    Duet 3 SBC : C# Program
    • Donpiundefined
      Donpi
      Hi everybody,
      In a other thread I asked for a way to start a fan on the Duet when the SBC is too hot.
      I received al the help I needed, thanks again.
      I am a bit low on free fan connectors, so I decided to run one only fan from the PI when the Duet or the PI are too hot. This works well to with a bash script.
      As I am prety good in C#, I want to try an other way to do it.
      Now here are my questions :
      • I read somewhere that the Duet program on the PI is writen in C#. If it's true , does it use Mono ?
      • How can I send GCODE to the Duet from c# ?
      • Are there any libraries that I can use tu get data from the Duet without GCODE ? If yes where and how can I access them ?
      Thanks
      Juan
        jay_s_uk
        Have you seen these two API's?
        One is written in golang and the other is written in python.
        https://github.com/Duet3D/DSF-APIs
        • A Former User?
          A Former User
          if you look at the DSF sources for the CodeConsole program it would probably answer the question of how to do it in C#
          as for mono, no, i think it uses dotnet core for linux; you'll find more info https://github.com/Duet3D/DuetSoftwareFramework
          Donpiundefined 1 Reply Last reply Reply Quote 0
          • Donpiundefined
            Donpi @A Former User
            @bearer Yes I found the link right after posting ( as allways 😛 )
