    M569 R parameter ?
    • Pseud3mysundefined
      Pseud3mys
      I try to configure an external driver connected to duet3 with the 1XD extension.
      everything is working exept the R parameter.
      R0 = active low
      But when I put this:
      M569 P40.0 S0 R0 T2.6:2.6:0:5
      the en+ pin is at 5v (at High level) when I connect it. So the driver is disconnected. But without (so the en+ pin of the driver at low) everything work.
      Why the en+ isn't at 0v ? And how I can fix it ?
      thanks !
        Pseud3mys
        Maybe the duet 3 disconnect the driver by default ? But I didn't find any command to activate it.
          The ENA inputs of many external drivers disable the motor when the are energised, instead of enabling it as you might expect.
          Pseud3mysundefined 1 Reply Last reply Reply Quote 0
            Pseud3mys @dc42
            This post is deleted!
              Pseud3mys
              It work now (don't now why). The M18 (Disable all stepper motors) command is supported but not the M17. Why ?
                dc42 administrators @Pseud3mys
                @Pseud3mys said in M569 R parameter ?:
                Nobody has asked for M17 to be supported before. I have added it to the work list.
                RepRapFirmware enables drivers automatically when you try to move them.
