Problems connecting Z-probe using a microswitch
  • Hello,
    I have a inductive sensor, signalling an optocoupler for closing a circuit between the signal pin and the ground pin. This works for the x and y axis.
    I have the same sensor which I want to use for my z probe. Browsing on the website gives me two choices:
    1. Connect to z-probe.in and ground, do the same. Doesn't work
    2. Set it in P4 and connect it to the E0 stop. This doesn't work since I have RRF3.1. The specific help the website provides is only for firmwares which are older and not working for the current firmwares.
    My question: I have a signal and ground cable for a sensor fitted next to the nozzle. Where do I put which cable AND what do I write in my configuration.g? I do not want to avoid the board with the optocouplers, just working with those cables.
    Kind regards
  • Hi,
    What version of firmware?
    What does the command the references "z-probe.in" look like?
    Thanks.
  • Moderator
    In RRF3 you would use M558 P5 and specify the pin being used in M558 C.
    What duet board are you using?
    Post your complete config.g
    Kind regards
    You only have 2 cables? 1x Signal 1x ground?
    Most normal induction sensors require 3 wire connections... 1x power (12-36v is common) 1x signal 1x ground.
    How are the other sensors wired? Do they have an additional power connection?
  • yes it has a seperate power supply, therefore 2 cables. Using the Duet 2 wifi, firmware 3.1.1.
    config file:
    M550 P"Artechno Printer" ; set printer name
    M551 P"Artechno" ; set password
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P5 R1 S1 ; physical drive 0 goes forwards
    M569 P6 R1 S1 ; physical drive 1 goes forwards
    M569 P7 R1 S1 ; physical drive 2 goes forwards
    M569 P8 R1 S1 ; physical drive 3 goes forwards
    M584 X5 Y6 Z7 E3 ; set drive mapping
    M350 E32 I0 ; configure microstepping without interpolation
    M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
    M92 X80.00 Y80.00 Z320.00 E837.20 ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
    M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X1400 Y1000 Z500 S0 ; set axis maxima
    M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
    M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
    M574 Z1 S2 ; configure Z-probe endstop for low end on Z
    M558 P5 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
    G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
    M557 X15:215 Y15:195 S50 ; define mesh grid
    M307 H0 B0 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
    I have an optocoupler that switches when the signal cable is active. I want to use that circuit for the z probe. Therefore, I thought: I use P5, state C"zprobe.in" and use my ground on the other side. This didn't work. Any ideas?
  • Moderator
