calibration IR probe RRF3
  • Hello,
    I have a problem with the calibration of my IR probe ...
    Since I have been on RRF3.1.1 I can no longer calibrate my probe. I follow the adjustment procedure to the letter =>
    Nozzle in the center of the bed (usual temperature)
    Touch the nozzle to the tray (or sheet of paper)
    G92 Z0 (Z = 0)
    Raise the 5 mm nozzle (G92 Z5)
    G30 S-1
    Read the z value
    G31 Z xxx
    I get the value of 2.66. I report in my Config.g.
    G31 P500 X-19 Y6 Z2.58
    (M558 P1 C "zprobe.in + zprobe.mod" H5 F120 T6000 two independent Z)
    And nothing helps, my first layer is still too overwritten, so I'm trying to correct manually in my Config.g ,. I put for example G31 P500 X-19 Y6 Z2.48 or G31 P500 X-19 Y6 Z2. 38. The result remains the same step of change always too crushed.
    On the other hand, if I play with BabyStepping or if I adjust the height of my Z in my slicer… does it work? An idea ?
  • post your config
  • @Rudy2A said in calibration IR probe RRF3:
    if you can get a good layer with babystepping adjust the offset by the amount you babystepped.
  • @Veti
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Oct 22 2020 08:00:14 GMT+0200 (heure d’été d’Europe centrale)
    M550 P"Bunch3D+" ; set printer name
    M669 K1 ; select CoreXY mode
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P0 S0 ; moteur 0 X
    M569 P1 S0 ; moteur 1 Y
    M569 P2 S0 ; moteur 2 ZA
    M569 P3 S0 ; moteur extrudeur
    M569 P4 S0 ; moteur 4 ZB
    M584 X0 Y1 Z2:4 E3 ; set drive mapping
    M671 X-58: 317 Y132: 132 S10 ; vis à plomb à gauche (connectées à Z) et à droite (connectées à E1) de l'axe X
    M350 X16 Y16 Z16 U16 E16 I1 ; configure microstepping with interpolation
    M92 X80 Y80 Z1600 U1600 E830 ; set steps per mm
    M566 X600 Y600 Z60 U60 E2400 ; set maximum instantaneous speed changes (mm/min)
    M203 X11639 Y11639 Z200 U200 E600 ; set maximum speeds (mm/min)
    M201 X800.00 Y800.00 Z40.00 U40.00 E300.00 ; set accelerations (mm/s^2)
    M906 X950 Y950 Z950 U950 E1120 I20 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X0 Y0 Z-0.5 U-0.5 S1 ; set axis minima
    M208 X270 Y2700 Z240 U240 S0 ; set axis maxima
    M574 Z1 S2 P"io2.in + io3.in"; Axe Z avec deux moteurs, butées min.
    M558 P1 C"zprobe.in+zprobe.mod" H5 F120 T6000
    G31 P500 X-19 Y6 Z2.58 ; set Z probe trigger value, offset and trigger height
    M307 H0 A435.0 C388.3 D7.8 B0 S0.8 V13.4
    M307 H1 A650.7 C221.3 D4.8 B0 S1 V13.3 ; disable bang-bang mode for heater and set PWM limit
    M143 H1 S245
    G10 P0 X0 Y0 Z0 U0 ; set tool 0 axis offsets
  • @Veti
    Déjà fait justement… quand j’obtiens un bon résultat avec les BabyStepping si je veux reporter et ajuster le décalage obtenu, ça ne fait rien… C’est comme si mon G31 Z xxx ne fonctionnait pas. ???
    if you did not change this to z probe, did you change your homing files?
    i would suggest that you make the changes in the configurator and upload the new config.
    your thermistor settings are incorrect, look up the correct beta value for your thermistor in its documentation
  • Thank you for your answers, I don't use Config Tools, I absolutely don't like it ... For my thermistors. Right now, I don't have a problem with that, I can heat up to ready degrees, I'll check it out when I fix my probe problem… Thanks again.
    i was not doubting that. the thermistor has no influence on the heating part. its responsible for displaying the correct temperature.
    i dont understand, your config has been created by the config tool
  • Yes, I used the tool to create the first file to spot where the changes were compared to RRF2. But afterwards, all my changes are done live and without the tool. When I say that I don't like this tool, I should rather say that it is not for me ...
  • ok you can still do the changes manually.
    just loo at the differences in all the files when you select a z probe in the configurator.
  • Moderator
    It can be helpful to send M98 P"config.g" to see if you have any syntax errors.
    Also very helpful to compare to the output of the online configuration tool.
  • @Phaedrux said in calibration IR probe RRF3:
    M98 P "config.g"
    I don’t understand, this is my answer with M98 P "config.g" ????
    M98 P "config.g"
    Warning: Macro file "config.g" not found
    M98 P "config.g"
    no space after P
  • thank's 👍
    M98 P"config.g"
    HTTP is enabled on port 80
    FTP is disabled
    TELNET is disabled
    Error: Invalid use of P parameter
    Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 460C
    Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 675C
    you have one invalid command. execute each line separately until you find it.
    You dont declare a U axis, but configure it afterwards.
  • Honestly, I think I have to reinstall everything!
    The more I change settings, the more errors I get.
    And the problem is, I'm not sure what to declare in the configuration tool ... I'm not talking about the basics like the dimensions of my machine, the size of my bed, the steps of my motors. But how do I declare a double Z, (Z + U) my heating thermistors… other?
  • I redid and redone my files again ... And nothing helps, nothing changes, worse I'm drowning completely.
    Someone with good intention to configure me (bass) my printer with the configuration tool. This would be a bass config file with the declared double Z (Z + U). I'm not asking you to do the work for me, I just want to compare files to understand and then be able to reproduce ... It's the only way for me, I know everything is detailed in procedure, but frankly as you can understand, this It's not easy to assimilate everything technically when it is not written in your mother tongue, a period, a comma, a bad translation and find yourself off topic. Thank you for your help.
    Sincerely the file comparison method is working for me. it's not to just copy and paste stupidly, it's to be able to continue to understand the RRF3 logic.
  • @Rudy2A
    the reason to go with the configurator is that it generates a config that saves you from small pitfalls.
    like order dependency of the commands etc.
    in your case changing of the M574 for z probe and changing the homing files no to use the endstops.
  • @Veti
    I understand that the configuration tool is there to help me (I do not disagree) and what I ask is that they explain it to me or that they give me a little help to configure it, because it is not easy for me (for lack of fluency in English) to understand everything he asks, it may seem stupid, but I assure you that it is indeed the reality ... with the translation, he gives me a bunch of words that I I have to put things back in order to try to make a solution that is necessarily not always the right one.
    The proof, just a simple request for help is already a problem between us, I think the translator does not exactly reproduce my request and makes us go around in circles ... Thank you anyway.
  • ask specific questions where you are unsure in the configurator.
    then we can hopefully clarify them.
    maybe this helps a bit.
    https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38
  • I assure you that I am not having a bad time. It's like, I wanted to convince you that I made the best wine from home in Corsica by explaining it to you in my written language… I'm sure you'll be more convinced if I gave it to you!
    Here are the different stages where I am not comfortable. What should I put for all of these pages?
    Mini IR Probe
    Genuine E3D V6
    Genuine E3D 300X300 bed (Semitec 104GT) 220V
    thank's
  • check: Select the first tool on Start-up.
    That is helpful for testing.
    Modulation Pin is not required for the ir probe, as there is no back channel. so set that do not assigned
    z enstop to not assigned is ok as well, since you want to use the ir sensor.
    for the e3d. in the the heater window. click on the beta field. and select semitec for both bed and hotend.
    Add these lines
    to Custom Settings for config.g: on the last page
  • Frankly, even installing my original backup file which used to work fine before… I end up with new errors. It's nothing to understand ... I'm sure too stupid. A function that would be nice to add to the configuration tool would be, from the first step. A button checked which would tell us: if you are a big moron, check this box and the answer would be: since you checked this box, take an interest in Marlin (noisier, cheaper, but configurable without any problem). Two years that I was shooting with RRF2 and no problem, easy configuration and good result. Thanks to RRF3, I think my printer will take some distance with me, by propelling it from the 5th floor, I would have created the first flying 3D printer.
  • Moderator
    @Rudy2A come now, don't despair. We will get you there eventually, but only if you don't give up.
    Can you post your current config.g please?
    Double Z/U axis is not needed in RRF3 if you intend to do leveling with two endstops. You only need a U axis if you want manual control of both Z motors.
    In your config above you have these pins define, but those are pin names for the Duet 3. The rest of your pin names for for Duet 2. I think this may be the cause of the invalid use of P parameter.
    Can you restate the current problem?
