Duet 2 WIFI "Over Temperature Shutdown..."
  • Hi, I need your advice.
    I've recently bought Duet 2 WIFI and Panel Due 7i to upgrade my 3D printer.
    Everything was okay until I increased Amp from 800mA to 1.5A so that I need to increase the power of the stepping motor.
    Since I imported the new configuration, the panel is showing this message "Response Error: over temperature shutdown reported by driver(s) 0 as I attached the picture.
    So, I exchanged the motor but still the same problem. Even I returned to the original configuration, it has the same problem. It looks got damage.
    Would you help me to fix this issue?
    Best regards
    Paul!
  • Moderator
    Please post the contents of your config.g
    Also post the results of M122.
    Driver0 is your X axis? If you disconnect the motor (while the board is powered off) and leave it disconnected does it still produce the same error message?
    Does the driver chip itself get hot?
    Does there appear to be any damage to the driver chip? Can you post a photo?
  • Hi Phaedrux,
    Thank you for your reply.
    Here is the config.g file.
    [0_1604607233790_config.g](Uploading 100%)
    Yes, the driver 0 was X axis.
    I disconnect all cables from the board since the issue.
    After rewiring them again, I will test the board as your points soon and update here again.
    Thank you.
  • Moderator
    Your upload didn't finish. Please copy and paste the text.
  • Uploading keep failing.
    Here is the full text of the config file.
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Oct 23 2020 17:13:35 GMT-0400 (Eastern Daylight Time)
    M550 P"3DPrinter1" ; set printer name
    M669 K1 ; select CoreXY mode
    M551 P"Hyunu2003" ; set password
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S1 ; enable FTP
    M586 P2 S0 ; disable Telnet
    M569 P4 S1 ; physical drive 4 goes forwards
    M584 X0 Y1 Z2 E4 ; set drive mapping
    M350 X1 Y1 Z1 E4 I0 ; configure microstepping without interpolation
    M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
    M906 X1500 Y1500 Z800 E1500 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X210 Y210 Z200 S0 ; set axis maxima
    M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
    M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
    G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
    M557 X15:195 Y15:195 S20 ; define mesh grid
    M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
  • Moderator
    @obligor said in Duet 2 WIFI "Over Temperature Shutdown...":
    This is a very unusual microstepping configuration and doesn't seem to match your steps per mm settings at all.
    Why not use x16 with interpolation for all motors?
    What are your motors actually?
  • It was just a test setting for trying to understand the parameters.
    Do you think it was the reason for the issue and it will be okay if I change it to proper value?
    I really appreciate your support!
  • Moderator
    @Phaedrux said in Duet 2 WIFI "Over Temperature Shutdown...":
