Won't print full radius
I can't get the delta (FLSun Q5) to print to the full edges of the bed. I have tried resetting the parameters in M565 but the printer still won't do that although I can override with M564 and there is no physical problem with reaching the max. It will print in only the center 104mm max radius and not go to the 200mm potential. Here is my latest:
M665 R105 L215 B100 H200 ; Set delta radius, diagonal rod length, printable radius and homed height
Same behavior.
do you have a config-overwrite?
check for a M665 there -
Yes - the B52 would be the problem, but how do I change that or redo it?
M665 L215.000:215.000:215.000 R106.339 H220.556 B52.0 X0.360 Y0.940 Z0.000
thats the result of the delta calibration. G32.
and saving with M501
see
https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer -
Well, there we go. I wasn't saving with M501. All fixed - thanks!!
Just to be clear, M500 saves it, M501 loads it.
@Phaedrux
my bad -
Very good to now know!
