    New software bundle 3.2-beta4
    Beta Firmware
    131
    • chrishamm
      chrishamm administrators last edited by dc42
      On behalf of the Duet3D team I am pleased to announce the release of the next beta software bundle 3.2.0-beta4 including RepRapFirmware, DuetWebControl, and DuetSoftwareFramework. If you are using expansion boards with a Duet 3, you must upgrade the corresponding firmware as well. The new DSF packages are now available on the unstable package feed and they can be installed using sudo apt-get update and sudo apt-get upgrade.
      RRF upgrade notes: https://github.com/Duet3D/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md
      DWC upgrade notes: https://github.com/Duet3D/DuetWebControl/blob/v3.2-dev/WHATS_NEW.md
      DSF upgrade notes: https://github.com/Duet3D/DuetSoftwareFramework/blob/dev/WHATS_NEW.md
      If you experience problems, please create a new post and put [3.2-b4] in the title unless a related post already exists in the Beta Firmware category.
      EDIT: Known issue with this bundle: users of Duet 3 with attached single board computer have reported being unable to update Duet 3 expansion and tool board firmware using this firmware bundle. Workarounds: (1) update tool and expansion board firmware to 3.2beta4 before upgrading RRF and DCS; or (2) switch to standalone mode to update tool and expansion board firmware
      • PCR
        PCR last edited by
        Nice. Does anyone have a Screenshot of the prusa slicer thingi?
        chrishamm 1 Reply Last reply Reply Quote 0
        • chrishamm
          chrishamm administrators @PCR last edited by
          @PCR It isn't implemented in DWC yet but we'll add it to the job file list soon. Here an example what a thumbnail generated by PrusaSlicer looks like:
          • Olby
            Olby last edited by
            Updated using sbc without errors. But I suspect that the EXP3HC failed. Get lots of:
            Error: M569: Response timeout: CAN addr 1, req type 6018, RID=1
            and similar for all expansion board related commands.
            Olby 1 Reply Last reply Reply Quote 0
            • Olby
              Olby @Olby last edited by
              Uploaded the new firmware to the system folder using the web ui. Now i get lots of:
              Error: Firmware file Duet3Firmware_EXP3HC.bin not found
                dc42 administrators @Olby last edited by
                @Olby, is that file not present in /sys ?
                • Olby
                  Olby @dc42 last edited by Olby
                  @dc42 It is...
                  /opt/dsf/sd/sys/Duet3Firmware_EXP3HC.bin
                  -rwxrwxr-- 1 dsf  dsf  123K Nov 26 20:36 Duet3Firmware_EXP3HC.bin
                    @Olby said in New software bundle 3.2-beta4:
                    @dc42 It is...
                    One for @chrishamm I think.
                    • Olby
                      @dc42 Does it make sense to test with the sbc disconnected?
                        Yes you can try updating it in standalone mode, then reconnect the SBC once the expansion board is updated.
                        • chrishamm
                          That's odd, I did test SBC file transfers and fixed a related issue in the firmware just before the release. I'll try to reproduce and fix it but I'm afraid I won't be able to look into it before Sunday.
                          • Olby
                            Olby @chrishamm last edited by Olby
                            @chrishamm Worked fine in stand alone mode
                            Duet EXP3HC firmware version 3.2-beta4 (2020-11-26)
                            So I have no excuse to by an Atmel-ICE.
