    Adding duex5 and all motor stop working
    70
    • Scachi
      Scachi last edited by
      I got an used duex5 from a friend that had a blown driver 8 chip. He got himself a new duet3 and gave me his broken duex5 plus a replacement chip.
      At first I had tested the duex5 board without replacing the chip by adding it to my system and the board did work fine with its remaining driver (except that blown driver).
      Now I have replaced that blown driver 8 chip with the chip I got with the board and I still get report from that one:
      Error: short-to-ground reported by driver(s) 8
      Error: over temperature shutdown reported by driver(s) 8
      And now all my driver aren't working anymore when I add the duex5 to my system (including my duet wifi ones).
      When I try to home/power my drives I get:
      10/21/2020, 12:48:38 AM	Warning: motor phase A may be disconnected reported by driver(s) 0 1
      Warning: motor phase B may be disconnected reported by driver(s) 0 1
      10/21/2020, 12:48:34 AM	G28
      Warning: motor phase A may be disconnected reported by driver(s) 6 7 9
      Warning: motor phase B may be disconnected reported by driver(s) 6 7 9
      When I remove the duex5 my driver on my duet wifi work fine again.
      Any Ideas ? Should I try to desolder the chip and check if it works without that chip ?
      Should I put back the old/broken driver onto it and check if it works then ?
      Or should I better accept my try to repair it as failed and get myself a new duex5 ?
      M115 output:
      10/21/2020, 12:52:10 AM	m115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.2-beta1 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2020-09-15b1
      Thank you.
      Veti 1 Reply Last reply Reply Quote 0
      • Veti
        Veti @Scachi last edited by
        @Scachi said in Adding duex5 and all motor stop working:
        there is very special requirements for wiring the duex5.
        see https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiring
        observe the length and how its wired
        Scachi 1 Reply Last reply Reply Quote 0
        • Scachi
          Scachi @Veti last edited by
          @Veti said in Adding duex5 and all motor stop working:
          I have double checked the wiring (polarity, continuity) and can't find a problem.
          For soldering I removed all the connections, took the board out, did the soldering, waited for cooldown of the board, checked the chip soldering visually, did put the duex5 back in and the wiring as it was before when the duex5 did work before the soldering.
          I think I need a more detailed idea/answer what can cause that issues that all drivers start to report an error. Is this problem common at all when there is a wiring issue ?
          m115 finds the duex5 .. so can the wiring really being the problem here ?
          I think I try to undo the soldering and check if it is back to previous working state then.
          • Veti
            Veti last edited by
            post a picture of your wiring and soldering
            • Scachi
              different question:
              I have a fully working duex5 board that works fine with my duet wifi.
              I am now getting curious and desolder one of the driver chips on the duex5 ( reported as number 8 ) .. will the board still work fine without that chip in its place ?
                Phaedrux Moderator @Scachi last edited by
                @Scachi Yes, but it will likely complain. You can use M569 P8 R-1 to disable that stepper.
                https://duet3d.dozuki.com/Wiki/Gcode#Section_M569_Set_motor_driver_direction_enable_polarity_and_step_pulse_timing
                As Veti says, post a photo of your wiring and soldering. Obviously something got fried during the replacement, but pretty hard to say what.
                • Scachi
                  Please note:
                  I have removed the chip again, while doing so I did see a note on the backside of the duex5 that this one is a cloned board.
                  Feel free to ignore all this as I don't feel comfortable to bother you asking for help for hardware that is cloned. Feel free to lock/delete the thread.
                  I have ordered a valid/offical duex5 board now and will report if everything works fine with that.
                  Thank you both for your answers.
                  Now I had the chance to take some photos of its current state, I have removed the chip again:
                  Here is the M122 output:
                  M122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta1 running on Duet WiFi 1.02 or later + DueX5
                  Board ID: 08DGM-95BNL-MGPSJ-6J1D4-3SD6M-KJZVX
                  Used output buffers: 3 of 24 (12 max)
                  Static ram: 23916
                  Dynamic ram: 100060 of which 44 recycled
                  Exception stack ram used: 312
                  Never used ram: 6740
                  Tasks: NETWORK(ready,145) HEAT(blocked,294) DUEX(blocked,36) MAIN(running,456) IDLE(ready,20)
                  Owned mutexes: WiFi(NETWORK)
                  Last reset 00:16:43 ago, cause: power up
                  Last software reset at 2020-10-21 00:39, reason: User, GCodes spinning, available RAM 6740, slot 0
                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                  Error status: 0x020
                  MCU temperature: min 20.2, current 33.2, max 33.7
                  Supply voltage: min 25.3, current 25.5, max 25.8, under voltage events: 0, over voltage events: 0, power good: yes
                  Driver 0: position 2, standstill, SG min/max not available
                  Driver 1: position 2, standstill, SG min/max not available
                  Driver 2: position 4, standstill, SG min/max not available
                  Driver 5: position 0, standstill, SG min/max not available
                  Driver 6: position 0, standstill, SG min/max not available
                  Driver 7: position 0, standstill, SG min/max not available
                  Driver 8: position 0, temperature-shutdown! short-to-ground, standstill, SG min/max not available
                  Driver 9: position 0, standstill, SG min/max not available
                  Driver 10: position 0
                  Driver 11: position 0
                  Date/time: 2020-10-22 16:42:41
                  Cache data hit count 1783850941
                  Slowest loop: 8.45ms; fastest: 0.16ms
                  === Storage ===
                  Free file entries: 10
                  SD card longest read time 10.1ms, write time 0.0ms, max retries 0
                  Hiccups: 0(0), FreeDm: 169, MinFreeDm: 166, MaxWait: 8060ms
                  === MainDDARing ===
                  Scheduled moves: 1, completed moves: 1, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                  === AuxDDARing ===
                  Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                  Segments left: 0
                  Movement lock held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is idle in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  LCD is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 16.14ms; fastest: 0.00ms
                  HTTP sessions: 1 of 8
                  - WiFi -
                  Network state is active
                  WiFi firmware version 1.23
                  WiFi MAC address 2c:3a:e8:0b:2e:a0
                  WiFi Vcc 3.37, reset reason Turned on by main processor
                  WiFi flash size 4194304, free heap 23320
                  WiFi IP address 192.168.178.22
                  WiFi signal strength -53dBm, reconnections 0, sleep mode modem
                  Clock register ffffffff
                  === Filament sensors ===
                  Extruder 0 sensor: ok
                  Extruder 1 sensor: ok
                  === DueX ===
                  Read count 1, 0.06 reads/min
                  I have a command in my config to power on the motors after boot of the duet for my corexy:
                  ; move a bit to power up all motors
                  G91
                  G1 H2 X0.01 Y0.01 Z0.01
                  G90
                  When I remove the duex5 without changing anything in the config my x+y motors gets powered.
                  With the duex5 attached the x+y motors aren't getting powered anymore. This doesn't change if I connect the z-motors to the driver on the duex or if I let them disconnected.
                  Here is the complete config:
                  ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Oct 05 2020 15:43:27 GMT+0200 (Central European Summer Time)
                  G90                                               ; send absolute coordinates...
                  M83                                               ; ...but relative extruder moves
                  M550 P"rr-vcore"                                  ; set printer name
                  M669 K1                                           ; select CoreXY mode
                  M551 P"redcap"                                    ; set password
                  M552 S1                                           ; enable network
                  M586 P0 S1                                        ; enable HTTP
                  M586 P1 S0                                        ; disable FTP
                  M586 P2 S0                                        ; disable Telnet
                  M569 P0 S0                                        ; physical drive 0 goes forwards
                  M569 P1 S0                                        ; physical drive 1 goes forwards
                  M569 P2 R-1                                       ; physical drive 2 goes forwards
                  M569 P3 S1                                        ; physical drive 3 goes backwards
                  M569 P4 S1                                        ; physical drive 4 goes backwards
                  M569 P6 S0                                        ; physical drive 6 goes backwards
                  M569 P7 S0                                        ; physical drive 7 goes backwards
                  M569 P8 R-1                            			  ; Drive 8 tripple Z duex5 DEFUNC BLOWN CHIP
                  ;M569 P8 S0                            			  ; Drive 8 tripple Z duex5 DEFUNC BLOWN CHIP
                  M569 P9 S0                                        ; physical drive 9 goes backwards
                  M584 X0 Y1 Z6:7:9 E3:4                            ; set drive mapping
                  M350 X16 Y16 Z16 E16:16 I1                        ; configure microstepping with interpolation
                  M92 X160.00 Y160.00 Z400.00 E305.50:143.00        ; set steps per mm
                  M566 X800.00 Y800.00 Z12.00 E2000.00:2000.00      ; set maximum instantaneous speed changes (mm/min)
                  M203 X12000.00 Y12000.00 Z180.00 E7980.00:7980.00 ; set maximum speeds (mm/min)
                  M201 X3000.00 Y3000.00 Z150.00 E6000.00:10000.00  ; set accelerations (mm/s^2)
                  M906 X1500 Y1500 Z1800 E1600:1600 I30             ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30                                           ; Set idle timeout
                  M208 X-10 Y-8.5 Z-1 S1                            ; set axis minima
                  M208 X297 Y305 Z265 S0                            ; set axis maxima
                  M574 X2 S1 P"xstop"                               ; configure active-high endstop for high end on X via pin xstop
                  M574 Y1 S1 P"ystop"                               ; configure active-high endstop for low end on Y via pin ystop
                  M574 Z1 S2                                        ; configure Z-probe endstop for low end on Z
                  M950 S0 C"duex.pwm5"                              ; create servo pin 0 for BLTouch
                  M558 P9 C"^zprobe.in" H5 F90 T20000               ; set Z probe type to bltouch and the dive height + speeds
                  G31 P500 X29 Y0 Z2                                ; set Z probe trigger value, offset and trigger height
                  M557 X20:280 Y15:285 S25                          ; define mesh grid
                  M308 S0 P"bedtemp" Y"thermistor" T100000 B4138    ; configure sensor 0 as thermistor on pin bedtemp
                  M950 H0 C"bedheat" T0                             ; create bed heater output on bedheat and map it to sensor 0
                  ;M307 H0 B1 S1.00                                 ; enable bang-bang mode for the bed heater and set PWM limit
                  M307 H0 A163.7 C1249.7 D0.5 S1.00 V24.8 B0		  ; auto tuned with: M303 H0 S100
                  M140 H0                                           ; map heated bed to heater 0
                  M143 H0 S120                                      ; set temperature limit for heater 0 to 120C
                  M308 S1 P"e0temp" Y"thermistor" T100000 B4138     ; configure sensor 1 as thermistor on pin e0temp
                  M950 H1 C"e0heat" T1                              ; create nozzle heater output on e0heat and map it to sensor 1
                  ;M307 H1 B0 S1.00                                 ; disable bang-bang mode for heater  and set PWM limit
                  M307 H1 A673.8 C218.7 D5.4 S1.00 V25.2 B0		  ; auto9 tuned with: M303 H1 S240 , 3in 1out 24V
                  M950 F0 C"fan0" Q500                              ; create fan 0 on pin fan0 and set its frequency
                  M106 P0 S0 H-1                                    ; set fan 0 value. Thermostatic control is turned off
                  M950 F1 C"fan1" Q500                              ; create fan 1 on pin fan1 and set its frequency
                  M106 P1 S1 H1 T45                                 ; set fan 1 value. Thermostatic control is turned on
                  M950 F2 C"fan2" Q500                              ; create fan 2 on pin fan2 and set its frequency
                  M106 P2 S1 H0 T60:120 C"PSup"	  				  ; Monitor BED heat to control power supply fans. Thermostatic control is turned on
                  M563 P0 S"0_Rear" D0 H1 F0                        ; define tool 0
                  G10 P0 X0 Y0 Z0                                   ; set tool 0 axis offsets
                  G10 P0 R0 S0                                      ; set initial tool 0 active and standby temperatures to 0C
                  M563 P1 S"1_Front" D1 H1 F0                       ; define tool 1
                  G10 P1 X0 Y0 Z0                                   ; set tool 1 axis offsets
                  G10 P1 R0 S0                                      ; set initial tool 1 active and standby temperatures to 0C
                  M575 P1 S1 B57600                                 ; enable support for PanelDue
                  ; Taper of height compensation above this mm value
                  ;M376 H1.0
                  ; Pressure Advanced
                  M572 D0 S0.4 ; set extruder 0 pressure advance
                  M572 D1 S0.4 ; set extruder 1 pressure advance
                  ; Endstop Filament
                  M591 D0 P1 C"e0_stop" S1; Extruder 0, high on filament out (P2 says "no" when filament present, P1 says "yes" when filament present) P2:IR, P1:Switch
                  M591 D1 P1 C"e1_stop" S1; Extruder 1, high on filament out (P2 says "no" when filament present, P1 says "yes" when filament present) P2:IR, P1:Switch
                  ; Bed Leveling
                  M671 X-54:150:354 Y50:370:50 S15; adjusting screws at left front#6, mid-rear#7 and right front#9
                  ; start up sound
                  G4 S7 ; pause delay for panel due to connect
                  M98 P/macros/Misc/FxShort
                  G91
                  G90
                  • Veti
                    Veti last edited by
                    your thermistor config is wrong. look up the correct beta value in you thermistor documentation
                      dc42 administrators @Scachi last edited by
                      You photo looks OK as far as I can see, however I suggest you check carefully for tiny solder bridges between the pads for the removed chip. A likely reason for no chips working (including drivers on the main board) is a short between one of the SPI MISO, MOSI or SCK pads and another pad.
