Connectors supplied?
Hello Duet-Community,
I am about to order a Duet WiFi. The thing is: in the resellers Website (FilaFarm) it isn't mentioned IF the connectors are supplied. Does someone know if they are?
Kinds Regards
Dennis a.k.a. TitanOne
The connector kit is separate
Alright, thanks. Do you have information in where it is available?
I got a set with the last board I bought but it went into a printer that was already built so if you want it let me know. I really am not going to use it.
Both Duets I own came with a set of connectors for Motors, Power supply and Endstops. You need to solder them by yourself.
We supply the boards with connector kits. Including to filafarm.
Not sure why i remembered buying them seperately… i had to go check filastruder after reading your comment
https://www.amazon.com/gp/product/B002AVVO7K/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
Order one of those. Will make the connectors so much easier to put together. Be gentle with the crimper. Don't need to squeeze too hard.
https://www.amazon.com/gp/aw/d/B014V5LUPI?psc=1
these are half the cost and work for both micro connectors and Molex connectors
Good find.
This is what we normally advise https://www.amazon.com/HT-225D-Cycle-Ratchet-Crimping-interchangeable/dp/B007JLN93S/ref=sr_1_1. Also widely available on eBay. This https://www.amazon.com/dp/B071X8PG4B looks good to.
Wish i had known about the interchangeable die set when i bought mine.
