    No connection to Duet-Wifi
    Firmware installation
    4.4k
    • fmaundefined
      fma
      I made a new test, and this time I get:
      09:15:28.941 : New conn on socket 0 for local port 80
      09:15:28.943 : HTTP connection accepted
      09:15:28.943 : Found responder
      09:15:28.943 : Received 404 bytes
      09:15:28.947 : Sending reply, file = yes
      09:15:28.949 : HTTP req, command words { GET / HTTP/1.1 }, parameters { }
      but still no answer… Looks like the debug info was messy.
      Could it be a hardware problem? I ask because firmware 1.18.1 was crashing... And the fact I can't load a file with M98 (I check the SD card, which is not corrupted).
      BTW, if the SD card can't be read, it could also explain why it does not answer... But firmware was correctly loaded from card! I'm puzzled.
      Frédéric
        To check that the SD card can be read, run M503.
        You can also use M98 to run other macros, e.g. M98 Phomeall.g
        If the Wireshark trace is short, post it here as ascii. Otherwise put the .pcap file on a file sharing site and post a link to it.
        We know that the pre-1.19 WiFi module firmware used to crash repeatedly for a very small number of users. The same Duet would work perfectly when attached to one network but crash when connected to a different network. We never tracked this down because we couldn't reproduce it. The version 1.19 WiFi firmware is largely rewritten, uses very little of the ESP8266 Arduino core, and shifts most of the server functionality to the main processor of the Duet where we can track down any issues much more easily.
        HTH David
        • fmaundefined
          fma
          Ok, I see. pcap file is here:
          https://sys.gbiloba.org/owncloud/index.php/s/wXQK1JBNIyaoRNm
          But I'm now in troubles: I tried to totally erase the firmware, using the erase button, but I'm unable to flash it again! I tried to use bossa, a free linux tool (still waiting from Atmel web site for their soft, but I don't get any notification once registered. When things go wrong…). The strange thing is I still have /dev/ttyACM0 port, but nothing related to bossa.
          [2634139.039937] usb 5-1: New USB device found, idVendor=03eb, idProduct=6124
          [2634139.039941] usb 5-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
          [2634139.043067] cdc_acm 5-1:1.0: ttyACM0: USB ACM device
          But I'm also unable to send gcodes on this port, so I think there is no more firmware in the flash…
          Frédéric
          • fmaundefined
            fma
            Ok, I was able to flash again the firmware using Atmel tool. But it didn't fix the com problem.
            I tried to enable telnet and ftp. Only ftp works; telnet does not answer neither.
            Strange thing: after the telnet connexion, I initiate a new web connexion, and I got:
            12:39:43.153 : New conn on socket 0 for local port 23 <<<<<<<
            12:39:43.153 : HTTP connection accepted
            12:39:43.155 : Found responder
            12:39:43.155 : Received 404 bytes
            12:39:43.159 : Sending reply, file = yes
            12:39:43.162 : HTTP req, command words { GET / HTTP/1.1 }, parameters { }
            12:40:04.388 : Client disconnected on socket 0
            12:40:04.388 : Can't send anymore
            Port number seems to be wrong (I think it is only in debug message).
            Frédéric
            • fmaundefined
              fma
              Arrgglll!!!! I made a test with a windows machine, running firefox, and it works!!!
              WTF? Why firefox nor chromium does not work from my linux machine???!!???
              Frédéric
                If you get a Wireshatk trace from the Windows machine too, perhaps we be able to spot the difference.
                • fmaundefined
                  fma
                  If all my problems are related to the wifi module, it would be better for me to switch to the ethernet version.
                  Is it possible to make an exchange?
                  Frédéric
                  • fmaundefined
                    fma
                    Here is the pcap file recorded from a Windows machine:
                    https://sys.gbiloba.org/owncloud/index.php/s/DssgVCz78OtqBGq
                    Frédéric
                      @fma:
                      That will depend on the policy of whoever you purchased it from and/or consumer rights legislation in your country.
                        @fma:
                        Thanks. The traces show that your Windows PC uses an MSS of 1460 and your Linux machine uses 1452. If I set the MTU on my Windows machine to 1492 instead of 1500, this forces the MSS to 1452 as it is on your Linux machine, and I get similar connection problems. So it appears that the TCP/IP stack on the WiFi module is failing to auto-negotiate the MSS.
                        I will look into this. If all else fails, I can rebuild the TCP/IP stack using maximum MSS of 1452 instead of 1460. Meanwhile, if your Linux system allows you to use an MSS of 1460, that may work around the problem.
                          I think I found the cause: this bug in LWIP http://savannah.nongnu.org/bugs/?func=detailitem&item_id=46384. It's been fixed, so with luck we just need to update the version of LWIP we are using.
                          • fmaundefined
                            fma
                            That's great news!
                            Do you think this can also be the source of crashs with the 1.18 and previous firmwares, where code is entirely managed by the ESP? If you apply the patch in this branch too, I can make some tests…
                            Thanks for your support.
                            Frédéric
                            • fmaundefined
                              fma
                              I will also see if I can use a MTU of 1500, instead of 1492 (I think I reduced it to handle ssh connexions, but I'm not sure if I need it anymore, as I changed my router, and OpenWRT version).
                              Frédéric
                                Please try this preview of DuetWiFiServer 1.19beta10: https://dl.dropboxusercontent.com/u/19369680/DuetWiFiServer.bin. If you don't have networking functional at present, you will need to copy the file into /sys on your SD card, put the SD card back in the Duet, restart the Duet, and run M997 S1 from USB or PanelDue. Then wait until the blue light on the wifi module stops flashing.
                                My windows machine now connects with an MSS of 1452.
                                I can't easily make that patch to the older version of DuetWiFiServer, because that version used a build of lwip pre-compiled by Expressif. In any case, we have no interest in going back to that version because the newer version offers a number of advantages, such as FTP and Telnet support.
                                • fmaundefined
                                  fma
                                  I test this this evening…
                                  No problem for the 1.18; it was just a suggestion.
                                  Frédéric
                                  • fmaundefined
                                    fma
                                    Ok, all works fine with a MTU 1500: I can have access to the duetwifi, and ssh connexions still work! And the test firmware you linked works fine with a MTU 1492.
                                    Good! Let's start playing with this great tool 😉
                                    Thanks again for the support.
                                    Frédéric
                                      I'm glad to have been of assistance.
