Problem by printing xyz Cube
  • Hi
    I habe calibrate my Ender 5,e-steps etc.
    Now i print the xyz Cube and i got Strange overhangs at all Corners.
    Look a the pictures:
    My simplify3d settings:
    my config.g:
    ; generated by RepRapFirmware Configuration Tool v2 on Tue May 07 2019 23:06:50 GMT+0100 (British Summer Time)
    G90                                      ; Send absolute coordinates...
    M83                                      ; ...but relative extruder moves
    M550 P"Ender 5"                          ; Set machine name
    M552 S1                                  ; Enable network
    M586 P0 S1                               ; Enable HTTP
    M586 P1 S0                               ; Disable FTP
    M586 P2 S0                               ; Disable Telnet
    M569 P0 S1                               ; Physical drive 0 goes forwards
    M569 P1 S1                               ; Physical drive 1 goes forwards
    M569 P2 S0                               ; Physical drive 2 goes backwards
    M569 P3 S0                               ; Physical drive 3 goes forwards
    M584 X0 Y1 Z2 E3                               ; set drive mapping
    M350 E128 I0                                   ; configure microstepping without interpolation
    M350 X16 Y16 Z16 I1                        ; configure microstepping with interpolation
    M92 X80.00 Y80.00 Z800.00 E3320.00              ; set steps per mm
    M566 X1200.00 Y1200.00 Z24.00 E3000.00            ; set maximum instantaneous speed changes (mm/min)
    M203 X9000.00 Y9000.00 Z180.00 E6000.00       ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z100.00 E1000.00          ; set accelerations (mm/s^2)
    M906 X800 Y800 Z800 E1000 I30                   ; set motor currents (mA) and motor idle factor in per cent
    M84 S30                                  ; Set idle timeout
    M208 X0 Y0 Z0 S1                         ; Set axis minima
    M208 X220 Y220 Z300 S0                   ; Set axis maxima
    M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
    M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
    ;M574 Z1 S1 P"zstop"                            ; configure active-high endstop for low end on Z via pin zstop
    M574 Z0                                     ; configure Z-probe endstop for low end on Z
    M950 S0 C"exp.heater7"                         ; create servo pin 0 for BLTouch
    M558 P9 C"^zprobe.in" H5 F100 T2000            ; set Z probe type to bltouch and the dive height + speeds
    G31 X41.2 Y4.5 Z1.010 P25                   ; set Z probe trigger value, offset and trigger height
    M557 X41.2:221.2 Y4.5:219.5 S20                       ; define mesh grid
    M671 X28.8:198.8:198:28.8 Y24:24:194:194
    M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
    M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
    M140 H0                                        ; map heated bed to heater 0
    M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
    M308 S1 P"e0temp" Y"thermistor" T100000 B3950  ; configure sensor 1 as thermistor on pin e0temp
    M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
    M307 H1 B0 S1.00
    M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
    M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
    M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
    M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
    M563 P0 D0 H1                            ; Define tool 0 S3D
    ;M563 P0 D0 H1 F0							; Für Prusa Slicer
    G10 P0 X0 Y0 Z0                          ; Set tool 0 axis offsets
    G10 P0 R0 S0                             ; Set initial tool 0 active and standby temperatures to 0C
    M572 D0 S0.04 ; Pressure Advance
    M501
  • Moderator
    That looks like some oozing on layer changes.
    Try increasing the speed of your Z axis, it's quite slow atm.
    Try
    M566 Z60
    M203 Z600
    M201 Z300
    Also look into tuning pressure advance.
    https://duet3d.dozuki.com/Wiki/Pressure_advance
  • @Phaedrux thanks a lot
    i want to set up pressure advance with the Marlin method but i dont see an option to select Bltouch ? if i insert only the z-offset it will print to high
  • @lui2004
    check that there is a G28 in the beginning of the file. thats all that is required for the bltouch if it is set up correctly
    also to rule out a setting mistake, give another slicer a go like prusaslicer.
  • @Veti ok i will try once again to define pressure advance
    i will try another slicer
  • i got my value now its 0.166
    so i insert it in my config.g like this:
    M572 D0 S0.166 ; Pressure Advance
    how can i test this now? benchy ?
  • @lui2004 said in Problem by printing xyz Cube:
    print the same thing as before
  • @Veti ok will reprint the xyz-cube
  • So i have reprinted the Cube
    It is much better but not perfect all sides have 20x20x20 almost perfect
  • the corners are round.
    grab the cold nozzle with your finger. see if you can displace it easily (we are talking about milimeters here)
  • @Veti i can Move it and its not to hard and not to easy
  • @lui2004
    sorry forgot to add, while the motors are energized?
    check the eccentric nuts. the there should be no play, but also the wheels should move easily.
    also the belt tension should be like a bass string when you pluck it.
  • @Veti no,with power off.
    I will test it later
    Thanks a lot for your pacience
  • @Veti i have checked all belt tension x and y and the accentric nut has no play.
    i print the cube again and post the results
    other strange is S3D show me the exact,what i am print
    here a screenshot:
  • @lui2004
    as i dont have s3d, why dont you give prusaslicer or cura a go?
    lately i have switch from cura to prusaslicer, as its gotten really good.
  • @lui2004
    Those are the retractions, maybe trying increasing the length? Ender 5 is a bowden setup right?
  • yeah i think after i print the cube
    i will try the alpha prusa slicer ,i heard its much better now
  • @Rushmere3D i have install as DD
  • @lui2004 Oh OK, I'd suggest trying at least 0.8mm up to 1mm and maybe reduce the retraction speed to 45mm/s.
  • Moderator
    for tuning the seam it's usually best to force it to a single spot. But it really depends on the model you're printing. If the model has a lot of details and inner corners the slicer can hide the seam a lot easier. On cubes and cylinders it only has external faces to put them where they are obvious. Try printing a more complex model. Your cube looks good. Move on to a benchy or something.
  • I have order a new Nozzle ( Plated Wear Resistant All Metal MK8 ), now i am waiting for to test.
    i will inform you here 👍
  • @lui2004
    what material are you printing that requires that?
