    Spindle speed control
    1.1k
    • TonyPagettundefined
      TonyPagett
      I want to add a PWM output from my Duet3D board to control a VFD and spindle.
      I have a PWM to voltage (1-10v) board that converts a PWM value into voltage. (5v =50%, 10v=100% etc) that connects to my VFD.
      QUESTION:
      Can I use heater 4 (on pin 13 of the Duet board) as a PWM output by using the following in my post processor?
      M307 H4 A-1 C-1 D-1 -- to disable heater 4
      M42 P4 Snnn --to send a PWM value
        jay_s_uk
        What firmware version are you on?
        Have you seen M453 which sets the machine in CNC mode to allow the use of M3 and M5?
        TonyPagettundefined 1 Reply Last reply Reply Quote 0
        • A Former User?
          A Former User @TonyPagett
          my Duet3D board
          presume you have a duet 2 wifi or duet 2 ethernet? running reprapfirmware v2.x?
          by persuming its a duet 2 you're refering to the 50 pin expansion header, that should give you a 3.3v pwm signal, but you might want to use
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M453_Select_CNC_Device_Mode
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M3_Spindle_On_Clockwise_CNC_specific_Laser_on_Laser_specific
          instead of M42, also beware in some case the firmware invert the heater output pins
            TonyPagett @jay_s_uk
            @jay_s_uk
            I do use M453 cnc mode. How do I assign a particular pin as a PWM output?
            Would it just be a case of M453 P4 R24000 (max spindle speed) and then M3 S255 for max speed?
              jay_s_uk
              depends of the version of the firmware you are on.
              Whats the output from M115?
                @jay_s_uk
                v2.03
                I have just been looking at using a fan output instead. M106 P2 Snnn.
                Would this work?
                  jay_s_uk @TonyPagett
                  @TonyPagett said in Spindle speed control:
                  If your standard heater ports are available I would just use one of those.
                  And yes, it would be as you've suggested, just using the right pin number (and freeing up the pin)
                  I would also consider upgrading to RRF3 when a CNC orientated version of DWC is released as you can also add a direction pin rather than jumpering forward to ground.
                  This is a helpful page. https://openbuilds.com/threads/workbee-cnc-w-duet2-and-chinese-spindle-control.14004/
                  Also connect the grounds on the VFD to a ground on the PSU for the duet (but this would be a DC ground and not an AC ground).
                  I use 3.2 beta 2 on my machine and I have this PWM converter https://www.amazon.co.uk/1-3KHZ-Voltage-Module-Digital-Converter/dp/B0789738RC/ref=sr_1_3?crid=AAYEZCBCA2WZ&dchild=1&keywords=pwm+to+analog+converter&qid=1603813874&sprefix=pwm+to+ana%2Caps%2C160&sr=8-3
                    @jay_s_uk
                    Many thanks. I will do a few tests using various options.
                    FYI, my VFD allows me to disable the REV direction (which I have already done to prevent broken end mills!!)
                    Many thanks again.
