    5v LED light is red....?
    • jaymcd0626undefined
      jaymcd0626
      The 5v led along the side of my Duet Maestro by the reset button is red. Wondering what that means. The 3.3v is green...??
        It just means it's a different color. The important thing is that it's lit.
        Are you having any other issues indicating a problem with 5v?
          jaymcd0626
          No issue really. Just wondering why it would be red not green. Seems like it might indicate a fault...??
            Maybe just to make it easier to differentiate between them.
            Check the LEDs on the Duet. There should be a red LED illuminated between the USB connector and the Reset button. The red 5V LED at the edge of the board should also be lit, so should the green 3.3V LED. (Note: the Duet 06 doesn't have the 5V or 3.3V LED)
            If the red LEDs are lit but not the green 3.3V LED then most likely there is a short between the 3.3V power rail and ground. Disconnect the Duet from USB, then remove all endstop and Z probe connectors from the Duet. If you have a Duex 2 or Duex 5 connected as well, disconnect the ribbon cable joining them too. Then reconnect the USB cable and check the LEDs again.
            https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
            • A Former User?
              A Former User
              @Phaedrux are there maestro/duet 3 specific versions of https://duet3d.dozuki.com/Wiki/Hardware_Overview#Section_LED_indications ?
              @jaymcd0626 i think if you ignore the endstop leds the link above is the same for the maestro
                Phaedrux Moderator @A Former User
                @bearer said in 5v LED light is red....?:
                No, but there probably should be. I'll look into that.
