M402
        • micktol
          Thank you for your reply.
          When I send M401 then G30 it probes and then retracts so it is half working!
          IF I send just G30 the servo starts to move and then stops with the error, so I thinks it needs a delay but I have no idea how to implement it .
          • jay_s_uk
            jay_s_uk last edited by
            @micktol have you followed this? https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3
            Can you post your config.g and your deploy and retract files?
            • Veti
              Veti last edited by
              you could try and set the probe type to P9
              then M401 and M402 are called automatically
              • micktol
                I am using P9 but the probe deploy seems to be cancelled by the probe already triggered error.
                Veti fcwilt 2 Replies Last reply Reply Quote 0
                • Veti
                  Veti @micktol last edited by Veti
                  @micktol said in Z Probe deploy:
                  ah then you have to switch to P8 and add the M401 and M402 to the homing scripts
                  • fcwilt
                    fcwilt @micktol last edited by
                    The BLTouch is quick to deploy/retract so I'm guessing the timing that is part of P9 is correct for the slower servo in your probe.
                    The reason for the "already triggered" error is because when the servo unit is retracted it also activates the switch. Since the servo is slow to deploy it appears the switch is still activated when the probe is checked as to it's state.
                    You will need to use one of the types meant for switches and use the M40x commands as needed.
                    • micktol
                      Thanks to everybody who replied, I have now found the solution.
                      In deployprobe.g I added a dwell so now it is:
                      M280 P0 S10
                      g4 s0.5
                      everything works correctly now.
                      fcwilt 1 Reply Last reply Reply Quote 1
                      • fcwilt
                        M280 P0 S10
                        g4 s0.5
                        Very good - I've never used that command but I have heard about it.
                        Thanks.
