Translating Duet3d into PrusaSlicer Machine limits
  • Hi,
    I've started using a fork of PrusaSlicer and I really like it, the infill and ironing settings are brilliant.
    In the slicer there is a page to define machine limits. I've mnaged to set a number of them but cant figure out how to calculate jerk.
    Can anyone help?
    (settings with the orange padlock I have changed)
    950 ; Configuration file for Duet WiFi (firmware version 3)
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Sep 05 2020 23:57:30 GMT+0100 (British Summer Time)
    M80					       	; Turns on the ATX power supply
    G90                                            	; send absolute coordinates...
    M83                                            	; ...but relative extruder moves
    M550 P"BLV MGN Cube"                           	; set printer name
    M669 K1                                        	; select CoreXY mode
    M552 S1                                        	; enable network
    M587 S"your_wifi_name" P"your_password"        	; Configure access point. You can delete this line once connected
    M586 P0 S1                                     	; enable HTTP
    M586 P1 S0                                     	; disable FTP
    M586 P2 S0                                     	; disable Telnet
    M569 P0 S0                                     	; physical drive 0 goes backwards
    M569 P1 S1                                     	; physical drive 1 goes forwards
    M569 P2 S1                                     	; physical drive 2 goes forwards
    M569 P3 S0                                     	; physical drive 3 goes backwards
    M584 X0 Y1 Z2 E3                               	; set drive mapping
    M350 X16 Y16 Z16 E16 I1                        	; configure microstepping with interpolation
    M92 X200.00 Y200.00 Z3200.00 E415.5             ; set steps per mm
    M566 X600.00 Y600.00 Z24.00 E300.00            	; set maximum instantaneous speed changes (mm/min)
    M203 X20000.00 Y20000.00 Z600.00 E2000.00      	; set maximum speeds (mm/min)
    M201 X3000.00 Y3000.00 Z100.00 E5000.00        	; set accelerations (mm/s^2)
    M906 X1200 Y1200 Z1200 E1000 I30               	; set motor currents (mA) and motor idle factor in per cent
    M84 S30                                        	; Set idle timeout
    ; Pressure advance
    ; M572 D0 S0.05
    M208 X-23 Y0 Z0 S1                            	; set axis minima
    M208 X305 Y332 Z950 S0                        	; set axis maxima
    M564 H0					       	; allow jog without homing
    M574 X1 S1 P"xstop"                            	;
    M574 Y2 S1 P"ystop"                            	;
    M574 Z1 S1 P"zstop"                            	; configure Z-probe endstop for low end on Z
    M558 P1 H5 C"^zprobe.in" H5 F250 T9000 R0.5	; set Z probe type to switch and the dive height + speeds
    G31 P500 X-2 Y-16.4 Z1.45                      	; set Z probe trigger value, offset and trigger height
    M557 X20:292 Y15:300 P7                      	; define mesh grid
    M308 S0 P"bedtemp" Y"thermistor"T100000 B3950 C0 R4700 A"Bed Temp"  	; configure sensor 0 as thermistor on pin bedtemp
    M950 H0 C"bedheat" T0                          				; create bed heater output on bedheat and map it to sensor 0
    M140 H0                                        				; map heated bed to heater 0
    M143 H0 S100                                   				; set temperature limit for heater 0 to 100C
    M307 H0 A498.2 C1435.8 D14.9 S1.00 V24.0 B0				; Set PID for heated bed values
    M308 S1 P"e0temp" Y"thermistor" T100000 B3950 C0 R4700 A"Hotend Temp"   ; configure sensor 1 as thermistor on pin e0temp
    M950 H1 C"e0heat" T1                           				; create nozzle heater output on e0heat and map it to sensor 1
    M143 H1 S260                              				; set temperature limit for heater 1
    M307 H1 A516.3 C152.5 D9.6 S1.00 V23.9 B0  				; Set PID for hotend values
    M950 F0 C"fan0" Q100                           	; create fan 0 on pin fan0 and set its frequency
    M106 P0 S0 H-1                                 	; set fan 0 value. Thermostatic control is turned off
    M950 F2 C"fan2" Q500                            ; create fan 1 on pin fan1 and set its frequency
    M106 P2 S1 H1 T45                              	; set fan 1 value. Thermostatic control is turned on
    M563 P0 D0 H1 F0                               	; define tool 0
    G10 P0 X0 Y0 Z0                                	; set tool 0 axis offsets
    G10 P0 R0 S0                                   	; set initial tool 0 active and standby temperatures to 0C
    ; Screen
    M575 P1 B57600 S1
  • @nick9one1 said in Translating Duet3d into PrusaSlicer Machine limits:
    thats jerk
    divide by 60 to get mm/s
    Even better would be to have PrusaSlicer fetch the correct values from the object model. There is already a way to tell PrusaSlicer the IP address of the Duet, for file upload purposes.
    Can anyone help?
    ; Pressure advance
    ; M572 D0 S0.05
    ; Screen
    M575 P1 B57600 S1
    Where have you find this screen ? in PrusaSlicer 2.2.0 I don't see it
  • @pipersw
    You need to be in expert mode and have Marlin selected as the firmware. It doesn't show under RepRap.
  • @Rushmere3D I don't understand why you select Marlin for a Duet, which is RepRap firmware.
    Why ?
  • @pipersw
    You'd have to ask the OP. I was just answering your question.
  • @Rushmere3D said in Translating Duet3d into PrusaSlicer Machine limits:
    i think he wants to add it to prusaslicer for reprap.
    this will allow prusaslicer to better estimate the required time.
