    PanelDue 2.0; "SAM-BA operation failed "when flashing
    PanelDue
    117
    • StevenL
      StevenL last edited by
      I have an old PanelDue v2.0 (green secondary board) that I tried to flash with newer firmware (PanelDue-v2-5.0.bin). After the update, it no longer displays any image. I can press Erase button and then reset. It does register as COM4 Bossa programming port. How do I revive it? Did I brick it?
      I'm following these instructions to flash: link text
      A Former User 1 Reply Last reply Reply Quote 0
      • A Former User
        A Former User @StevenL last edited by
        @StevenL said in PanelDue 2.0; "SAM-BA operation failed "when flashing:
        with newer firmware
        its possible the newer firmware (v3.2) is too large to fit in the cpu, see the release notes/whats new for details.
        you likely did not brick it, the sam-ba bootloader is read-only so you can safely write another firmware to the board.
        some people hare having problems with dodgy usb cables and usb ports, even some operating systems so trying another, cable or computer if the problem isn't the available flash size might be worth while.
          Can you link to the exact version you're talking about?
          When connected with Samba does it show some info on what the CPU is? I know on bossa you can get some info from the board.
          If 3.2 doesn't work because there isn't enough ram you'd have to stick with 1.24.
          • StevenL
            Update: I was able to fiddle with it and get v1.24 firmware re-installed. The display shows now, touch calibrated.
            BUT when I connect the screen to the DuetWifi, the touch is not always working, and when it i press say Setup, i hear the beep but it doesnt actually go to the setup screen.
            ideas why?
              Anything loose after playing with it?
              What version of firmware are you running on the Duet?
              StevenL 1 Reply Last reply Reply Quote 0
              • StevenL
                StevenL @Phaedrux last edited by
                @Phaedrux nothing loose. Duetwifi running 2.05.1
                This is my second printer with a DuetWifi. So I have a complete other printer with DuetWifi and PanelDue.
                Veti 1 Reply Last reply Reply Quote 0
                  Might be worth trying to reflash the Paneldue again.
                  • StevenL
                    I found that the 3d printed case is pinching part of the screen... basically overwhelming the touch sensor. out of the case it works fine. I even re-made the cable.
                    • Veti
                      Veti @StevenL last edited by
                      that is not compatible with the latest paneldue release.
