    Erratic fans on toolboard
    • matt3oundefined
      matt3o
      I was finally able to configure my first toolboard, connected to the duet3 through a distribution board. The duet3 also powers a raspberrypi3 b+ (with no external devices connected, I installed the "lite" image with no GUI).
      Everything seems to be working, I updated the toolboard and configured on channel 20, but the fans act a little weird.
      The hotend fan 12v is on OUT2, it's thermostatically controlled. It works as it turns on when the temp reaches 45°C but when the temperature is below that threshold it turns on and off for a second randomly.
      The object fan is on OUT1 and it's always on. I can't seem to be able to turn it off with M106.
      The relevant config bit is as follow:
      ; 1st tool
      M308 S1 P"20.temp0" Y"thermistor" T500000 B4723 C1.196220e-7 R4700 H6 L0 ; configure sensor 1 as thermistor on pin 1.temp0 (Slice)
      M950 H1 C"20.out0" T1                          ; create nozzle heater output on 1.out0 and map it to sensor 1
      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater and set PWM limit
      M143 H1 S320                                   ; set temperature limit for hotend
      M950 F0 C"20.out1" Q500                        ; create fan 0 on toolboard out1
      M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"20.out2" Q500                        ; create fan 1 on toolboard out2
      M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
      M563 P0 S"bondtech" D0 H1 F0                   ; define tool 0
      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
      I checked again and again the wiring and fan polarity and everything seems fine.
      Pretty sure I did something terribly stupid but I can't really see it.
      Ideas? Thanks!
      M122
      RepRapFirmware for Duet 3 MB6HC version 3.01-RC9 running on Duet 3 MB6HC v1.01 or later
      Board ID: 08DJM-956BA-NA3TJ-6J1FJ-3S86Q-1T96TUsed output buffers: 1 of 40 (10 max)
      Static ram: 154572
      Dynamic ram: 161792 of which 148 recycled
      Exception stack ram used: 296
      Never used ram: 76408
      Tasks: NETWORK(ready,2084) HEAT(blocked,1184) CanReceiv(suspended,3412) CanSender(suspended,1484) CanClock(blocked,1432) TMC(blocked,216) MAIN(running,4724) IDLE(ready,80)
      Owned mutexes:
      Last reset 00:14:57 ago, cause: power up
      Last software reset at 2020-11-13 16:21, reason: User, spinning module LinuxInterface, available RAM 76400 bytes (slot 0)
      Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04435000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
      Error status: 0
      Free file entries: 10
      MCU temperature: min 28.3, current 42.8, max 42.9
      Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
      Driver 0: standstill, reads 50313, writes 14 timeouts 0, SG min/max 0/0
      Driver 1: standstill, reads 50313, writes 14 timeouts 0, SG min/max 0/0
      Driver 2: standstill, reads 50314, writes 14 timeouts 0, SG min/max 0/0
      Driver 3: standstill, reads 50314, writes 14 timeouts 0, SG min/max 0/0
      Driver 4: standstill, reads 50314, writes 14 timeouts 0, SG min/max 0/0
      Driver 5: standstill, reads 50318, writes 11 timeouts 0, SG min/max 0/0
      Date/time: 2020-11-13 16:51:19
      Slowest loop: 3.73ms; fastest: 0.14ms
      Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
      === MainDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
      === AuxDDARing ===
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP* is ready with "M122" in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon* is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 1.67ms; fastest: 0.01ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
      HTTP sessions: 0 of 8
      - Ethernet -
      State: disabled
      Error counts: 0 0 0 0 0
      === CAN ===
      Messages sent 3535, longest wait 2ms for type 6011
      === Linux interface ===
      State: 0, failed transfers: 0
      Last transfer: 16ms ago
      RX/TX seq numbers: 27366/27367
      SPI underruns 0, overruns 0
      Number of disconnects: 0
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.1.1
      Code buffer space: 4096
      Configured SPI speed: 8000000 Hz
      Full transfers per second: 15.98
      M122 B20
      Diagnostics for board 20:
      Board TOOL1LC firmware 3.1.0 (2020-05-15b1)
      Never used RAM 8.6Kb, max stack 368b
      HEAT 1092 CanAsync 1460 CanRecv 1416 TMC 204 AIN 524 MAIN 2308
      Last reset 00:15:56 ago, cause: VDD brownout
      Driver 0: standstill, SG min/max 0/0, read errors 0, write errors 0, ifcount 11, reads 15683, writes 11, timeouts 1, DMA errors 0, failedOp 0x80
      Moves scheduled 0, completed 0, hiccups 0
      VIN: 24.6V
      MCU temperature: min 22.8C, current 32.2C, max 32.4C
      Ticks since heat task active 16, ADC conversions started 955747, completed 955746, timed out 0
      Last sensors broadcast 00000002 found 1 19 ticks ago
      Free CAN buffers: 36
      NVM user row b1d088a9 fffff8bb f50a098a e7a77a8a
      TSENS 000c92 GAIN 015421 OFFS 002add CAL 1f2b
        dc42 administrators @matt3o
        @matt3o said in Erratic fans on toolboard:
        Thanks, we have at least two other users reporting a similar issue. I am fairly sure that it is caused by a firmware problem. My attempts to pin it down have so far been unsuccessful, but I will get back to looking at it soon.
        matt3oundefined 1 Reply Last reply Reply Quote 0
        • matt3oundefined
          matt3o @dc42
          @dc42 thanks for swift reply. Is the issue with the other fan related to that?
