    Running 12v fans in series one pitfall to avoid
    • DjDemonD
      DjDemonD last edited by
      So when I built one machine which is 24v I had plenty of 12v fans lying about, and wired two in series as hotend cooling fans. to get 12v/fan I have noticed one small pitfall, at low speed (which I use with ABS to keep overhangs in check) only one fan runs. One obviously has lower resistance than the other so one runs and the other doesn't unless I can set them over 30% (these are 30mm sunon blower fans). As such curling edges were more of a problem with one sided cooling than with none.
      So something to watch out for. Might rewire them with a buck converter at 12v parallel until they need replacing then go for 24v fans.
      www.precisionpiezo.co.uk
      • sigxcpu
        sigxcpu last edited by
        I would say that "resistance" in a PWM controlled coil voltage/current chopper is a bit stretched.
        • Alexander Mundy
          Alexander Mundy last edited by
          These fans take so little current I would try a 1K ohm 1/4 watt resistor across each fan to even out the voltage division.
