    Unipolar/bipolar steppers.
    1956
    • Deluxe 600
      Deluxe 600 last edited by
      Hello i have quite a problem here. I ordered 6 steppers from aliexpress. but when they came i discovered 4 of these are bipolar and 2 are unipolar.
      Now my question is, is it possible to make the board work with 4 unipolar and 2 bipolar steppers? Thank you and have a nice day.
        If your unipolar motors have 6 wires (not 5) then you can use them as bipolar motors by leaving the two centre tap connections not connected. However, unipolar motors are often designed to run at higher voltages than typical bipolar motors, and that may make them unsuitable.
        • Deluxe 600
          Hello thanks for fast responce. Sorry let me be more specific . I have two 6 wire 1.6amp unipolar motors (17HS4401) i was unable to find the voltage ratings. And four 4 wires 2.5amp bipolar motors (42BYGHW811B). My question is , can i use all of these 6 motors (2 of the unipolar in paralel for Z axis) on one board? OR am i screwed? Because i cant imagine trying to return something to China. Thank you very much and have a nice day.
          • Deluxe 600
            Forgot to add that the 42BYGHW811B bipolar motor has a rate volatage of 3.1volts.
              Yes you should be able to use all of those motors.
              • Deluxe 600
                Well i finally got to trying out the unipolar motors. I cant seem to make them work. Do i have to change something in the software side of things to make it work? So far the steppers just shake in one place.
                Thank you for help
                  @Deluxe:
                  Thank you for help
                  That usually means the phases are not connected in the correct pairs. How have you connected them to the Duet?
                  • Deluxe 600
                    Well i did it the same way as with the other bipolar steppers. But whatever combination i use doesnt seem to work.
                    • Deluxe 600
                      And they worked fine. But the unipolar doesnt strangely. I have no experience with unipolars, i bought it by mistake but cant return it.
                      • Dougal1957
                        Dougal1957 last edited by
                        this may help
                        https://www.circuitspecialists.com/blog/unipolar-stepper-motor-vs-bipolar-stepper-motors/
                          @Deluxe:
                          Well i did it the same way as with the other bipolar steppers. But whatever combination i use doesn't seem to work.
                          You haven't answered the question in a way that gives me enough information to make a suggestions. What I need is:
                          1. A link to the motor datasheet;
                          2. A photo of how you have connected them, or at least a description of the order in which you have connected the wires to the Duet's connector (assuming that the wires come straight from the motor, not from a connector on the motor).
                          • Deluxe 600
                            Hello.
                            1.This is the link to the motors datasheet : https://www.ebay.com/itm/wantai-1pc-Nema17-Stepper-Motor-70OZ-IN-2-5A-42BYGHW811B-Dual-shaft-worldwide-/222067054625
                            2.I dont know how to add a photo but i did the wiring the same way as here: http://reprap.org/mediawiki/images/thumb/d/d7/Duet_0.8.5_Duex4_wiring_0.2.svg/640px-Duet_0.8.5_Duex4_wiring_0.2.svg.png
                            Motor just shakes in place but doesnt move.
                              The eBay link you gave is to a bipolar stepper motor, but you said that the problem you are having is with a unipolar motor.
                              • Deluxe 600
                                Yeah i was mistaken. I did think it was unipolar, does that make it unusable?
                                  Bipolar stepper motors are the correct sort to use. Suggestions:
                                  • Check that you have the wires in the correct order, i.e. black and green at one end of the connector, and red and blue at the other end;
                                  • Check that the crimp connections on the connectors are good, using a multimeter if you have one;
                                  • If the above checks pass, try a different motor output in case you have a blown driver.
