    Fans don't works
    330
    • Ducati87undefined
      Ducati87
      Hello guys, I'm trying to setup my 3 fans (2 materiale fans and 1 for the hotend).
      I connected the two material fans to FAN1 and FANS2, while the hotend fans to FANS0.
      I have some problems:
      1. the FANS1 port is always powered on
      2. the hotend fans doesn't start when reach 50 degree
      3. the only material fan which works is FANS2.
      this is my config:
      M950 F0 C"fan0"                               ; create fan 0 on pin fan0 and set its frequency
      M106 P0 C"Hotend Fan" S0 H1 T45                    ; set fan 0 name and value. Thermostatic control is turned on
      M950 F1 C"fan1"                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 C"Material 1 Fan" S0 H-1                   ; set fan 1 name and value. Thermostatic control is turned off
      M950 F2 C"fan2"                               ; create fan 2 on pin fan2 and set its frequency
      M106 P2 C"Material 2 Fan" S0 H-1                   ; set fan 2 name and value. Thermostatic control is turned off
      M563 P0 S"hotend 0" D0 H1 F0                     ; define tool 0
      Where could be the problem?
      Thank you!
        Your tool definition only assigns fan0 to it as the part cooling fan, which isn't what you want.
        I would suggest that you connect the hotend fan to Fan1 as that is the intended port because that port will power on automatically at power up to cool the hotend in case it was power cycled while hot. Then use Fan0 and Fan2 as the part cooling fans.
        Should look like this
        M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
        M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
        M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
        M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
        M950 F2 C"fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
        M106 P2 S1 H-1                                 ; set fan 2 value. Thermostatic control is turned off
        M563 P0 D0 H1 F0:2                             ; define tool 0
        Note the differences.
        • Ducati87undefined
          Ducati87
          Thank you for your support, it works!
          • Ducati87undefined
            Ducati87
            I reopen the topic because the system doesn't recognize any fans....
              But it was working before? What has changed?
              Ducati87undefined 1 Reply Last reply Reply Quote 0
              • Ducati87undefined
                Ducati87 @Phaedrux
                @Phaedrux said in Fans don't works:
                I replaced the board due a short circuit...I placed the hotend fan on FAN1 and the other two on FAN0 and FAN1 but on DWC I cannot see any fans to control.
                  Do the fans work when connected to the always on fan port?
                  Is the configuration the same as I posted above?
                  • Ducati87undefined
                    Ducati87 @Phaedrux
                    the fans works if I connect the fan to always fan ports.
                    The actually config is this:
                    M950 F0 C"Mat Fan1" Q500                           ; create fan 0 on pin fan0 and set its frequency
                    M950 F1 C"Hotend Fan" Q500                           ; create fan 1 on pin fan1 and set its frequency
                    M950 F2 C"Mat Fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
                    M106 P2 S0 H-1                                 ; set fan 2 value. Thermostatic control is turned off
                    • Ducati87undefined
                      Ducati87
                      seems to be solved. The problem was the nomenclature in C"Mat Fan1". The DWC doesn't recognize that, for which I typed C"fan0" and C"fan2" and miraculously the fans appeared on the DWC.
