jerky movement - mini 5+ v0.4 + SBC 3.2beta3.2
I'm getting jerky movement on fast non print travel moves.
I can hear that the movements aren't one smooth continuous run.
Here is my config.g; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Sep 22 2020 14:08:43 GMT+0100 (British Summer Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder move ; Drives M569 P0.0 S0 D3 V40 ; physical drive 0.0 goes forwards M569 P0.1 S1 D3 V40 ; physical drive 0.1 goes forwards M569 P0.2 S1 D3 V40 ; physical drive 0.2 goes forwards M569 P0.3 S0 D3 V40 ; physical drive 0.3 goes forwards M569 P0.4 S1 D3 V40 ; physical drive 0.3 goes forwards M584 X0.0 Y0.1 Z0.2:0.3 E0.4 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X100.00 Y100.00 Z400.00 E837 ; set steps per mm M566 X1000.00 Y1000.00 Z24.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min) M201 X1000.00 Y1000.00 Z200.00 E250.00 ; set accelerations (mm/s^2) M906 X1200 Y1200 Z1200 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X270 Y260 Z350 S0 ; set axis maxima M671 X-130:400 Y150:150 S10 ; Endstops M574 X1 S1 P"io1.in" M574 Y1 S1 P"io2.in" ; Z-Probe M558 P1 C"!io3.in" H2 A5 F120 T20000 S0.02 ; Set Z probe type to switch and the dive height + speeds G31 P1000 X-25 Y0 Z3.915 ; Set Z probe trigger value, offset and trigger height M557 X15:230 Y15:230 S20 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out2" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"temp1" Y"thermistor" T100000 B4276 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans ;############## Tool 0 Fans ########################## M950 F0 C"out6" Q500 ; Create fan 0 on pin out3 and set its frequency M106 P0 S0 H-1 ; Set fan 0 value. Thermostatic control is turned off M950 F1 C"out5" Q500 ; Create fan 1 on pin out4 and set its frequency M106 P1 S1 H1 T45 ; Set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ;M918 P2 ; enable ST7567-based 12864 display M150 X2 R255 U255 B255 S3 ; set all 3 LEDs to white M501 ; load saved parameters from non-volatile memory T0 ; select first tool M207 S5.0 R0.02 F2400 Z0.5 M950 P0 Q500 C"out0"
Pretty sure they weren't happening on earlier betas
Are you calling macro files from daemon.g?
no. I do not currently have a daemon.g file
Please run M122 once, then try to reproduce the jerky movement, and run M122 again once you could observe it. Then post the output here.
@chrishamm ok.
Will do that once this print finishes -
@jay_s_uk said in jerky movement - mini 5+ v0.4 + SBC 3.2beta3.2:
I can hear that the movements aren't one smooth continuous run.That's usually caused by using G29 bed compensation on an uneven bed with a low Z jerk value, especially when using a fine G29 mesh. You do have a very low Z jerk value in config.g.
@dc42 I'll try increasing the speed.
It does happen as part of homing as well and the mesh compensation shouldn't be enabled then -
If the problem persists, please run M122 before doing this type of move (to reset the variables); then run it again after observing this behaviour and post the result here.
i've increased my jerk and it seems to have gone
I think I had requested the default Z jerk speed to be increased to 60 in the next update to the config tool. That usually seems like it's enough to prevent this issue from happening. 24 is pretty low.
@Phaedrux if I get chance to look at it (or even to remember to) I'll send a pull request in the morning
@Phaedrux pull request created
https://github.com/Duet3D/ConfigTool/pull/58
@chrishamm
