    Weird behavior calibrating Delta
    344
    • BigMoff96undefined
      BigMoff96
      Hi guys,
      I have been trying to tune and tweak my delta for the past week or so, and have seemed to fix most of my dumb mistakes. The only trouble I’m having right now is that when I run G32 my smart effector will not trigger at one point on the bed. It isn’t consistent, but it does happen frequently. I can run a few auto calibrations before it decides to not trigger at this one point.
      Here’s a video of what I’m talking about https://imgur.com/gallery/alxkiDI
      A little about my system
      -duet 2 wifi
      -RRF3 3.1.1
      -Delta smart effector
        BigMoff96
        Also, here’s my config.g file
        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Nov 14 2020 22:35:13 GMT-0500 (Eastern Standard Time)
        M550 P"My Printer" ; set printer name
        M665 R135 L290 B135 H350 ; Set delta radius, diagonal rod length, printable radius and homed height
        M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
        M552 S1
        M551 P"Delilah0805" ; set password
        M552 S1 ; enable network
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        M569 P0 S0 ; physical drive 0 goes backwards
        M569 P2 So ; physical drive 2 goes backwards
        M92 X80.00 Y80.00 Z80.00 E415.00 ; set steps per mm
        M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
        M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
        M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 Z0 S1 ; set minimum Z
        M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
        M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
        M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
        M558 C"zprobe.in+zprobe.mod" P8 R0.4 F1000 B1 H10 T6000 ; set Z probe type to effector and the dive height + speeds
        G31 P100 X0 Y0 Z-0.1 ; set Z probe trigger value, offset and trigger height/
        M557 R130 S10 ; define mesh grid
        M308 S0 P"bedtemp" Y"thermistor" T100000 B4388 ; configure sensor 0 as thermistor on pin bedtemp
        M307 H0 A119.6 C668.3 D23.8 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
        M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
        M307 H1 A561.1 C164.5 D4.8 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
        M143 H1 S298
        M563 P1 S"Extruder" D0 H1 F0 ; define tool 1
        G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
        G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
        M501
          BigMoff96
          And my bed.g file if it helps
          ; bed.g file for RepRapFirmware, generated by Escher3D calculator
          ; 16 points, 6 factors, probing radius: 130, probe offset (0, 0)
          G28
          G30 P0 X0.00 Y130.00 Z-99999 H0
          G30 P1 X65.00 Y112.58 Z-99999 H0
          G30 P2 X112.58 Y65.00 Z-99999 H0
          G30 P3 X130.00 Y0.00 Z-99999 H0
          G30 P4 X112.58 Y-65.00 Z-99999 H0
          G30 P5 X65.00 Y-112.58 Z-99999 H0
          G30 P6 X0.00 Y-130.00 Z-99999 H0
          G30 P7 X-65.00 Y-112.58 Z-99999 H0
          G30 P8 X-112.58 Y-65.00 Z-99999 H0
          G30 P9 X-130.00 Y-0.00 Z-99999 H0
          G30 P10 X-112.58 Y65.00 Z-99999 H0
          G30 P11 X-65.00 Y112.58 Z-99999 H0
          G30 P12 X0.00 Y65.00 Z-99999 H0
          G30 P13 X56.29 Y-32.50 Z-99999 H0
          G30 P14 X-56.29 Y-32.50 Z-99999 H0
          G30 P15 X0 Y0 Z-99999 S6
            BigMoff96
            @dc42 Im hoping you might be able to help me
            • Vetiundefined
              Veti
              maybe increase the sensitivity by just a bit.
              https://duet3d.dozuki.com/Wiki/Smart_effector_and_carriage_adapters_for_delta_printer#Section_Programming_the_sensitivity
                BigMoff96
                I had tried that. It didn’t seem to work and just made other points not trigger when running. I believe what I might have to do is go through the bed.g points and enter their individual trigger heights
                • Vetiundefined
                  Veti
                  @BigMoff96 said in Weird behavior calibrating Delta:
                  then try increasing the F value
                  and maybe the z acceleration.
                    BigMoff96
                    You think 1200 or 1500 mm/s for z acceleration?
                    • Vetiundefined
                      Veti
                      you have to test it. the idea is to increase the force with which the nozzle hits the bed.
