    Forward/redefine tools T0 & T1.
    • vapvapundefined
      vapvap
      My T0 tool defined to "Heated Bed",
      and T1 tool to "Extruder".
      Can they be reassigned without a "configurator"?
      (T0 - Extruder & T1 - Heated Bed)
      Unfortunately, I haven't found HOW to do this, and I'm afraid to ruin something.
      Here is my config file:
      ; generated by RepRapFirmware Configuration Tool on Mon Aug 06 2018 00:13:45 GMT+0100 (IST)
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
      M665 R105.6 L288 B105 H250 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
      M550 PMy printer ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
      M350 E8 I0 ; Configure E axis microstepping to x8 with interpolation OFF
      M92 X80 Y80 Z80 E2098 ; Set steps per mm
      M566 P1 X240 Y240 Z240 E6 ; Set maximum instantaneous speed changes (mm/min)(Jerk)
      M203 X12000 Y12000 Z12000 E2400 ; Set maximum speeds (mm/min)
      M201 X660 Y660 Z660 E120 ; Set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E400 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; Set minimum Z
      M574 X2 Y2 Z2 S1 ; Set active high endstops
      M558 P5 R0.4 H2 F1200 T6000 ; Set Z probe type to effector and the dive height + speeds
      G31 P100 X0 Y0 Z-0.1 ; Set Z probe trigger value, offset and trigger height
      M557 R90 S20 ; Define mesh grid
      M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
      M307 P0 A191.5 C1032.9 D5.1 ; CALIBRATION my
      M305 P1 X200 ; Set thermistor + ADC parameters for heater 1
      M106 P2 S0 I0 F35 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P1 D0 H1 F2 ; Define tool 0 + DEFAULT Fan0 ->forwarded to-> Fan2!!!
      G10 P1 X0 Y0 Z0 ; Set tool 0 axis offsets
      G10 P1 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C
      T1 ; Select first tool
      M501 ; new commands override the ones earlier in your config.g
        Phaedrux Moderator @vapvap
        @vapvap said in Forward/redefine tools T0 & T1.:
        All the P1 in there should be P0
        And that should be T0
        Heater0 should be the bed heater
        Heater1 should be your tool0 heater
        • vapvapundefined
          vapvap
          Thank you so much, now everything works as it should!
          Honestly, the help and support of key figures like you makes this forum one of the best in 3D printing!
          Please stay with us! )
