Manual Bed Leveling Assistant output meanings
  • undefined
    bdelia
    I am new to Duet and Reprap and trying to leverage the Manual Bed Leveling Assistant to help level my bed. When I get presented the output of the assistant it will be similar to the following:
    Manual corrections required: 0.00 turn up (0.00mm) 0.34 turn down (0.17mm) 0.31 turn down (0.16mm) 0.46 turn down (0.23mm)
    I am curious to verify when the assistant states I should "turn up" a knob does that mean get the bed closer to the nozzle or further away?
    Thanks
    undefined 1 Reply Last reply 9 Dec 2020, 20:41 Reply Quote 0
    • undefined
      Turn down would mean tighten I think, thus lower the bed. And vice versa.
      https://duet3d.dozuki.com/Wiki/Using_the_manual_bed_levelling_assistant
      • undefined
        jay_s_uk @bdelia
        @bdelia turn up is bed closer to the nozzle and turn down is move it further away
        • undefined
          bdelia
          Thanks! That helps and is what I was mostly thinking
          1 out of 4
