My new large scale 3D printer Hydra
  • Hey there,
    since my project is coming to an end, I would like to share some pics of my new large scale idex printer. The print volume is 550x550x500 mm. The printer is equipped with two E3d Hemera extruders which are watercooled with a custom heatsink. That's why I call the beast HYDRA.
    The print bed consists of 4 individually adjustable aluminum plates with 230V silicone heaters and embedded high temperature magnets. Due to the separate beds, it is possible to use only one bed for small parts.
    In my printers I'm using belt drives (gun tackle) which prove to be reliable and eliminate z wobbling completely (and any noise).
    The bed of the HYRDA is moved by two belt drives (on single heatbed printers I'm using only one belt drive).
    The printer has linear rails and a housing made of 3mm steel which results in a total weight of well over 100 kg (as I mentioned a real beast).
    Here are some close-ups to the z axis and the used belt drive setup:
    And some close-ups to the Hemera extruder heads:IMG_20201109_202712.jpg
    The electronics look like this atm (I know a little bit messy 😉 😞IMG_20201109_195114.jpg
    I wanted to ask if someone already has experience with a setup like this and whether it is possible to display all the four bed in the GUI of PanelDue.
    Cheers,
    Vinz
  • Moderator
    @rabbit said in My new large scale 3D printer Hydra:
    What version of firmware are you running on Duet and PanelDue?
  • I'm running the rrf 3.2beta3 on the duet WiFi and the 3.20 on panel due.IMG_20201109_204223.jpg
    This is shown on the panel. The web interface shows all heaters correctly.
  • Moderator
    Can you post your config for the heaters?
    What heaters currently show up in Paneldue?
  • this is my heater config:
    	;BedHeaters
    		;Layout:
    			;	1	2
    			;	3	4
    		;Bed0
    			M308 S0 P"duex.e2temp" Y"thermistor" T100000 B4138                          ; configure sensor 0 as thermistor on pin  duex.e2temp
    			M950 H0 C"duex.gp1" T0                                                   	; create bed heater output on duex.gp1 and map it to sensor 0
    			M140 P0 H0        ; map heated bed to heater 0
    			M143 H0 S120                                                            	; set temperature limit for heater 0 to 120C
    			M307 H0 B0 S1.00                                                        	; disable bang-bang mode for the bed heater and set PWM limit
    		;Bed1
    			M308 S1 P"duex.e3temp" Y"thermistor" T100000 B4138                          ; configure sensor 1 as thermistor on pin  duex.e3temp
    			M950 H1 C"duex.gp2" T1                                                   	; create bed heater output on duex.gp2 and map it to sensor 1
    			M140 P1 H1        ; map heated bed to heater 1
    			M143 H1 S120                                                            	; set temperature limit for heater 1 to 120C
    			M307 H1 B0 S1.00                                                        	; disable bang-bang mode for the bed heater and set PWM limit
    		;Bed2
    			M308 S2 P"duex.e4temp" Y"thermistor" T100000 B4138                          ; configure sensor 2 as thermistor on pin  duex.e4temp
    			M950 H2 C"duex.gp3" T2                                                   	; create bed heater output on duex.gp3 and map it to sensor 2
    			M140 P2 H2        ; map heated bed to heater 2
    			M143 H2 S120                                                            	; set temperature limit for heater 2 to 120C
    			M307 H2 B0 S1.00                                                        	; disable bang-bang mode for the bed heater and set PWM limit
    		;Bed3
    			M308 S3 P"duex.e5temp" Y"thermistor" T100000 B4138                          ; configure sensor 3 as thermistor on pin  duex.e5temp
    			M950 H3 C"duex.gp4" T3                                                   	; create bed heater output on duex.gp4 and map it to sensor 3
    			M140 P3 H3        ; map heated bed to heater 3
    			M143 H3 S120                                                            	; set temperature limit for heater 3 to 120C
    			M307 H3 B0 S1.00                                                        	; disable bang-bang mode for the bed heater and set PWM limit
    	;HotendHeaters
    		;LeftHotend
    			M308 S4 P"spi.cs5" Y"rtd-max31865"                                      	; configure sensor 4 as thermocouple via CS pin spi.cs1
    			M950 H4 C"!exp.heater3" T4                                                    	; create nozzle heater output on e0heat and map it to sensor 4
    			M143 H4 S280                                                            	; set temperature limit for heater 4 to 280C
    			M307 H4 B0 S1.00                                                        	; disable bang-bang mode for heater  and set PWM limit
    		;RightHotend
    			M308 S5 P"spi.cs6" Y"rtd-max31865"                                      	; configure sensor 5 as thermocouple via CS pin spi.cs2
    			M950 H5 C"!exp.heater4" T5                                                    	; create nozzle heater output on e1heat and map it to sensor 5
    			M143 H5 S280                                                            	; set temperature limit for heater 5 to 280C
    			M307 H5 B0 S1.00                                                        	; disable bang-bang mode for heater  and set PWM limit
    and a screenshot of the webcontrol:
  • Moderator
    Thanks. Will see if @wilriker has any comment
  • Moderator
    @Phaedrux Technically it's not problem to show all bed heaters, chamber heaters and all tools - in practice though we run out of screen estate quickly. On 5" and 7" we have 7 slots and on the 4.3" it's even less with just 5 slots.
    I think about how to use the screen estate better for the next version. IMHO tools should have preference so they and at least one heated bed should always be displayed. But I could fill the remaining slots (if any) with whatever is not displayed otherwise.
  • Meanwhile the one color prints look pretty decent. Unfortunately I have ugly red blobs if I print with dual color.
    The reason for this is that the second head restore the position of the first tool after toolchange.
    I´m wondering if it´s possible to not restore the position of the first tool and move the second head directly to the next position?
  • @rabbit
    that looks exactly like one on the street. the defect make it look more real
  • Moderator
    Take a look at this thread: https://forum.duet3d.com/topic/19201/wrong-return-point-after-tool-change
