    Reset during print Part 2 - Duet 3.1.1 / 3.2beta3 - Duet3+SBC
    Beta Firmware
    1.7k
    • Viaundefined
      Via @chrishamm
      @chrishamm apologies, didn't notice 3.2beta3.2 update until I posted this.
      I have now updated to this and now for something different... Print got a lot further than previously (Layer 21) and then just froze, this time board did not reboot.
      Full syslog at the time
      Nov 15 17:42:57 duet3 DuetWebServer[523]: #033[40m#033[1m#033[33mwarn#033[39m#033[22m#033[49m: Microsoft.AspNetCore.Server.Kestrel[22]
      Nov 15 17:42:59 duet3 DuetWebServer[523]:       Heartbeat took longer than "00:00:01" at "11/15/2020 17:42:00 +00:00". This could be caused by thread pool starvation.
      Nov 15 17:43:53 duet3 DuetControlServer[434]: [info] System time has been changed
      Nov 15 17:44:48 duet3 DuetWebServer[523]: #033[40m#033[1m#033[33mwarn#033[39m#033[22m#033[49m: Microsoft.AspNetCore.Server.Kestrel[22]
      Nov 15 17:44:57 duet3 DuetWebServer[523]:       Heartbeat took longer than "00:00:01" at "11/15/2020 17:44:34 +00:00". This could be caused by thread pool starvation.
      Nov 15 17:45:32 duet3 DuetWebServer[523]: #033[40m#033[1m#033[33mwarn#033[39m#033[22m#033[49m: Microsoft.AspNetCore.Server.Kestrel[22]
      Nov 15 17:45:41 duet3 DuetWebServer[523]:       Heartbeat took longer than "00:00:01" at "11/15/2020 17:45:16 +00:00". This could be caused by thread pool starvation.
      Screen attached to pi has frozen and web connection sits on "Connecting".
      Left while writing this post (to save filament waste I am using a modified version now with temps set to 0 so it goes through the motions without actually printing) and after a while it suddenly restarted printing.
      Looking at logs (extrusion warning because of zeroed temps) it did last print move at 17:42:55 and then two at 17:45:53 and 17:45:58 (did think I heard it move but when I went to check display was still frozen so thought I imagined it) and then started reprinting fully (and still continuing now 10 mins later) at 17:51:01
      The DCS section has nothing (other than the restarting transfer shortly before) - tool not driven warnings removed from all logs for clarity.
      Nov 15 17:41:42 duet3 DuetControlServer[434]: [warn] Restarting transfer because a bad data response was received (0x00000005)
      Nov 15 17:41:51 duet3 DuetControlServer[434]: [warn] Restarting transfer because a bad header response was received (0x0003015f)
      Nov 15 17:42:54 duet3 DuetControlServer[434]: [info] System time has been changed
      Nov 15 17:45:51 duet3 DuetControlServer[434]: [info] System time has been changed
      Nov 15 17:45:52 duet3 DuetControlServer[434]: [info] System time has been changed
      Nov 15 17:46:46 duet3 DuetControlServer[434]: [info] System time has been changed
      Nov 15 17:48:03 duet3 DuetControlServer[434]: [info] System time has been changed
      Nov 15 17:50:52 duet3 DuetControlServer[434]: [info] System time has been changed
      EDIT: M122 taken shortly after it restarted printing...
      RepRapFirmware for Duet 3 MB6HC version 3.2-beta3.2 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
      Board ID: 08DJM-956L2-G43S4-6J9FA-3S86T-1B5LD
      Used output buffers: 1 of 40 (12 max)
      Static ram: 122236
      Dynamic ram: 139232 of which 64 recycled
      Never used RAM 130660, free system stack 126 words
      Tasks: Linux(ready,67) HEAT(blocked,296) CanReceiv(blocked,948) CanSender(blocked,352) CanClock(blocked,352) TMC(blocked,20) MAIN(running,1073) IDLE(ready,19)
      Owned mutexes: HTTP(MAIN)
      Last reset 01:44:39 ago, cause: software
      Last software reset at 2020-11-15 16:13, reason: User, GCodes spinning, available RAM 130700, slot 0
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0xffffffff Task Linu
      Error status: 0x00
      MCU temperature: min 30.7, current 32.5, max 33.3
      Supply voltage: min 12.9, current 13.0, max 13.1, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 11.9, current 12.0, max 12.1, under voltage events: 0
      Driver 0: position 27914, ok, reads 37426, writes 19 timeouts 0, SG min/max 0/280
      Driver 1: position 6439, ok, reads 37426, writes 19 timeouts 0, SG min/max 0/545
      Driver 2: position 1480, standstill, reads 37438, writes 7 timeouts 0, SG min/max 0/317
      Driver 3: position 0, standstill, reads 37439, writes 7 timeouts 0, SG min/max 0/332
      Driver 4: position 0, standstill, reads 37427, writes 19 timeouts 0, SG min/max not available
      Driver 5: position 0, standstill, reads 37446, writes 0 timeouts 0, SG min/max not available
      Date/time: 2020-11-15 17:57:40
      Slowest loop: 243.63ms; fastest: 0.09ms
      === Storage ===
      Free file entries: 10
      Hiccups: 0(0), FreeDm: 372, MinFreeDm: 339, MaxWait: 249818ms
      === MainDDARing ===
      Scheduled moves 18341, completed moves 18327, StepErrors 0, LaErrors 0, Underruns [0, 0, 28], CDDA state 3
      === AuxDDARing ===
      Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      Segments left: 1
      Movement lock held by null
      Telnet is idle in state(s) 0
      File* is doing "G0 F7200 X82.716003 Y80.648003" in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue* is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === CAN ===
      Messages sent 24971, send timeouts 24971, longest wait 0ms for type 0, free CAN buffers 47
      === SBC interface ===
      State: 0, failed transfers: 2
      Last transfer: 23ms ago
      RX/TX seq numbers: 52632/53918
      SPI underruns 1, overruns 1
      Number of disconnects: 8, IAP RAM available 0x20a30
      Buffer RX/TX: 1168/1704-0
      === Duet Control Server ===
      Duet Control Server v3.2.0-beta3
      File:
      Buffered code: G0 X152.632 Y162.681
      Buffered code: G0 X152.632 Y162.84
      Buffered code: G1 F4800 X174.699 Y80.486 E2.1268
      Buffered code: G0 F7200 X174.463 Y80.487
      Buffered code: G1 F4800 X214.597 Y120.621 E1.41584
      Buffered code: G0 F7200 X214.599 Y120.621
      Buffered code: G1 F4800 X221.858 Y118.676 E0.18746
      Buffered code: G0 F7200 X221.858 Y117.7
      Buffered code: G1 F4800 X184.646 Y80.487 E1.31277
      Buffered code: G1 X184.54 Y80.381
      Buffered code: G0 F7200 X184.54 Y80.648
      Buffered code: G0 X185.88 Y80.648
      Buffered code: G0 X185.88 Y80.485
      Buffered code: G1 F4800 X163.813 Y162.84 E2.12682
      Buffered code: G1 X163.775 Y162.984
      Buffered code: G0 F7200 X163.775 Y162.681
      Buffered code: G0 X165.175 Y162.681
      Buffered code: G0 X165.175 Y162.84
      Buffered code: G1 F4800 X82.822 Y80.487 E2.90522
      Buffered code: G1 X82.716 Y80.381
      Buffered code: G0 F7200 X82.716 Y80.648
      Buffered code: G0 X81.524 Y80.648
      Buffered code: G0 X81.524 Y80.486
      Buffered code: G1 F4800 X59.457 Y162.84 E2.1268
      Buffered code: G0 F7200 X59.457 Y162.681
      Buffered code: G0 X58.26 Y162.681
      Buffered code: G0 X58.26 Y162.84
      Buffered code: G1 F4800 X58.139 Y162.719 E0.00427
      Buffered code: G0 F7200 X58.139 Y162.544
      Buffered code: G1 F4800 X213.707 Y120.86 E4.01755
      Buffered code: G1 X213.851 Y120.822
      Buffered code: G0 F7200 X213.78 Y120.656
      ==> 1496 bytes
      Code buffer space: 2392
      Configured SPI speed: 8000000 Hz
      Full transfers per second: 29.52
      File /opt/dsf/sd/gcodes/[PLA] CFFFP_Top - zero temps.gcode is selected, processing
      • Viaundefined
        Via
        Sorry for double posting but an update...
        Print is still continuing (almost complete now judging by movements) however rpi gui is totally frozen still (mouse pointer not even moving).
        Remote web panel working fine however print status shows as 100% complete on layer 21 (where it froze) status box at top shows busy and is updating correctly though with tool position (have also reloaded page).
        • chrishammundefined
          chrishamm administrators
          If DCS reports many "system time has changed" messages then its internal update task stalled longer than 5 seconds every time. I suspect the underlying problem may be related to the DWS error messages, too, but TBH I have never observed those messages yet.
          I noticed bad SD card performance may cause lags and if yours is damaged, those kinds of problems could be expected. I suggest you rewrite the latest DuetPi version to your board, update everything, and then change once again to the unstable branch. Please use the official Raspberry Pi Imager this time and let it verify the written content. When you start this tool, you can select custom third-party images at the bottom of the distro selection and then select the corresponding DuetPi img file.
          If the same problem persists, maybe leave htop running in a console in the background after a fresh start and check if a process is taking an excessive amount of CPU or RAM.
          Duet software engineer
          • dhusoloundefined
            dhusolo
            Your issues seem similar to mine. I was getting a few different errors
            Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
            Connection interrupted, attempting to reconnect...
            DCS has been stopped
            Warning: Lost connection to Duet (Board is not available (no data response))
            11/6/2020, 5:21:16 PM	Cancelled printing file 0:/gcodes/a1.gcode, print time was 0h 19m
            11/6/2020, 5:21:15 PM	Warning: Controller has been reset
            Removing the pi fixed the issue so I'm waiting until the communication issues are resolved before going back to the SPC
            https://forum.duet3d.com/topic/19563/duet-3-sbc-dcs-has-stopped/
            Viaundefined 1 Reply Last reply Reply Quote 0
            • Viaundefined
              Via
              @chrishamm that was with the fresh install on a new (Sandisk Ultra) memory card. But I have redone to double check as previously did use Rufus to write. I have used RPi imager this time and verified. All updates done and rebooted, M997 done to confirm all updates OK and shown running 3.2beta3.2.
              And this time back to reset ~1hr into print.
              Kept a casual eye on htop during print, chromium did sit fairly high on CPU usage averaging ~55% but spiking as high as 98% this is without any plugins installed (did have Visualizer on previous) and only window open on gui is standard DWC.
              Nothing telling on syslog (added M302 P1 to get rid of tool not driven warnings)
              Nov 16 11:21:35 duet3 systemd[1]: Started Session c5 of user pi.
              Nov 16 11:54:33 duet3 DuetControlServer[8548]: [warn] Lost connection to Duet (Board is not available (no header))
              Nov 16 11:54:54 duet3 DuetControlServer[8548]: [info] Connection to Duet established
              Nov 16 11:54:54 duet3 DuetControlServer[8548]: [warn] Controller has been reset
              Nov 16 11:54:54 duet3 DuetControlServer[8548]: [info] Starting macro file config.g on channel Trigger
              Nov 16 11:54:54 duet3 DuetControlServer[8548]: [warn] File: Out-of-order reply: 'G0/G1: insufficient axes homed'
              Nov 16 11:54:54 duet3 DuetControlServer[8548]: [error] G0/G1: insufficient axes homed
              Nov 16 11:54:54 duet3 DuetControlServer[8548]: [info] Aborted job file
              Nov 16 11:54:55 duet3 DuetControlServer[8548]: [warn] M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
              Nov 16 11:54:55 duet3 DuetControlServer[8548]: [info] Starting macro file config-override.g on channel Trigger
              Nov 16 11:54:55 duet3 DuetControlServer[8548]: [info] Finished macro file config-override.g
              Nov 16 11:54:55 duet3 DuetControlServer[8548]: [warn] M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 226C
              Nov 16 11:54:55 duet3 DuetControlServer[8548]: [info] Event logging stopped
              Nov 16 11:54:55 duet3 DuetControlServer[8548]: [info] Event logging to /opt/dsf/sd/sys/eventlog.txt started
              Nov 16 11:54:55 duet3 DuetControlServer[8548]: [info] Finished macro file config.g
              M122
              Used output buffers: 1 of 40 (10 max)
              Static ram: 122236
              Dynamic ram: 139232 of which 24 recycled
              Never used RAM 130700, free system stack 200 words
              Tasks: Linux(ready,81) HEAT(blocked,297) CanReceiv(blocked,948) CanSender(blocked,371) CanClock(blocked,354) TMC(blocked,54) MAIN(running,1217) IDLE(ready,19)
              Last reset 00:02:40 ago, cause: watchdog
              Last software reset at 2020-11-15 23:19, reason: User, GCodes spinning, available RAM 130660, slot 2
              Error status: 0x00
              MCU temperature: min 35.0, current 36.8, max 36.9
              Supply voltage: min 13.0, current 13.0, max 13.1, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0
              Driver 0: position 0, standstill, reads 890, writes 14 timeouts 0, SG min/max 0/0
              Driver 1: position 0, standstill, reads 891, writes 14 timeouts 0, SG min/max 0/0
              Driver 2: position 0, standstill, reads 891, writes 14 timeouts 0, SG min/max 0/0
              Driver 3: position 0, standstill, reads 892, writes 14 timeouts 0, SG min/max 0/0
              Driver 4: position 0, standstill, reads 893, writes 14 timeouts 0, SG min/max 0/0
              Driver 5: position 0, standstill, reads 897, writes 11 timeouts 0, SG min/max 0/0
              Date/time: 2020-11-16 11:57:34
              Slowest loop: 0.92ms; fastest: 0.10ms
              === Storage ===
              Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
              === MainDDARing ===
              === AuxDDARing ===
              Segments left: 0
              File* is idle in state(s) 0
              Queue is idle in state(s) 0
              === CAN ===
              Messages sent 640, send timeouts 640, longest wait 0ms for type 0, free CAN buffers 47
              State: 0, failed transfers: 0
              Last transfer: 20ms ago
              RX/TX seq numbers: 61520/5305
              SPI underruns 0, overruns 0
              Number of disconnects: 0, IAP RAM available 0x20a30
              Buffer RX/TX: 0/0-0
              Code buffer space: 4096
              Full transfers per second: 2.79
              • Viaundefined
                Via @dhusolo
                @dhusolo Just had a look through your thread, looks like that will be the way to go for now which is a shame as whole design of this printer is around the SBC and display design. Did you have any issues going over to standalone? I did try to do that a few days back but having problems getting board to start in standalone mode, most likely not got SD card right as my board only had the old duetpi image (but will do seperate thread on that later if I still have issues).
                I am just redoing print now with debug mode as advised in that thread to see if it gives any further insight.
                dhusoloundefined 1 Reply Last reply Reply Quote 0
                  @Via Can you please share your G-code file? The other thread is not related to this issue and that one is likely fixed in the latest beta. Your M122 excerpt reveals that the Duet had an unexpected watchdog reset and it would really help if we manage to reproduce this.
                  • Viaundefined
                    Via @chrishamm
                    @chrishamm original and zero temps version:
                    [PLA] CFFFP_Top - ReRender.gcode
                    [PLA] CFFFP_Top - ReRender - zero temps.gcode
                    Print using debug just stopped, attached is everything in scrollback buffer. Failure part below.
                    failed print debug log.txt
                    [debug] Waiting for finish of G1 F4800 X221.859 Y142.854 E0.51614
                    [debug] File: Sent G1 F4800 X215.386 Y162.84 E2.88069, remaining space 184, needed 56
                    [debug] File: Sent G0 F7200 X215.386 Y162.681, remaining space 136, needed 48
                    [debug] File: Sent G0 X216.503 Y162.681, remaining space 96, needed 40
                    [debug] File: Sent G0 X216.503 Y162.84, remaining space 56, needed 40
                    [debug] File: Sent G1 F4800 X221.859 Y142.854 E0.51614, remaining space 0, needed 56
                    [warn] Bad header checksum (expected 0x0000, got 0x1890)
                    [warn] Restarting transfer because the number of maximum retries has been exceeded
                    [debug] Cancelled G1 F4800 X221.859 Y142.854 E0.51614
                    [debug] Cancelled G0 X216.503 Y162.84
                    [debug] Cancelled G0 X216.503 Y162.681
                    [debug] Cancelled G0 F7200 X215.386 Y162.681
                    [debug] Cancelled G1 F4800 X215.386 Y162.84 E2.88069
                    [debug] Cancelled G0 X112.148 Y162.84
                    [debug] Cancelled G0 X112.148 Y162.681
                    [debug] Cancelled G0 F7200 X221.858 Y133.072
                    [debug] Cancelled G1 F4800 X141.964 Y162.84 E2.10885
                    [debug] Cancelled G1 F4800 X110.759 Y162.841 E2.86914
                    [debug] Cancelled G0 F7200 X215.504 Y127.32
                    [debug] Cancelled G1 X141.926 Y162.984
                    [debug] Cancelled G1 F4800 X214.831 Y127.353 E0.91645
                    [debug] Cancelled G0 F7200 X205.323 Y162.84
                    [debug] Cancelled G0 F7200 X141.926 Y162.681
                    [debug] Cancelled G1 F4800 X205.204 Y162.84 E2.88069
                    [debug] Cancelled G1 F4800 X123.417 Y81.182 E1.68581
                    [warn] File: Out-of-order reply: ''
                    [debug] Cancelled G0 X58.3 Y98.673
                    [debug] Cancelled G0 X144.11 Y162.84
                    [debug] Cancelled G0 F7200 X58.3 Y100.269
                    [debug] Cancelled G1 X58.101 Y100.269
                    [debug] Cancelled G1 F4800 X62.453 Y81.182 E2.88069
                    [debug] Cancelled G1 F4800 X58.139 Y100.125 E0.48921
                    [debug] Cancelled G0 X144.11 Y162.681
                    [debug] Cancelled G0 F7200 X63.215 Y81.182
                    [debug] Cancelled G0 F7200 X133.729 Y81.182
                    [debug] Cancelled G0 X58.139 Y98.673
                    [debug] Cancelled G1 F4800 X134.028 Y81.181 E2.10885
                    [debug] Cancelled G0 F7200 X110.615 Y162.681
                    [debug] Cancelled G1 X110.615 Y162.879
                    [debug] Cancelled G0 F7200 X123.547 Y81.182
                    [debug] Cancelled G1 F4800 X221.859 Y133.675 E0.22419
                    [info] Cancelled printing file 0:/gcodes/[PLA] CFFFP_Top - ReRender - zero temps.gcode, print time was 1h 18m
                    [debug] Requesting update of key job, seq 47 -> 48
                    [debug] Updated key job
                    • dhusoloundefined
                      dhusolo @Via
                      @Via I flashed 3.1.1 to the board with Bossa and made a new SD card config. It didn't take too long
                      • Viaundefined
                        Via
                        I've put Duet3 into standalone now, retried print using 3.1.1 and print failed again. M122 shows Memory protection fault at time of failure.
                        RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
                        Used output buffers: 1 of 40 (11 max)
                        Static ram: 154604
                        Dynamic ram: 162852 of which 44 recycled
                        Exception stack ram used: 272
                        Never used ram: 75444
                        Tasks: NETWORK(ready,364) ETHERNET(blocked,436) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1452) TMC(blocked,204) MAIN(running,4472) IDLE(ready,76)
                        Owned mutexes:
                        Last reset 00:00:47 ago, cause: software
                        Last software reset at 2020-11-18 11:53, reason: Memory protection fault, spinning module GCodes, available RAM 75108 bytes (slot 0)
                        Software reset code 0x4163 HFSR 0x00000000 CFSR 0x00000001 ICSR 0x04427804 BFAR 0x00000000 SP 0x204175c4 Task MAIN
                        Stack: 0000000a 0000000a 40070000 20417668 204176b9 00000015 00000000 0000000d 0046207b 00000052 20417630
                        Error status: 0
                        MCU temperature: min 37.2, current 37.4, max 38.0
                        12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
                        Driver 0: standstill, reads 38262, writes 14 timeouts 0, SG min/max 0/0
                        Driver 1: standstill, reads 38263, writes 14 timeouts 0, SG min/max 0/0
                        Driver 2: standstill, reads 38263, writes 14 timeouts 0, SG min/max 0/0
                        Driver 3: standstill, reads 38264, writes 14 timeouts 0, SG min/max 0/0
                        Driver 4: standstill, reads 38264, writes 14 timeouts 0, SG min/max 0/0
                        Driver 5: standstill, reads 38268, writes 11 timeouts 0, SG min/max 0/0
                        Date/time: 2020-11-18 11:54:07
                        Slowest loop: 6.14ms; fastest: 0.14ms
                        === Storage ===
                        SD card 0 detected, interface speed: 25.0MBytes/sec
                        SD card longest read time 0.8ms, write time 0.0ms, max retries 0
                        === MainDDARing ===
                        Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                        === AuxDDARing ===
                        Segments left: 0
                        HTTP is idle in state(s) 0
                        File is idle in state(s) 0
                        Trigger is idle in state(s) 0
                        === Network ===
                        Slowest loop: 9.70ms; fastest: 0.03ms
                        Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
                        HTTP sessions: 1 of 8
                        - Ethernet -
                        State: active
                        Error counts: 0 0 0 0 0
                        Socket states: 5 2 2 2 2 0 0 0
                        === CAN ===
                        Messages sent 190, longest wait 0ms for type 0
                        === Linux interface ===
                        Last transfer: 47750ms ago
                        RX/TX seq numbers: 0/1
                        Buffer RX/TX: 0/0-0
                          I've got more details about this problem, it looks like lxpanel (a program for the desktop running in the background) has a memory leak and which, at some point, causes problems with DSF. I hope this will be fixed by Raspbian soon.
                          @Via Please try out 3.2.0-b3.2 in standalone mode, the memory protection fault should be fixed in that build.
                          • Viaundefined
                            Via @chrishamm
                            @chrishamm Thanks for the update.
                            Would using the non-gui version of duetpi and forgoing connected screen work around this issue for the short term keeping SBC control?
                            Have updated standalone to 3.2.0-b3.2 and running test again now.
                              chrishamm administrators @Via
                              @Via Yes, I think so. My printer has the GUI-less variant installed (DuetPi lite), so that probably explains why I couldn't observe this problem before.
                              • Viaundefined
                                Via @chrishamm
                                @chrishamm No luck again on standalone with 3.2.0-beta3.2, this time "AssertionFailed"
                                I will have another try later with duetpi lite.
                                RepRapFirmware for Duet 3 MB6HC version 3.2-beta3.2 running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
                                Static ram: 122236
                                Dynamic ram: 168580 of which 376 recycled
                                Never used RAM 101000, free system stack 180 words
                                Tasks: NETWORK(ready,165) ETHERNET(blocked,109) HEAT(blocked,293) CanReceiv(blocked,948) CanSender(blocked,371) CanClock(blocked,358) TMC(blocked,54) MAIN(running,1111) IDLE(ready,19)
                                Owned mutexes:
                                Last reset 00:00:28 ago, cause: software
                                Last software reset at 2020-11-19 11:11, reason: AssertionFailed, GCodes spinning, available RAM 101000, slot 0
                                Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00427000 BFAR 0x00000000 SP 0x2040fd54 Task MAIN
                                Stack: 00000599 004886b0 00468ce5 00000000 ffffffff 20427700 2040e2a0 20427ab0 ffffffff 00000000 56a3ba63 a5a5a5a5 00468d9b 2040fda4 00000000 20423aa8 004664d5 20427aa0 00440cc3 00000000 20427aa4 20408001 2040fdb4 00000101 00469700 0046972e 61000000
                                Error status: 0x00
                                MCU temperature: min 37.1, current 37.8, max 38.0
                                Driver 0: position 0, standstill, reads 9148, writes 14 timeouts 0, SG min/max 0/0
                                Driver 1: position 0, standstill, reads 9149, writes 14 timeouts 0, SG min/max 0/0
                                Driver 2: position 0, standstill, reads 9151, writes 14 timeouts 0, SG min/max 0/0
                                Driver 3: position 0, standstill, reads 9152, writes 14 timeouts 0, SG min/max 0/0
                                Driver 4: position 0, standstill, reads 9153, writes 14 timeouts 0, SG min/max 0/0
                                Driver 5: position 0, standstill, reads 9157, writes 11 timeouts 0, SG min/max 0/0
                                Date/time: 2020-11-19 11:12:08
                                Slowest loop: 6.68ms; fastest: 0.21ms
                                === Storage ===
                                SD card longest read time 1.2ms, write time 0.0ms, max retries 0
                                === MainDDARing ===
                                === AuxDDARing ===
                                Segments left: 0
                                === Network ===
                                Slowest loop: 11.39ms; fastest: 0.03ms
                                - Ethernet -
                                State: active
                                === CAN ===
                                Messages sent 113, send timeouts 113, longest wait 0ms for type 0, free CAN buffers 47
                                  @Via , I will look into this later today.
                                  • Viaundefined
                                    Via @dc42
                                    @dc42 Many thanks.
                                    Is it worth trying with DuetPi Lite? Was going to try earlier but work got in the way 🙄
                                      dc42 administrators @Via
                                      @Via said in Reset during print Part 2 - Duet 3.1.1 / 3.2beta3 - Duet3+SBC:
                                      @dc42 Many thanks.
                                      I doubt it. The assertion failure looks like it was caused either by memory corruption, or possibly by a power brownout. I guess a hardware problem is also a possibility.
                                      Can you set up a macro that runs the file in simulation mode within a loop, to see if you can provoke the failure that way?
                                      Viaundefined 2 Replies Last reply Reply Quote 0
                                      • Viaundefined
                                        Via @dc42
                                        @dc42 I've ran the file as a normal simulation which completes fine.
                                        Trying to do a macro to loop it but my gcode knowledge is terrible and keep freezing the board 😞 can you point me in right direction?
                                        Was thinking this (I know never ending loops are bad in themselves but was just going to let it run until I reset it) but looks like it is just buffering all the M24s in one go how would I go about waiting for it to finish one before starting the next?
                                        M37 S1
                                        M23 "[PLA] CFFFP_Top - ReRender - zero temps.gcode"
                                        while true
                                        	M24
                                        • Viaundefined
                                          Via @dc42
                                          @dc42 Stopped overthinking it and just added the M37/M23/M24 to the end of gcode which is looping properly now.
                                          Has done ~130 loops with no issues in simulation.
                                          • Viaundefined
                                            Via
                                            Simulation loop ran for 4 1/2 hours (~380 loops) with no issues.
                                            Ripped 24V PSU out of another printer today and unplugged heaters and fans so just steppers and sensors plugged in and done another test print, again this did not complete.
                                            This time M122 back to Memory Protection Fault
                                            Used output buffers: 2 of 40 (11 max)
                                            Static ram: 122236
                                            Never used RAM 101000, free system stack 200 words
                                            Tasks: NETWORK(ready,161) ETHERNET(blocked,109) HEAT(blocked,297) CanReceiv(blocked,948) CanSender(blocked,371) CanClock(blocked,356) TMC(blocked,54) MAIN(running,1111) IDLE(ready,19)
                                            Owned mutexes:
                                            Last reset 00:00:20 ago, cause: software
                                            Last software reset at 2020-11-21 19:46, reason: MemoryProtectionFault mmarValid daccViol, Platform spinning, available RAM 101000, slot 1
                                            Software reset code 0x4160 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x00427804 BFAR 0x00038100 SP 0x2040aa78 Task TMC
                                            Stack: 00000001 2040a928 00000000 00410210 00000000 00469d0f 00415682 21000000 427a0001 3c800001 00000000 3d000001 00000000 00000000 37533333 43d697a0 00000000 41dde946 43fa0000 44a80000 2040ff38 00469d0f 00000000 40078000 20400020 00415681 0000001e
                                            Error status: 0x00
                                            MCU temperature: min 39.2, current 39.9, max 40.0
                                            Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                                            Driver 0: position 0, standstill, reads 35967, writes 14 timeouts 0, SG min/max 0/0
                                            Driver 1: position 0, standstill, reads 35968, writes 14 timeouts 0, SG min/max 0/0
                                            Driver 2: position 0, standstill, reads 35969, writes 14 timeouts 0, SG min/max 0/0
                                            Driver 3: position 0, standstill, reads 35970, writes 14 timeouts 0, SG min/max 0/0
                                            Driver 4: position 0, standstill, reads 35971, writes 14 timeouts 0, SG min/max 0/0
                                            Driver 5: position 0, standstill, reads 35975, writes 11 timeouts 0, SG min/max 0/0
                                            Date/time: 2020-11-21 19:46:54
                                            Slowest loop: 6.26ms; fastest: 0.15ms
                                            === Storage ===
                                            === MainDDARing ===
                                            === AuxDDARing ===
                                            Segments left: 0
                                            === Network ===
                                            Slowest loop: 5.46ms; fastest: 0.03ms
                                            - Ethernet -
                                            State: active
                                            === CAN ===
                                            Messages sent 82, send timeouts 82, longest wait 0ms for type 0, free CAN buffers 46
