    Capacitive Sensor
    1.7k
    • Rudy2Aundefined
      Rudy2A
      This configuration works perfectly with the IR probe.
      S2 probes the 4 corners (2X2).
      If you put S4, it will probe 4 points on the first line multiplied by 4, so 16 points on the bed.
      This is valid for S3, S6 ...
      Vetiundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti @Rudy2A
        @Rudy2A
        so you are talking about G29 and not G32.
        M208 X270 Y270 Z245 S0 ; set axis maxima
        G31 P500 X0 Y-43 Z1.30 ; set Z probe trigger value, offset and trigger height
        M557 X11:250 Y11:252 S20 ; define mesh grid
        This does not match.
        Also there will be an error message in the console telling you whats wrong.
        Y252 can not be reached with an offset of -43
        change this to
        M557 X11:250 Y11:220 S20 ; define mesh grid
        Rudy2Aundefined 1 Reply Last reply Reply Quote 0
        • Rudy2Aundefined
          Rudy2A @Veti
          @Veti said in Capacitive Sensor:
          Y252 ne peut pas être atteint avec un décalage de -43
          changez ceci en
          M557 X11: 250 Y11: 220 S20; définir la grille de maillage
          thank you,
          Indeed, with that it works ...
          On the other hand, depending on the tests carried out, the capacitive or IR probe is similar. I would tell you that my finding to come.
          • Rudy2Aundefined
            Rudy2A @Rudy2A
            I definitely left the capacitive probe to the detriment of the mini IR probe.
            The reason is that for me the weight of the capacitive probe was a bit too heavy. She was exerting a difference on my bed when polling.
            FYI, my bed is not absolutely stable and the slightest difference in weight causes a difference in the measurement in the height map.
            I will be working on another much more stable bed system soon, so I will test again.
            Vetiundefined 1 Reply Last reply Reply Quote 1
            • Vetiundefined
              Veti @Rudy2A
              @Rudy2A
              there a small capacitive probes like the pinda probe
              • ziggymanpopoundefined
                ziggymanpopo
                I found the sensors all gad its addvantages and dis -advantages after som monkeyong arround i decided to try this 16056489496302843328936229039224.jpg
                  ziggymanpopo
                  I installed the z swich on tip of the extruder
                  Which sits on two linerer rails so when the nozzle
                  Touches the bed it trips the sw
                  This works really well and is extremely accurate
                  I went this way because of the fluctuations with most sensors. be aware this is a ton of work but well worth it in my opinion. im happy with my mod but took 4 months to put together and i have lots if time. The other sensor i used was a n abl capasitive
                  I found out i was as much as 1.5 mm off at random
                  Other times it worke fair but not supper accurate
                  The other option is the bl toutch im affraid i would go thru a bunch breaking the pins..🙂 good luck thought i would share that. 👍
                  • Rudy2Aundefined
                    Rudy2A @ziggymanpopo
                    @ziggymanpopo Late response due to my work ... Thank you for sharing, I admit that your technique has already turned in my head!
