    Heater Monitor Setup (M143)
    • pixelpieperundefined
      pixelpieper
      Hi, I have the following configuration:
      • Mains powered silicone heater mat with an integrated thermistor
      • A second thermistor on the side of the aluminum bed
      • Duet Maestro at the current beta firmware version
      I am trying to configurethe following:
      • My board should use the bed thermistor as the control target
      • The temperature of the silicone pad shoud stay below a given temperature, lets say 120°C
      My configuration is using S0 for the silicone heater thermistor and S4 for the aluminium bed thermistor. My understanding is that I should be able to configure a monitor with M143 to limit the maximum silicone heater temperature as follows:
      ;; thermal -------------------------------------------------
      ; Sensors --------------------------------------------------
      M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 A"Bedmat"; configure sensor 0 as thermistor on pin temp0
      M308 S1 P"e0temp" Y"pt1000" A"Hotend"  ; configure sensor 1 as thermistor
      M308 S2 P"ctemp" Y"thermistor" T100000 B3950 A"Chamber"	;Chamber fan
      M308 S3 Y"mcu-temp" A"Board"
      M308 S4 P"e1temp" Y"thermistor" T100000 B3950 A"Bedplate"
      ; Heaters --------------------------------------------------
      ;Bed
      M950 H0 C"bedheat" T4                           ; create bed heater output on out0 and map it to sensor 4
      M143 H0 P1 T0 A2 S110 C0                     ; Regulate (A2) bed heater (H0) to have pad sensor (T0) below 110°C. Use Heater monitor 1 for it
      M143 H0 P2 T0 A0 S120 C0                     ; Fault (A0) bed heater (H0) if pad sensor (T0) exceeds 120°C. Use Heater monitor 2 for it
      M143 H0 P0 S110                            ; Set bed heater max temperature to 120°C, use implict monitor 0 which is implicitly configured for heater fault
      M140 H0
      However, I see the silicone pad temperature overshooting to the point that I rather turn it of by hand:
      It looks like the monitors are not working - do I miss anything here?
      Edit: M122 Output
      M122
      RepRapFirmware for Duet 2 Maestro version 3.2-beta3.2 running on Duet Maestro 1.0
      Board ID: 08DJM-9X66L-LG3SJ-6JKF2-3SJ6L-KAX6R
      Used output buffers: 3 of 24 (11 max)
      Static ram: 22780
      Dynamic ram: 97892 of which 200 recycled
      Never used RAM 9176, free system stack 218 words
      Tasks: NETWORK(ready,205) HEAT(blocked,331) TMC(blocked,71) MAIN(running,480) IDLE(ready,21)
      Owned mutexes:
      Last reset 00:00:39 ago, cause: software
      Last software reset at 2020-11-21 20:12, reason: User, GCodes spinning, available RAM 9176, slot 1
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
      Error status: 0x00
      MCU temperature: min 42.3, current 42.4, max 43.3
      Supply voltage: min 0.0, current 24.4, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 0, standstill, read errors 0, write errors 1, ifcnt 107, reads 10859, writes 8, timeouts 0, DMA errors 0
      Driver 1: position 0, standstill, read errors 0, write errors 1, ifcnt 105, reads 10858, writes 8, timeouts 0, DMA errors 0
      Driver 2: position 0, standstill, read errors 0, write errors 1, ifcnt 106, reads 10858, writes 8, timeouts 0, DMA errors 0
      Driver 3: position 0, standstill, read errors 0, write errors 1, ifcnt 101, reads 10858, writes 8, timeouts 0, DMA errors 0
      Driver 4: position 0, standstill, read errors 0, write errors 1, ifcnt 105, reads 10858, writes 8, timeouts 0, DMA errors 0
      Driver 5: position 0, standstill, read errors 0, write errors 1, ifcnt 105, reads 10858, writes 8, timeouts 0, DMA errors 0
      Driver 6: position 0, standstill, read errors 0, write errors 1, ifcnt 105, reads 10858, writes 8, timeouts 0, DMA errors 0
      Date/time: 2020-11-21 20:12:54
      Slowest loop: 25.26ms; fastest: 0.16ms
      === Storage ===
      Free file entries: 10
      SD card 0 detected, interface speed: 15.0MBytes/sec
      SD card longest read time 0.9ms, write time 0.0ms, max retries 0
      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      === MainDDARing ===
      Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Bed heaters = 0 -1, chamberHeaters = -1 -1
      Heater 0 is on, I-accum = 0.2
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 6.27ms; fastest: 0.01ms
      HTTP sessions: 1 of 8
      Interface state active, link 100Mbps full duplex
      Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
      Voron V0.250 / Duet 2 Maestro
        pixelpieper
        Nevermind, Fixed it - Problem was the order of my commands, I now moved the M140 and M307 to before the M143 definition:
        ;Bed
        M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
        M140 H0
        ;PID Settings
        M307 H0 A301.0 C845.3 D1.4 S1.00 V23.6 B0
        M307 H1 A482.6 C291.7 D5.5 S1.00 V23.6 B0 ;V6
        ; Monitors & Limits
        M143 H1 S400                                  ; set temperature limit for heater 1 to 275C
