Problem setting up core XY
@mrehorstdmd
Electrical Specification
Bipolar/Unipolar Bipolar
Holding Torque(Ncm) 46
Holding Torque(oz.in) 65.1
Inductance(mH) 3
Phase Resistance(ohm) 1.4
Rated Current(A) 2
Step Angle(°) 0.9
Physical Specification
Body Length(mm) 48
Frame Size(mm) 42 x 42
Single Shaft/Dual Shaft Single Shaft
Shaft Type D-Cut
Shaft Diameter(mm) 5
Shaft Length(mm) 24
No. of Lead 4
Lead Length(mm) 500
Weight(g) 400 -
@william3d said in Problem setting up core XY:
Shaft Type D-Cut
blv require full d-cut shafts. could the pulleys be slipping?
@Veti You could be onto something the two motors on X and Y Part numbers are different and I think it means one is .9 and one is 1.8 Looking up and trying to verify right now.
17HS19-2004S2
17HS19-2004S1 -
17HS19-2004S2 1.8 deg
17HS19-2004S1 0.9 deg -
@Veti Hopefully that is it I do have another S1 I am swapping them out right now.
did you buy the blv kit?
https://www.omc-stepperonline.com/motor-kit-for-blv-mgn-cube-3d-printer.html/?tracking=5c7cdef6c9645the 2 17HS19-2004S2 are for the z axis
the 2 17HM19-2004S1 are for x and y
and 1 17HS16-2004S1 for e
@Veti Yes I did, will have to check the Z.
@Veti If you could see me now I am doing the happy dance problem solved unbelievable I've been fighting this for a while. This is printer number 2 and I'm still working on printer 1 modifying changing never-ending Hobby/business. I also have in the works a large Core XY HEVORT.
How do I mark this solved?
Topic tools, ask as question, and then topic tools again, mark as solved.
