    Duet Web control is not available at time of printing
    Duet Web Control
    282
    • DronBroks
      DronBroks last edited by
      Good afternoon!
      I have a printer based on the Duet 2 Maestro board. The board is connected to the router with a cable, it is assigned a permanent IP address. In addition, the Duet Panel is connected to the board 5 inches.
      When printing, access to Duet Web Control is lost. Access appears only after rebooting the board. The printer address is pinged. The printer is controlled from the panel. Only Web Control falls off.
      The board is flashed with firmware 3.1.1 and the Web Control version is taken from there.
      What might not work like that?
      • Veti
        Veti last edited by
        there was a post a few weeks back where a user was reporting similar issue.
        this was due to electrical interference from the stepper wires.
        DronBroks 1 Reply Last reply Reply Quote 0
        • DronBroks
          DronBroks @Veti last edited by
          @Veti Thanks!
          I read this post. Home test this version. But I have a cable to the router passes the signal wires stepper motors.
            Please post the results of M122 and double check that DWC is version 3.1.1
            How are you permanently assigning an IP address?
            Post your config.g
            • DronBroks
              DronBroks @Phaedrux last edited by
              @Phaedrux
              M122
              RepRapFirmware for Duet 2 Maestro version 3.1.1 running on Duet Maestro 1.0
              Board ID: 08DJM-956DU-LL3SW-6JTDG-3SJ6S-1UHLR
              Used output buffers: 3 of 24 (12 max)
              Static ram: 21924
              Dynamic ram: 89580 of which 44 recycled
              Exception stack ram used: 408
              Never used ram: 19116
              Tasks: NETWORK(ready,432) HEAT(blocked,1316) MAIN(running,1996) IDLE(ready,84)
              Owned mutexes:
              Last reset 05:56:42 ago, cause: power up
              Last software reset at 2020-10-21 20:26, reason: User, spinning module GCodes, available RAM 19300 bytes (slot 3)
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
              Error status: 0
              MCU temperature: min 25.5, current 34.8, max 38.4
              Supply voltage: min 0.0, current 12.6, max 12.8, under voltage events: 0, over voltage events: 0, power good: yes
              Driver 0: ok, read errors 0, write errors 0, ifcount 9, reads 2347, timeouts 0
              Driver 1: standstill, read errors 0, write errors 0, ifcount 9, reads 2347, timeouts 0
              Driver 2: standstill, read errors 0, write errors 0, ifcount 9, reads 2347, timeouts 0
              Driver 3: ok, read errors 0, write errors 0, ifcount 9, reads 2339, timeouts 8
              Driver 4: standstill, read errors 0, write errors 0, ifcount 6, reads 2350, timeouts 0
              Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 2356
              Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 2355
              Date/time: 2020-10-22 08:59:13
              Slowest loop: 48.15ms; fastest: 0.12ms
              === Storage ===
              Free file entries: 9
              SD card 0 detected, interface speed: 15.0MBytes/sec
              SD card longest read time 22.0ms, write time 0.0ms, max retries 0
              Hiccups: 0(0), FreeDm: 165, MinFreeDm: 109, MaxWait: 361770ms
              === MainDDARing ===
              Scheduled moves: 209242, completed moves: 209223, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: 3
              === AuxDDARing ===
              Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
              Bed heaters = 0 -1, chamberHeaters = -1 -1
              Heater 0 is on, I-accum = 0.3
              Heater 1 is on, I-accum = 0.2
              Segments left: 1
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is doing "G1 X182.914 Y233.246 E0.36015" in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              Daemon is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 8.95ms; fastest: 0.02ms
              HTTP sessions: 1 of 8
              Interface state active, link 100Mbps full duplex
              === Filament sensors ===
              Extruder 0 sensor: ok
              A static IP address is assigned by the router.
              Config
              ; Configuration file for Duet Maestro (firmware version 3)
              ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 23 2020 13:34:11 GMT+0300 (Москва, стандартное время)
              M80
              M550 P"Dron Printer" ; set printer name
              M669 K1 ; select CoreXY mode
              M551 P"XXXXXXXXX" ; set password
              M552 PXXX.XXX.XXX.XXX S1 ; enable network and acquire
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M569 P0 S1 D3 ; physical drive 0 goes forwards stealthChop2
              M569 P1 S1 D3 ; physical drive 1 goes forwards stealthChop2
              M569 P2 S1 D3 ; physical drive 2 goes forwards stealthChop2
              M569 P3 S0 D3 ; physical drive 3 goes forwards stealthChop2
              M350 X64 Y64 Z64 E32 I0 ; configure microstepping without interpolation
              M92 X320.00 Y320.00 Z3219.50 E1000.00 ; set steps per mm
              M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min) Jerk
              M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
              M201 X1000.00 Y1000.00 Z100.00 E2000.00 ; set accelerations (mm/s^2)
              M204 P1000 T5000 ; Maximum printing acceleration 1000.0, maximum travel acceleration 5000.0
              M906 X800 Y800 Z800 E600 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X300 Y300 Z240 S0 ; set axis maxima
              M574 X1 S1 P"!xstop" ; configure active-low endstop for low(min) end on X via pin xstop
              M574 Y2 S1 P"!ystop" ; configure active-low endstop for high(max) end on Y via pin ystop
              M574 Z1 S2 ; configure Z-probe endstop for low(min) end on Z
              M591 D0 P7 C"e0_stop" L7 R50:250 E22 S1 ; BTT sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 50 to 250%, 7mm/pulse, measure every 22 sek, enabled
              M558 P9 C"zprobe.in" H5 F120 T3000 ; BLTouch set Z probe type to unmodulated and the dive height + speeds
              M950 S0 C"zprobe.mod" ; BLTouch servo/gpio 0 is Z probe MOD pin
              M280 P0 S10 ; BLTouch send control signal to BLTouch through servo/gpio 0
              M280 P0 S90 ; Send PWM channel 0 the S90 (angle) command
              G31 P25 X-2.7 Y-50.6 Z2.45 ; BLTouch set Z probe trigger value, offset and trigger height
              M557 X10:290 Y10:290 S20 ; probe from X=10 to 290, Y=10 to 250mm with a mesh spacing of 20mm
              M308 S0 P"bedtemp" Y"thermistor" R2200 T100000 B3950 A"Stol-Temp" ; configure sensor 0 as thermistor on pin bedtemp
              M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
              M143 H0 S130 ; set temperature limit for heater 0 to 130C
              M308 S1 P"e0temp" Y"thermistor" R2200 T100000 B3950 A"Nozl_0-Temp" ; configure sensor 1 as thermistor on pin e0temp
              M308 S2 P"ctemp" Y"thermistor" R2200 T100000 B3950 A"Drivers-Temp" ; configure sensor 2 as thermistor on pin сtemp
              M308 S3 Y"mcu-temp" A"MCU-Temp" ;
              M950 F2 C"fan2" Q1000 ; create fan 2 on pin fan2 and set its frequency
              M106 P2 S1 H2 T40 ; set fan 2 value. Thermostatic control is turned on
              M501
              M200 D1.75 ; set all extruder filament diameters to 1.75mm
              • Veti
                Veti last edited by
                @DronBroks said in Duet Web control is not available at time of printing:
                first why are you not using interpolation?
                can you just for testing go down to x16 for all?
                • DronBroks
                  @Veti
                  I'm still testing a printer. Daylight interpolation supposed to do in the near future
                  Veti 1 Reply Last reply Reply Quote 0
                  • Veti
                    Veti @DronBroks last edited by
                    i dont know what you mean by that
                    • DronBroks
                      @Veti
                      I plan to enable interpolation later
                      • Veti
                        Veti last edited by
                        actually you can send
                        M350 X64 Y64 Z64 E32 I1
                        during the print.
                        i think you can even send
                        M350 X16 Y16 Z16 E16 I1 during the print as it adjusts steps as well (but i have not tried that)
                        but if its an important print you might not want to risk it.
                        • DronBroks
                          @Veti
                          I sent the first command while printing. Printing was interrupted, now only after work I can start printing again. In essence, the main question - after transferring the Ethernet cable outside the printer case, the Web server does not hang up yet.
                            With the high microstepping it's possible that you're saturating the CPU and it's not able to service the web interface requests quickly enough during a print.
                            Please test with x16 microsteps and interpolation enabled.
                            DronBroks 2 Replies Last reply Reply Quote 1
                            • DronBroks
                              @Phaedrux
                              Good. After the work is checked.
                              • DronBroks
                                @Phaedrux
                                After the transfer of the Ethernet cable from the printer body, hovering stopped interface (tested on a daily print interface can be accessed at any time)
                                jovo0911 1 Reply Last reply Reply Quote 0
                                • jovo0911
                                  jovo0911 @DronBroks last edited by
                                  @Phaedrux
                                  Any new infos here? I have also a problem with network connection. Sometimes I lost connection (mostly after upload a file - bigger then 10 mb)
                                    Phaedrux Moderator @jovo0911 last edited by
                                    @jovo0911 Might want to start a new thread with your specific details.
                                    • DronBroks
                                      Good afternoon!
                                      Problems continued, but less frequently. Most often, the problem appears when you create a folder on the memory card, or transfer to the card volumetric files. Sometimes the interface freezes during long-term work. And it is such that when downloading files pauses printing for a split second.
                                        @DronBroks Can you confirm that you have switched to x16 microstepping?
                                        Do you have a new SD card to test with?
                                        DronBroks 2 Replies Last reply Reply Quote 0
                                        • DronBroks
                                          @Phaedrux Yes, I switched to 1x16 microsteps. Perhaps the reason is actually in the memory card. I’m not very fast. Today I will buy a new one and check with a new card
                                          Phaedrux 1 Reply Last reply Reply Quote 1
                                          • DronBroks
                                            DronBroks @Phaedrux last edited by DronBroks
                                            @Phaedrux
                                            M80
                                            M551 P"" ; set password
                                            M552 P192.ххх.ххх.ххх S1 ; enable network and acquire
                                            M350 X16 Y16 Z16 E32 I1 ; configure microstepping interpolation
                                            M92 X80.00 Y80.00 Z804.875 E1001 ; set steps per mm
                                            ; Jerk
                                            ; Maximum Speeds
                                            ; Accelerations
                                            M201 X1000.00 Y1000.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
                                            M906 X900 Y900 Z900 E600 I30 ; set motor currents (mA) and motor idle factor in per cent
                                            M591 D0 P5 C"e0_stop" R50:140 E4.0 S0 ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 40 to 120%, 7mm comparison length, enabled
                                            G31 P25 X-2.7 Y-50.6 Z1.54 ; BLTouch set Z probe trigger value, offset and trigger height
                                            ; M308 S1 P"e0temp" Y"pt1000" R2200 A"Nozl_0-Temp" ; configure sensor 1 as thermistor on pin e0temp
                                            M501
                                              Phaedrux Moderator @DronBroks last edited by
                                              Yes please test with a new SD card. When you do so, replace the files in the /www folder with a fresh set from the DWC 3.1.1 zip file.
                                              https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/DuetWebControl-SD-3.1.1.zip
                                              Also try with a different ethernet cable, just in case.
                                              • DronBroks
                                                @Phaedrux said in Duet Web control is not available at time of printing:
                                                I replaced the SD card with a new (class 10), the DWC has updated the files, replace the cable. As a result, the DWC fell off after 8 hours printing. On the old card it occurred 5-6 hours after printing
                                                  Can you share one of your volumetric gcode files?
                                                  Do you have a large number of nested folders?
                                                  Can you try a different ethernet port on your switch/router?
                                                  • DronBroks
                                                    And where to put this file?
                                                    • DronBroks
                                                      There are many subfolders (each project has its own folder). But this problem does not depend on the depth of nesting. The interface also freezes if you print a file from the root of the card and from a subfolder.
