How to use New Mcode run Multiple Mcode?
Do you realise that if you want to us a gcode that isn't supported that you can create a file called M6.g and put it in the sys folder?
You can then add whatever you want to the contents of that file and when M6 is called it will execute that file? -
It's not currently possible to pass parameters to macro files. Support for macro parameters is planned for firmware 3.3.
