    Having problems with the bltouch, duet 2 wifi
    822
    • A Former User?
      A Former User
      still crashing into the bed 😞
      BoAundefined 1 Reply Last reply Reply Quote 0
      • BoAundefined
        BoA @A Former User
        Is BL Touch deployed, but bed not detected? Or not deployed at all?
        Describe what and where You connected (from BLtouch).
        • A Former User?
          A Former User
          bed is not detected
          • A Former User?
            A Former User
            the bltouch is connencted to gnd and signal on probe in. and pin 1, 2 and 8 on the expansion
            Vetiundefined 1 Reply Last reply Reply Quote 0
            • Vetiundefined
              Veti @A Former User
              @remixbot
              post a picture of your wiring
                Phaedrux Moderator @A Former User
                @remixbot said in Having problems with the bltouch, duet 2 wifi:
                G1 H1 Z-205 F360 ; move Z down stopping at the endstop
                G90 ; absolute positioning
                G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                To use the probe you need to use G30 as shown by BoA in his example homing files.
                If your wiring is correct and the config uses those correct pins and it still doesn't trigger but the servo commands work, then it's likely a bad connection on the white wire, which is the trigger signal.
