    Duet 2 Wifi With Gigabot Thermocouple Issue
    My Duet controlled machine
    • mosesbuckwalter
      mosesbuckwalter last edited by
      Hello All! This is my first post, and first printer, so bear with me. I received a Gigabot 3 from a friend about a year ago and we've been slowly working on it. In August we put a Duet 2 Wifi in it and got everything working except the bed heater and the extruder heat, obviously thats a problem. I am using 2 type K thermocouples and this thermocouple board:
      https://www.printedsolid.com/products/duet-type-k-thermocouple-daughter-board
      The sensors read 2000c at all times and here's a picture of the duet web interface. Screen Shot 2020-10-20 at 8.32.34 PM.png
      If theres any other useful information I'm missing please let me know, and at this point I'm down to try anything. Thanks in advance!
        That image looks like an older version of the web interface. I'm pretty sure a firmware update will be in your near future.
        Can you use the Gcode console to send M122 and copy and paste the results?
        Can you also copy and paste the contents of your config.g file?
        Have you seen these?
        https://duet3d.dozuki.com/Wiki/Thermocouple_daughter_board
        https://duet3d.dozuki.com/Wiki/Connecting_thermocouples
        mosesbuckwalter 1 Reply Last reply Reply Quote 0
        • mosesbuckwalter
          mosesbuckwalter @Phaedrux last edited by
          @Phaedrux
          Thanks for the reply! I have checked both those out and numerous other threads.
          I had tried updating to 3 but had received an error, but that was back in early August, maybe its time I try again.
          The heater section of my config.g looks like this
          M305 P1 X100
          M305 P1 X101
          M305 P0 X102
          M305 P0 X103
          I set them both to 2 different channels because I wasn't sure how to determine which channel they were on.
          Heres the output of M122
          Used output buffers: 3 of 32 (13 max)
          RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later
          Board ID: 08DLM-996RU-N8PS4-6J9FG-3SD6L-9VURN
          Static ram used: 16152
          Dynamic ram used: 100400
          Recycled dynamic ram: 2232
          Stack ram used: 1224 current, 4448 maximum
          Never used ram: 7840
          Last reset 00:00:46 ago, cause: power up
          Last software reset at 2020-10-20 20:06, reason: User, spinning module GCodes, available RAM 7776 bytes (slot 0)
          Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
          Error status: 0
          Free file entries: 10
          MCU temperature: min 34.7, current 35.6, max 35.9
          Supply voltage: min 23.7, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0
          Date/time: 2020-10-20 20:44:16
          Slowest main loop (seconds): 0.015620; fastest: 0.000046
          MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
          Scheduled moves: 0, completed moves: 0
          Bed compensation in use: none
          Heater 0 is on, I-accum = 0.0
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          http is idle in state(s) 0
          telnet is idle in state(s) 0
          file is idle in state(s) 0
          serial is idle in state(s) 0
          aux is idle in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
          HTTP sessions: 2 of 8
          • WiFi -
            Network state is running
            WiFi firmware version 1.23
            WiFi MAC address f4:cf:a2:59:85:c4
            WiFi Vcc 3.37, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 25872
            WiFi IP address 192.168.0.30
            WiFi signal strength -76dBm, reconnections 0, sleep mode modem
            Socket states: 2 0 0 0 0 0 0 0
            === Expansion ===
          Another possible useful thing would be this error, which I also received earlier. Screen Shot 2020-10-20 at 8.45.12 PM.png
          Thanks in advance!
            Have you tried reseating the daughterboard in its pins?
            How do you have your thermocouple wired to the daughterboard?
            Was the thermistor ever working before?
            1.21 is a very old firmware. I would say that updating is probably a good idea, though you will need an updated config file. If you post your entire config.g that would help me produce an updated config for you, or you can use the values in there to create a fresh config file for RRF3 using the online tool.
            In this case I would update to 2.0 first, and then 2.05.1 and then 3.0 and then 3.1.1. The last 3 of those are quite easy once you're on 2.0. It may seem tedious to do it this way, but it also ensures you have all the needed files from all the releases along the way.
            First start with the 2.0 bin file. Upload it to the /sys folder and then send M997 to flash it if it doesn't detect it automatically.
            https://github.com/Duet3D/RepRapFirmware/releases/download/2.0/Duet2CombinedFirmware.bin
            At this point you can upload the web interface update zip file to the /sys folder, as is, don't extract it.
            https://github.com/Duet3D/RepRapFirmware/releases/download/2.0/DuetWebControl-1.21.1.zip
            Now you should be able to upload the 2.05.1 zip file, as is, don't extract it, straight to the /sys folder. It should detect and update the firmware and web interface and reboot.
            Then do the same for the 3.0 and 3.1.1 zip files.
            https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
            https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
            That should get you up to date and then you can upload a config file set zip file you get from the configurator https://configtool.reprapfirmware.org/Start
            Then if you still have some issues we can tackle them then. It will be easier once you're on modern firmware.
              dc42 administrators @mosesbuckwalter last edited by
              @mosesbuckwalter said in Duet 2 Wifi With Gigabot Thermocouple Issue:
              M305 P1 X100
              M305 P1 X101
              M305 P0 X102
              M305 P0 X103
              1. You can't set a single heater to use 2 channels. For example, the M305 P1 X101 command will cancel the M305 P1 X100 command.
              2. Unless the thermocouple board is the older version, you need to use X150 and X151, not X100 and X101. The image on the Printed Solid page shows the newer version, which uses MAX31856 chips, but the text incorrectly says that it uses MAX31855.
              • Referenced by  Phaedrux Phaedrux
