    Duet Web Control 1.17 RC
    Firmware installation
    19
    47
    6.7k
    • fcwiltundefined
      fcwilt
      @deckingman:
      Ah OK. That could be useful. How did you go about setting it up? I didn't get beyond pressing the "create new filament" button and giving it a name before it threw a wobbly.
      "Wobbly" - that's awful - I think - what's a "wobbly"?
      I was getting ready to test a new install of a Diamond 3.
      I created a filament for each color I was going to use naming each according to actual filament color: RED, YELLOW, BLUE.
      Then I assigned each newly created filament to each tool.
      During testing it was nice to be sure I was selecting the correct tool since the color of the filament was displayed.
      • chrishammundefined
        chrishamm administrators
        @whosrdaddy:
        Small question:
        I have uploaded 1.17 to the printer (upgrading from 1.17RC6) and now the printer asks to reload the page.
        I can't remember seeing this dialog when I upgraded from 1.16, is this also new?
        Yes, that's sort of new. It's more convenient to test changes when the web interface reloads automatically.
        @deckingman:
        Just updated to 1.17. Saw something labelled "Filaments". Didn't know what it did so I clicked on it and got a message to the effect that filament was empty or there were no filaments or some such. Saw a button labelled create new filament so I clicked on that and was asked to give it a name. Typed PLA in the box, hit return and got the following Java script error.
        A JavaScript Error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this message:
        Message: Type Error: dateCreated is : undefined
        URL@ http://192.168.1/119/js/dwc.js
        Line: 2599:6
        Error object:{}
        Now it's completely bricked. I've cycled the power to the printer. Closed Firefox. Restarted everything but cannot connect to the printer. All I get is the JavaScript Error above.
        What now?
        Thanks for your report, I've just fixed this problem in v1.17+1 - see https://github.com/chrishamm/DuetWebControl/blob/master/DuetWebControl-1.17%2B1.zip.
        The web interface had a problem with filament directories that did not have a valid "last modified" attribute, but it should be fixed now.
        Using the new Filaments feature you can automate your filament load+unload process and set the required temperatures, fan values etc. in the load+unload macros. They can be edited by right-clicking on the items of the Filaments page.
        Duet software engineer
        • Whitewolfundefined
          Whitewolf
          @chrishamm:
          @whosrdaddy:
          Small question:
          @deckingman:
          Line: 2599:6
          Error object:{}
          What now?
          Nice, cant wait to finish building my wifes new craft studio so i can get back to the printer and try it out.
          Any chance the upload button got fixed to filter out stl files?
          Exploring the universe wherever the tech blows
          • deckingmanundefined
            deckingman
            @chrishamm:
            Hi Chris,
            I'm pleased to report that it works fine now. I'd also like to say thank you for this feature which will be useful with my Diamond hot end.
            This is probably too complicated but it would be kind of nice if I could assign multiple filaments to tools that use multiple extruders. e.g. if I had Tool defined which used two extruders, then it would be nice if I could show both the filaments (colours) that were assigned to it. As I understand it, I can only assign single filaments to single extruder tools. As I said, it would be nice to have but no bg deal if it's too complicated to do.
            I have another little glitch to report to you I'm afraid. When I used the system editor to edit my config.g to create a virtual heater using M305 and give it a name, after saving config.g and rebooting Duet, DWC failed to connect and I got the following JavaScript Error…..........
            Meesage: TypeError: lastStatusResponse.temps.extra "square bracket,i,square bracket" is undefined (had to type that long hand otherwise it looks like a single italic)
            URL: http://192.168.1.119/js/dwc.js
            Line: 1079:1
            Error object:{}
            This only happens once. That is to say, after receiving the message I hit "Connect" and everything is fine again and the virtual heater shows up in the "Extra" tab as expected.
              deckingman
              @fcwilt:
              Yes, sorry. You need to be a native English speaker to know what that means. It's usually applied to people. I don't know if you are married but if you are and you do something that really upsets your wife, she'd likely start shouting and waving her arms about - that's throwing a wobbly.
                @deckingman:
                @chrishamm:
                Hi Chris,
                Line: 1079:1
                Error object:{}
                Thanks, I found the bug and will fix it in my next release.
                At the moment filaments are mapped per extruder drive, so you will be able to use filament counters etc. (of course as soon as that is implemented in the firmware) with your diamond hotend as well. However for the load+unload macros it really makes sense to run them in the context of a single extruder drive, so you will have to define individual tools per extruder drive to load+unload different materials.
                  deckingman
                  @chrishamm:
                  Yes, that all makes perfect sense. Thanks again for what you've done so far - my interface is looking so much neater now that I don't have to use dummy tools to display the temperatures of various thermistors that I have stuck in various places around the printer.
                  • DjDemonDundefined
                    DjDemonD
                    Have we got an answer on whether the latest DWC can be installed via DWC or is it a case of remove memory card and install it manually?
                    www.precisionpiezo.co.uk
                      DJDemonD if you're referring to the Duet WiFi: Yes, see my earlier post:
                      @chrishamm:
                      @Guyaros:
                      What's the best method to update to the new DWC version ?
                      Older DWC versions may complain about DuetWebControl*.zip being incompatible with the Duet WiFi. Hence I suggest to rename the ZIP archive to DWC.zip and to upload it once more. That should work.
                      Otherwise just upload the entire ZIP file on the Settings page.
                      • DjDemonDundefined
                        DjDemonD
                        Thanks. Renamed to DWC.zip and it uploaded straightaway, hit refresh and its all good.
                        • joestefanoundefined
                          joestefano
                          Can someone provide a step by step for creating filaments and assigning them to tools? I was able to create a PLA and ABS but cant figure out how to assign to a tool. I am using Duetwifi with the latest version of DWC and Firmware.
                            deckingman
                            @joestefano:
                            +1
                            I'd like to know this too please.
                            • nikkerundefined
                              nikker
                              Tried to grab the lastest zip and extract to /www on the flash card but when connecting to the web interface i get this error
                              A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
                              Message: Uncaught ReferenceError: maxHeaters0 is not defined
                              URL: http://192.168.1.164/js/dwc.js
                              Line: 1006:115
                              Error object: {}
                              Edit: Should have done some more research, updated to the latest edge wifiserver and wififirmware and all works
                              • kazolarundefined
                                kazolar
                                I have 4 extruders configured and I only see Fan1 in the Fans section of DWC, can other fans be added there? Technically Fan1 corresponds to Fan0 – so presumably you'd see Fan0,Fan2,Fan4,Fan6?
                                  @kazolar:
                                  DWC supports 3 fans at the moment. You can toggle their visibility on the settings page.
                                    deckingman
                                    @chrishamm.
                                    Chris,
                                    Have you seen this thread that I started ? https://www.duet3d.com/forum/thread.php?id=2094
                                    I wasn't sure if it was firmware or DWC so I didn't post the issue in this thread. It seems now that it is DWC related.
                                      deckingman
                                      Another little thing. DWC disconnects after what seems to be a period of inactivity - reason timeout. Is it supposed to?
                                        joestefano
                                        @joestefano:
                                        Anyone know how to do this? Is there any documentation? Is it a firmware/config thing?
                                        • fcwiltundefined
                                          fcwilt
                                          @joestefano:
                                          @joestefano:
                                          There is a down arrow next to each Tool. Click on that and you will see "Load Filament".
                                          If you select that you will be shown a list of possible Filaments to choose from.
                                          If a Filament is already loaded to the Tool when you click the down arrow you will see options to "Change Filament" or "Unload Filament".
                                          • Zesty_Lykleundefined
                                            Zesty_Lykle
                                            You know, every time I come to this forum I am struck by 2 things.
                                            1 The incredible amount of knowledge and sharing that goes on here.
                                            2 The enormous amount of support offered by Tony, Chris and DC.
                                            As for the new DWC, thank you for a great job.
                                            Oh, and I would like to be able to control my sliders with more accuracy as well.
                                            Lykle
                                            Design, make and enjoy life
                                            Co Creator of the Zesty Nimble
