Problems with sensorless homing
  • I’m having problems with my sensorless homing, around 50% of the time the Y-axis going in the wrong direction when homing. Functions properly when printing tho. I’ve already replaced the wire and upped the current already but has had no effect. I didn’t have any problems with sensorless homing on my arduino 2560 mega with TMC2209 before the upgrade either so the motors should be good.
  • Moderator
    post your config.g and homing files.
    Have you seen this? https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing
  • @c-bldwn said in Problems with sensorless homing:
    Sounds like an issue with absolute and relative moves in homing. Add the files Phaedrux asked for and I'm sure someone will have a fix for it
  • @Phaedrux not sure how to post picture on here but here is a link to the post I made on the Facebook group and have posted the pictures there. Yes I had used that guide to set up the sensorless home if, I didn’t try adjusting the steps/s initially. I have now tried between 200 and 400 with 40-60% current. Seemed like it might start moving a little bit better but then it didn’t was to stop once it hit the limits, regardless of what threshold I tried.
    https://www.facebook.com/groups/512053822637021/permalink/977115966130802/
  • @bearer I don’t see why it would be intermittent like it is if that were the case. The homing files were also created by the web configuration tool and I only modified the current %’s. Also it seems worse after sitting over night too. The only information I could find suggested it could be missing a step from a bad cable or driver that would cause it to rotate the wrong direction but I’ve replaced the cable already and both cables I know worked before switching to the duet.
  • Moderator
    Please copy and paste the text of your config.g and homing files.
  • @Phaedrux
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Sep 26 2020 16:50:18 GMT-0600 (Mountain Daylight Time)
    M550 P"Duet Multicolor" ; set printer name
    M551 P"18831883" ; set password
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P0 S1 ; physical drive 0 goes forwards (X)
    M569 P1 S0 ; physical drive 1 goes backwards (Y)
    M569 P2 S0 ; physical drive 2 goes backwards (Z)
    M569 P3 S1 ; physical drive 3 goes forwards (E0)
    M569 P4 S1 ; physical drive 4 goes forwards (E1)
    M569 P5 S1 ; physical drive 5 goes forwards (E2)
    M569 P6 S1 ; physical drive 6 goes forwards (E3)
    M569 P7 S1 ; physical drive 7 goes forwards(E4)
    M569 P8 S1 ; physical drive 8 goes forwards(E5)
    M584 X0 Y1 Z2 E3:4:5:6:7:8 ; set drive mapping
    M350 X16 Y16 Z16 E16:16:16:16:16:16 I1 ; configure microstepping with interpolation
    M92 X80.71 Y80.66 Z403.84 E106.47:97.07:96.49:96.00:96.00:96.00 ; set steps per mm
    M566 X1200.00 Y1200.00 Z18.00 E8000.00:1200.00:1200.00:1200.00:1200.00:1200.00 ; set maximum instantaneous speed changes (Jerk) (mm/min)
    M203 X8700.00 Y8700.00 Z2100.00 E8700.00:8700.00:8700.00:8700.00:8700.00:8700.00 ; set maximum speeds (mm/min)
    M201 X3000.00 Y3000.00 Z50.00 E3000.00:1500.00:1500.00:1500.00:1500.00:1500.00 ; set accelerations (mm/s^2)
    M906 X1000 Y1000 Z600 E1000:900:900:900:900:900 I50 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X-9 Y-9 Z0 S1 ; set axis minima
    M208 X305 Y305 Z400 S0 ; set axis maxima
    M574 X1 S3 ; configure sensorless endstop for low end on X
    M574 Y1 S3 ; configure sensorless endstop for low end on Y
    M574 Z1 S2 ; configure Z-probe endstop for low end on Z
    M915 X R0 F0 S2 ; set X threshold
    M915 Y R0 F0 S3 ; set Y threshold
    M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch
    G31 P500 X30 Y0 Z.8 ; set Z probe trigger value, offset and trigger height
    M557 X25:275 Y25:275 S125 ; define mesh grid
    M143 H0 S100 ; set temperature limit for heater 0 to 100C
    ; Disable Heater to free up PWM channel
    M307 H7 A-1 C-1 D-1 ; disable heater 7 for BLTouch
    M563 P0 S"Extruder 0" D0 H1 F0 ; define tool 0
    M563 P1 S"Extruder 1" D1 H1 F0 ; define tool 1
    G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
    G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
    M563 P2 S"Extruder 2" D2 H1 F0 ; define tool 2
    G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
    G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
    M563 P3 S"Extruder 3" D3 H1 F0 ; define tool 3
    G10 P3 X0 Y0 Z0 ; set tool 3 axis offsets
    G10 P3 R0 S0 ; set initial tool 3 active and standby temperatures to 0C
    M563 P4 S"Extruder 4" D4 H1 F0 ; define tool 4
    G10 P4 X0 Y0 Z0 ; set tool 4 axis offsets
    G10 P4 R0 S0 ; set initial tool 4 active and standby temperatures to 0C
    M563 P5 S"Extruder 5" D5 H1 F0 ; define tool 5
    G10 P5 X0 Y0 Z0 ; set tool 5 axis offsets
    G10 P5 R0 S0 ; set initial tool 5 active and standby temperatures to 0C
    M501
  • @Phaedrux
    ; homeall.g
    ; called to home all axes
    M400
    M913 X70 Y80 ; drop motor current %
    M400 G91; relative positioning
    G1 H2 Z5 F12000 ; lift Z relative to current position
    G1 H1 X-305 F6000 ; move quickly to X and Y axis endstops and stop there (first pass)
    G1 H2 X5 F6000 ; go back a few mm
    G1 H1 X-305 F3600 ; move slowly to X and Y axis endstops once more (second pass)
    G1 H1 Y-305 F6000 ; move quickly to X and Y axis endstops and stop there (first pass)
    G1 H2 Y5 F6000 ; go back a few mm
    G1 H1 Y-305 F3600 ; move slowly to X and Y axis endstops once more (second pass)
    G90 ; absolute positioning
    M400
    M913 X100 Y100 ; return current to 100%
    M400
    G1 X130 Y150 F6000 ; go to first bed probe point and home Z
    ;G91 ; relative positioning
    ;G1 Z5 F100 ; lift Z relative to current position
    ;G90 ; absolute positioning
  • @Phaedrux
    ; homey.g
    ; called to home the Y axis
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Sep 26 2020 16:50:19 GMT-0600 (Mountain Daylight Time)
    M400
    M913 Y90 ; drop motor current to 90%
    G1 H1 Y-305 F6000 ; move quickly to Y axis endstop and stop there (first pass)
    G1 H1 Y-305 F3600 ; move slowly to Y axis endstop once more (second pass)
    G1 H2 Z-5 F6000 ; lower Z again
    M400
    M913 Y100 ; return current to 100%
    M400
  • Moderator
    Thanks. Can you also send M115 and confirm your firmware version?
  • @Phaedrux
    It’s a completely new setup, I deleted the old files and did a restore to 3.1.1 for my initial setup then used the web configuration tool to generate the setup and then made the changes I needed.
    Date Event
    2020-10-25, 2:29:19 PM M115
    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2020-05-19b2
  • Moderator
    First. The motor current you're dropping down to is inconsistent. You will need to find the absolute lowest current you can use and still get reliable motion. Having low current is critical to getting a reliable stall.
    Second. Don't do multiple passes when using stall detection homing. The stall is going to be most reliable on a fast pass. Once it hits and you back off slightly and then slowly try to stall again it's never going to work as well as the first fast pass. There is no accuracy gain here as there might be from multiple slower passes on an endstop. The stall is going to snap to the nearest motor full step.
  • @Phaedrux
    Maybe that’s something that should be also changed in the web configuration tool as that is not something I added. I had my concerns about that as I know you don’t generally want it and I had removed it on my other printer still running marlin but left it in as I figured maybe duet had a reason for it. How can I find out the best current setting, I’ve tried between 40% and 90% in increments of 10 already and didn’t have any luck. Here are my motor specs.
    Motor Model 42HS1411-20B19
    Step Angle(°) 1.8
    Holding torque(mN.m) 280
    Rated current(A) 1.5
    Rated Voltage(V) 3
    Resistance per phase(Ω) 2.1±10%(20℃)
    Inductance per phase(mH) 2.5±20%
    Mass 0.2kg
    Rotor inertia(g.cm²) 45
    Insulation Class: B
    Ambient Working Temperature Range(℃) " -20 to + 60℃ "
    "Temperature rise MAX (rated current, 2 phase on) (℃)" 80℃
  • Moderator
    For normal operation to recommendation is to use 60-85% of the rated max current for the motor.
    So 1500 max * 60% = 900
    or 1500 max * 85% = 1300
    And in your config you have 1000ma, which is fine.
    To find the lowest current for reliable movement, simply use M913 to lower it down to the lowest you can still get movement.
    Try M913 X10 and try to move the X axis around with the jog buttons. Try blocking it with your hand. If it sometimes stalls without any effort on your part, increase it to X20. etc.
    Do the same for the Y axis.
  • Oh I forgot to mention before switching to duet, on the factory arduino 2560 mega board with tmc2209 drivers I was running the Y axis at 1000ma normal and 50% of that for homing and didn’t have any issues before.
  • Moderator
    Doesn't really matter. Once you drop the current and do a single fast homing move stall detection should improve.
  • @Phaedrux
    Ok so I tested as you reccomended, got best results with X60 and Y90. I ended up bumping The current up for the Y from 1000 to 1200 and tested again and found Y80 to work well. I then had to up the Y threshold to 5 to get it to move and seems to work as expected when it hits the home. However I’m still having issues with the y axis wanting to go the wrong direction sometimes. I bumped the threshold up to 7 and seems to be more reliable. I’ll test this out a bit and let you know if I’m still getting the problem or not.
  • This post is deleted!
  • Ok so after testing for a bit last night and today my problem seems to be fixed. Thanks for the help!!
