    how to setup duet 3 extension 1LC driver ?
    Gcode meta commands
    995
    • Pseud3mysundefined
      Pseud3mys
      hi,
      I am using a toolboard extension for my extruder.
      But when I need to configure the driver I don't now what I need to do.
      I tried this:
      M569 P"121.drive0" S1
      but the entire extruder disappear from the web control interface, maybe because the config.json doesn't match ?
      Do you now how to do ? I don't find doc on this.
      • Vetiundefined
        Veti
        have you tried the duet configurator?
        it generates this
        M569 P1.0 S1 ; physical drive 1.0 goes forwards
        Pseud3mysundefined 1 Reply Last reply Reply Quote 0
          Pseud3mys @Veti
          @Veti Yes it was my initial config. Does 1.0 means the driver from toolboard ?
          • Vetiundefined
            Veti
            first extension driver 0
              Pseud3mys
              okay, this seems to do nothing. I don't hear song from the motor (and it don't rotate).
              • Vetiundefined
                Veti
                maybe the configurator is wrong.
                try 121.0
                  Pseud3mys
                  I will try. Did we need to change value in the config.json file ?
                  Vetiundefined 1 Reply Last reply Reply Quote 0
                  • Vetiundefined
                    Veti @Pseud3mys
                    @Pseud3mys
                    no the config.json is only for the online configurator if you want to import the config again.
                      Pseud3mys
                      ah okay thank you.
                      The motor do a song, but it a bad song and It don't rotate
                      • Vetiundefined
                        Veti
                        @chrishamm
                        That seems like a bug in the online configurator. The wrong canbus address is used.
                        motor not turning but making a noise is an indication of a wiring problem.
                        check that the phases are correct and the crimps are making contact.
                        Pseud3mysundefined chrishammundefined 2 Replies Last reply Reply Quote 0
                          Pseud3mys @Veti
                          @Veti
                          okay, I check the wiring and now the motor is spining.
                          But, when it stop spining it make a strage noise like electrical noise or like he is forcing, it is normal ?
                          • Vetiundefined
                            Veti
                            send M569 P121.0 in the console.
                            if it is in spreadcycle that is normal.
                            see this
                            https://duet3d.dozuki.com/Wiki/Reducing_Stand-Still_Noise
                              Pseud3mys
                              It return this. I now how to interprete it ?
                              M569 P122.0
                              Driver 122.0 runs forwards, active low enable, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 612
                              • Vetiundefined
                                Veti @Pseud3mys
                                @Pseud3mys said in how to setup duet 3 extension 1LC driver ?:
                                mode spreadCycle
                                see above comment
                                  Pseud3mys @Veti
                                  @Veti I don't now if it help but I use this motor :
                                  https://www.bondtech.se/wp-content/uploads/2019/02/13003-Nema17-25mm.pdf
                                  And I have an other question, did the E-step is the step per mm ?
                                  • Vetiundefined
                                    Veti @Pseud3mys
                                    no it does not help. you need to follow the guide and try it for yourself which parameter reduces the standstill noise.
                                    i am not sure what you are asking.
                                    Pseud3mysundefined 2 Replies Last reply Reply Quote 0
                                    • chrishammundefined
                                      chrishamm administrators @Veti
                                      @Veti Thanks, now fixed in configtool version 3.1.10.
                                      Duet software engineer
                                        Pseud3mys @Veti
                                        @Veti yes I change the mode It is okay now thank you.
                                          Pseud3mys @Veti
                                          @Veti I have always some issues..
                                          Some time the button here don't stop spinning, even after than the motor stop spining.
                                          • Vetiundefined
                                            Veti
                                            try a newer dwc
                                            https://github.com/Duet3D/DuetWebControl/releases
