    Laser not turning off
    Laser Cutters
    367
    • marvinosswaldundefined
      marvinosswald
      I've installed a cheap ebay laser controlled with pwm with the additional circuit from the pvm laser guide. When I installed it for the first time it worked as in i could cut cardboard with it.
      Now a few months later i'm trying to get it running again with Lightburn hopefully, but my Laser turns on as soon as i put the machine in laser mode with :
      M452 C"exp.heater3" R255 F5000
      and only turns off if I reset the machine, it doesn't react to any of the following:
      M5
      M3 S0
      G0
      G1 S0
      At this point i'm afraid i've fried some circuit which would explain why it's always on not so much why it turns off with the reset or stays off before i enable Laser Mode, right ?
      My Machine:
      • MPCNC burly
      • Duet Wifi 2
      • Version: 3.1.1
      Thanks in advance!
        marvinosswald
        Can't update my post anymore - sorry - so here is my config:
        My Config:
        ; generated by RepRapFirmware Configuration Tool v2.0.3 on Sun Sep 08 2019 11:43:58 GMT+0200 (Central European Summer Time)
        G90                            ; send absolute coordinates...
        M83                            ; ...but relative extruder moves
        M550 P"MPCNC"                  ; set printer name
        M552 S1                        ; enable network
        M586 P0 S1                     ; enable HTTP
        M586 P1 S0                     ; disable FTP
        M586 P2 S0                     ; disable Telnet
        M569 P0 S1                     ; physical drive 0 goes forwards
        M569 P1 S1                     ; physical drive 1 goes forwards
        M569 P2 S1                     ; physical drive 2 goes forwards
        M584 X0 Y1 Z2                  ; set drive mapping
        M350 X16 Y16 Z16 I1            ; configure microstepping with interpolation
        M92 X100.00 Y100.00 Z400.00     ; set steps per mm
        M566 X900.00 Y900.00 Z12.00    ; set maximum instantaneous speed changes (mm/min)
        M203 X6000.00 Y6000.00 Z180.00 ; set maximum speeds (mm/min)
        M201 X500.00 Y500.00 Z20.00    ; set accelerations (mm/s^2)
        M906 X1700 Y1700 Z1700 I30     ; set motor currents (mA) and motor idle factor in per cent
        M84 S30                        ; Set idle timeout
        M208 X0 Y0 Z0 S1               ; set axis minima
        M208 X579 Y578 Z150 S0         ; set axis maxima
        M574 X1 S1 P"!xstop"
        M574 Y1 S1 P"!ystop"
        M574 Z0 S1 P"!zstop"
        M558 P5 H5 F120 T3000 C"!^zprobe.in"               ; set Z probe type to switch and the dive height + speeds
        G31 P500 X0 Y0 Z19.20575                      ; set Z probe trigger value, offset and trigger height
        M557 X0:550 Y0:550 S50
        M140 H-1                       ; disable heated bed
        M307 H3 A-1 C-1 D-1       ; Disable Heater output on H3
        M106 P0 S0 I0 F500 H-1         ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
        ;M106 P2 S1 I0 F500 H-1
        M950 F2 C"!Fan2"
        M563 P1 S"Spindel" F0               ; define tool 0
        G10 P1 X0 Y0 Z0                ; set tool 0 axis offsets
        G10 P1 R0 S0                   ; set initial tool 0 active and standby temperatures to 0C
        M453 C"fan0" R6000 T1 ; CNC MODE
        T1                             ; select first tool
        M106 P0 I-1
          jay_s_uk @marvinosswald
          @marvinosswald if you sent M3 S255 does it turn off?
          marvinosswaldundefined 1 Reply Last reply Reply Quote 0
            marvinosswald @jay_s_uk
            @jay_s_uk it actually does, sorry forget to mention that.
              @marvinosswald invert your pin then using !
              only issue i can see though is it will probably briefly turn on until the firmware boots
              marvinosswaldundefined 1 Reply Last reply Reply Quote 1
                @jay_s_uk i'll try that tonight, thanks alot. i'll report back.
                  If it use to work but doesn't any more, most likely the 74HCT02 chip on the converter board you made is fried. If you mounted it in an IC socket, you can easily replace it.
                    marvinosswald
                    @jay_s_uk you suggestion worked, i must have figured it out at the time but never committed the "!" to my config. Thanks so much!
                    @dc42 i was afraid of that but it seems like i was lucky.
                    First cut came out decent 🙂
                    • g0rgundefined
                      g0rg
                      Where did you buy the additional circuit ? I'm in switzerland and I dont know where to buy or how to build it...
                      thank you.
                      Duet 2 wifi , Ooznest Worbee CNC 1510 , Neje Laser 20w. Ruida 100w Co2 Laser 6090. Some homemade laser cnc grbl 1515.
                      • WingedDonkeyundefined WingedDonkey referenced this topic
