    BLTouch not working after Firmware upgrade
    356
    • itsab67undefined
      itsab67
      Hi i just upgraded my Duet Ethernet to the newest reprap firmware 3.x
      Before i was using reprap 2.x and my BLTouch worked good. I have not changed any connections. I've included my config.g and how i have the BLTouch wired, hoping someone can figure out what i did wrong. I used the reprap config tool. When I 1st turn on the printer the bltouch glows red, the probe deploys and retracts and then it sits there flashing red , it doesn't respond when i try to deploy or retract from the console and resetting the bltouch from the console doesn't help.
      Config.g
      ; generated by RepRapFirmware Configuration Tool v3.1.8 on Fri Nov 20 2020 16:34:34 GMT-0500 (Eastern Standard Time)
      M550 P"TLM" ; set printer name
      M665 R160 L437 B160 H250 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
      M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M92 X80.00 Y80.00 Z80.00 E407.63 ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X1250 Y1250 Z1250 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; set minimum Z
      M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
      M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
      M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 R155 S20 ; define mesh grid
      M143 H0 S90 ; set temperature limit for heater 0 to 90C
      M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
      M563 P0 S"Hotend" D0 H1 F0 ; define tool 0
        Did you also update your deploy and retract macros? The config tool would have generated new ones as well.
        itsab67undefined 1 Reply Last reply Reply Quote 0
        • itsab67undefined
          itsab67 @Phaedrux
          @Phaedrux yes, im using the ones that reprap config created.
            Can you post them?
            If sending M401 M402 doesn't deploy or retract either the servo pin you're using doesn't match the pin name used in M950, or the servo index needs to change to 0 to match your M950 command, which would make sense if you were still using your old files, but not if you're using the new files from the generator.
            • itsab67undefined
              itsab67 @Phaedrux
              @Phaedrux
              here they are
              ; deployprobe.g
              ; called to deploy a physical Z probe
              M280 P0 S10 ; deploy BLTouch
              ; retractprobe.g
              ; called to retract a physical Z probe
              M280 P0 S90 ; retract BLTouch
              • itsab67undefined
                itsab67
                config.json
                also this, not sure if helps you
                  Those look correct. Are you sure you're using heater3 pin? Try heater7 pin instead?
                  • itsab67undefined
                    itsab67 @Phaedrux
                    @Phaedrux
                    My friend i appreciate the time you have spent trying to help. However it appears nothing was wrong. i had a close look at the bltouch and discovered there was a string of PETG wrapped around the bltouch pin, once i removed that all works as it should. Cant believe i didn't notice that earlier.
