Rinning???
  • What setting affect rining. ???
  • Moderator
    Usually a combination of high jerk and acceleration. But there are a few different causes of ringing artifacts. Maybe a photo? It can also be from mechanical slop, or loose belts, or belt teeth causing changes in head position.
  • ithink i loosened my belt to much you and i went thru jerk settings some time ago ive got lots to tweek i think
    thanks
  • ill run another
    16055524256431943239763652172375.jpg 16055525166761615222058927090772.jpg 16055526137978265958354214074143.jpg
  • Moderator
    What are your settings in config.g and the slicer?
    A quicker test print for ringing would be something like this
    ringtest.stl
  • Please note the rinning around prop hole by stern and by porthole on the front bow
  • K ill send shortly
  • To start i wlswitched to pla for ease
    Slicer
    Temp of 210
    Bed at 63.c but i. Suspect it runs cooler then advertised
    General slicers setings ...(mattercontrol slicer)
    Layer thicknesses 0.2
    First layer 0.35
    Perimiters 3
    Top solid 0.8
    Bottom solid 0.8
    Fil density 20%
    Retractions 1mm
    Max speed 100%
    Retraction speed 35mms
    Extrusion multiplier 1.0
    Infill 60mms.
    Inside perimiters 45mms (infill)
    Perimiters :
    Outside perimiters 30mms
    Perimiters acceleration 0%
    Default acceleration 0%
  • ; Configuration file for Duet WiFi (firmware version 1.21)
    ; generated by RepRapFirmware Configuration Tool on Thu Sep 06 2018 21:21:12 GMT-0700 (Pacific Daylight Time)
    M550 Pe3 ; Set machine name
    M552 S1 ; Enable network
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M569 P0 S0 ; Drive 0 goes forward
    M569 P3 S1
    ; Drive 3 goes backwards
    ;M569 P3 S1 ; Drive 3 (Extruder 0) goes backwards
    M350 X16 Y16 Z16 E16 ; Configure microstepping with interpolation
    ; M92 X79.7 Y320 Z400.4 E415 ; Set steps per mm
    M92 X79.2 Y320 Z400.5 E427.8 ; Set steps per mm
    M566 X1600 Y500 Z24 E300 ; Set maximum instantaneous speed changes (mm/min)
    M203 X30000 Y1600 Z300 E1500 ; Set maximum speeds (mm/min)
    M201 X1500 Y1500 Z300 E5000 ; Set accelerations (mm/s^2) is 500
    M906 x1700 Y1700 Z850 E1100 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S300 ; Set idle timeout
    ; M208 X-5.5 Y-10 Z0 S1 ; Set axis minima
    ; M208 X495 Y495 Z460 S0 ; Set axis maxima
    M208 X500 Y500 Z500 S0 ; Set axis maxima
    M574 X1 Y1 Z1 S1 ; Set endstops controlled by sw. Z control by nozzle triger sw.
    ; M558 P5 H5 F100 T2000 ; Set Z probe type to capasitive and the dive height + speeds
    M558 P5 H5 F100 T4000 ; Set Z probe type to capasitive and the dive height + speeds
    G31 P500 X-42 Y-5 Z-0.87 ; Set Z probe trigger value, offset and trigger height - is Nozzle hoger
    M557 X15:215 Y35:215 S20 ; Define mesh grid
    M143 H0 S120 ; Set temperature limit for heater 0 to 80C
    M305 P1 x501 R4700 ; Set thermistor + ADC parameters for heater 1
    M143 H1 S400 ; Set temperature limit for heater 1 to 400C
    ; M307 H1 A245.3, C121.7, D4.0, S0.5 ; PID
    ; M106 P0 S1 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
    ; M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M563 P0 D0 H1 ; Define tool 0
    M501 ;pid save to config overide
    ; Enable Bed Leveling
  • Moderator
    @ziggymanpopo said in Rinning???:
    I think it may be a combination of the large mismatch in X Y speeds and jerk.
    Try
    M566 X600 Y600 Z60 E3000 ; Set maximum instantaneous speed changes (mm/min)
    M203 X12000 Y12000 Z600 E6000 ; Set maximum speeds (mm/min)
    M201 X600 Y600 Z300 E5000 ; Set accelerations (mm/s^2) is 500
    M204 P600 T2000 ; set print and travel move accel
  • before i make those changes i thought id ask you this i installed a ball screw on the y axes its a 16/10 pitch...dose that impact it at al las far as the spread or figures
  • my bad for not sayin 😁
  • Moderator
    The settings I posted should be ok for ball screw axis as well. The rotational inertia of the ball screws may be contributing to the ringing. Either way, the settings I posted may help.
  • Thank you will reprint the benchy the the rinning stl 😁👍
    16055787789997202308994252061709.jpg 16055788150455756014100385980163.jpg 16055788380572190341681057943307.jpg 16055789240171649926039508937222.jpg 16055789907478814825783507615761.jpg
  • The x makes me think that ive got a belt issue
    I can say its prety tight and the idler bearing is smooth because thats what i could find and thought the smooth one proably would resonate less ?????
  • So much better 🙂
  • Moderator
    It's better now?
  • Yes much thank you i think i still need to play with the hotend cooling duct. Thank you what do you think about the lines. The x axes belt ?????
  • 80% maybe 90% !!😁
  • Moderator
    I would say that it's still likely mechanical in nature. Ball screw has a lot of rotational mass, so trying to get it up to speed and slow down quickly is going to be tricky.
    Try
    M566 X600 Y400 Z60 E3000 ; Set maximum instantaneous speed changes (mm/min)
    M201 X600 Y400 Z300 E5000 ; Set accelerations (mm/s^2) is 500
    M204 P500 T2000 ; set print and travel move accel
    And if the travel moves seem harsh, try reducing M204 T2000 to T1500
  • One at a time ??
  • Moderator
    All at once?
  • Done rerunning cube
