    Random board resets
    • chas2706undefined
      chas2706
      Anyone any ideas why suddenly i'm getting random board resets.
      Nothing has been changed physically on board and not upgraded firmware. Was previously running without issues.
      Running RRF 3.1.1 on duet3 with SBC.
      Here's M122:
      Dynamic ram: 163620 of which 44 recycled
      Exception stack ram used: 544
      Never used ram: 74404
      Tasks: NETWORK(ready,1972) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1420) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,2672) IDLE(ready,76)
      Owned mutexes:
      Last reset 00:10:26 ago, cause: power up
      Last software reset at 2020-11-11 16:08, reason: User, spinning module LinuxInterface, available RAM 74404 bytes (slot 3)
      Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
      Error status: 0
      MCU temperature: min 30.4, current 30.6, max 30.8
      Supply voltage: min 11.8, current 11.9, max 11.9, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 11.1, current 11.1, max 11.2, under voltage events: 0
      Driver 0: standstill, reads 2570, writes 2 timeouts 0, SG min/max not available
      Driver 1: standstill, reads 2570, writes 2 timeouts 0, SG min/max not available
      Driver 2: standstill, reads 2570, writes 2 timeouts 0, SG min/max not available
      Driver 3: standstill, reads 2570, writes 2 timeouts 0, SG min/max not available
      Driver 4: standstill, reads 2570, writes 2 timeouts 0, SG min/max not available
      Driver 5: standstill, reads 2569, writes 2 timeouts 0, SG min/max not available
      Date/time: 2020-11-11 16:21:56
      Slowest loop: 4.21ms; fastest: 0.21ms
      === Storage ===
      Free file entries: 10
      Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
      === MainDDARing ===
      Scheduled moves: 2490, completed moves: 2490, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
      === AuxDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
      Segments left: 0
      Movement lock held by null
      HTTP* is ready with "M122" in state(s) 0
      Telnet is idle in state(s) 0
      File* is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue* is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon* is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 0.47ms; fastest: 0.01ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
      HTTP sessions: 0 of 8
      • Ethernet -
        State: disabled
        Error counts: 0 0 0 0 0
        === CAN ===
        Messages sent 215, longest wait 0ms for type 0
        === Linux interface ===
        State: 0, failed transfers: 133
        Last transfer: 16ms ago
        RX/TX seq numbers: 19918/19921
        SPI underruns 378, overruns 138
        Number of disconnects: 0
        Buffer RX/TX: 0/0-0
        === Duet Control Server ===
        Duet Control Server v3.1.1
        Code buffer space: 4096
        Configured SPI speed: 8000000 Hz
        Full transfers per second: 33.01
        11/11/2020, 16:24:48 m122
        Error: Operation failed (Reason: A task was canceled.)
        11/11/2020, 16:24:28 Warning: Controller has been reset
        11/11/2020, 16:23:55 m122
        RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
        Board ID: 08DJM-956L2-G43S4-6J1F8-3SD6P-9V5QF
        Used output buffers: 1 of 40 (10 max)
        Static ram: 154604
        Owned mutexes:
        Last reset 00:09:32 ago, cause: power up
        Error status: 0
        MCU temperature: min 24.2, current 30.6, max 30.7
        Supply voltage: min 11.7, current 11.9, max 12.0, under voltage events: 0, over voltage events: 0, power good: yes
        12V rail voltage: min 11.0, current 11.1, max 11.2, under voltage events: 0
        Driver 0: standstill, reads 29922, writes 29 timeouts 0, SG min/max 0/985
        Driver 1: standstill, reads 29923, writes 29 timeouts 0, SG min/max 0/1023
        Driver 2: standstill, reads 29923, writes 29 timeouts 0, SG min/max 0/1023
        Driver 3: standstill, reads 29924, writes 29 timeouts 0, SG min/max 0/1023
        Driver 4: standstill, reads 29924, writes 29 timeouts 0, SG min/max 0/1023
        Driver 5: standstill, reads 29937, writes 17 timeouts 0, SG min/max 0/416
        Date/time: 2020-11-11 16:21:02
        Slowest loop: 5.07ms; fastest: 0.14ms
        === Storage ===
        Hiccups: 0(0), FreeDm: 375, MinFreeDm: 319, MaxWait: 173709ms
        === MainDDARing ===
        === AuxDDARing ===
        Segments left: 0
        === Network ===
        Slowest loop: 0.95ms; fastest: 0.01ms
      • Ethernet -
        State: disabled
        === CAN ===
        Messages sent 2230, longest wait 0ms for type 0
        State: 0, failed transfers: 117
        Last transfer: 17ms ago
        RX/TX seq numbers: 18141/18143
        SPI underruns 341, overruns 120
        Buffer RX/TX: 0/0-0
        Full transfers per second: 30.20
        11/11/2020, 16:23:23 Cancelled printing file 0:/gcodes/2020_CableClip_100.gcode, print time was 0h 5m
        11/11/2020, 16:23:22 Warning: Controller has been reset
        11/11/2020, 16:18:16 M32 "0:/gcodes/2020_CableClip_100.gcode"
        File 0:/gcodes/2020_CableClip_100.gcode selected for printing
        11/11/2020, 16:18:06 Height map loaded from file heightmap.csv
        11/11/2020, 16:18:06 Leadscrew adjustments made: -0.002 -0.004 0.008, points used 3, (mean, deviation) before (-0.000, 0.004) after (0.000, 0.000)
        11/11/2020, 16:18:06 Repeating calibration because deviation is too high 0.017mm
        11/11/2020, 16:18:06 Leadscrew adjustments made: 0.013 0.022 -0.029, points used 3, (mean, deviation) before (0.006, 0.017) after (-0.000, 0.000)
        11/11/2020, 16:18:06 Repeating calibration because deviation is too high 0.022mm
        11/11/2020, 16:18:06 Leadscrew adjustments made: 0.159 0.157 0.219, points used 3, (mean, deviation) before (0.173, 0.022) after (0.000, 0.000)
        11/11/2020, 16:14:58 Connection established
      The first reset was during mid-print, the rest occured within seconds of each other with the printer idle.
      Thanks in advance.
        We've seen this type of problem occasionally with Duet + SBC using the 3.1.1 firmware bundle. There have been major changes to the SBC interface in release 3.2beta3 to address this type of issue. Please try the 3.2beta3.1 release, which we expect to make available tomorrow.
        • chas2706undefined
          chas2706
          Ok thanks for the info.
          Will try when available.
