I need SD card files for duet 3 6HC
Where can I download the SD cards file for duet 3 6HC I’m goin to run in stand alone mode
https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Running_in_standalone_mode
See here for more details on standalone mode. There is a link in there that shows what must be on the SD card.
@Phaedrux I have formatted SD card to spec. I have downloaded SD card files and put in config from RRF config tool Included M552 S1 M575 P1 B57600
Still haven’t gotten anything to happen yet No panel due No Ethernet connection No comport via usb either.
@Ironman777 said in I need SD card files for duet 3 6HC:
try a different usb cable.
@Veti 3 different usb cables and it worked. Thank you. I was able to upload a config through web interface stepper motors are working. Upgraded to 3.1.1 no luck on PanelDue yet.
Is there anything on the PanelDue screen at all?
You may need to update the firmware.
https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
For RRF 3.1.1 I would use 1.24 on the PanelDue.
Send M503 through USB to check that it can read the SD card.
@Phaedrux Screen didnt do anything. i uploaded firmware update via usb. Upload system files button in Duet Web Control. Check it is in the Duet's '0:sys' folder. If necessary, rename the file to 'PanelDueFirmware.bin'. still no luck
@dc42 M503 VIA USB no results. Do you have to have PanelDue to resume print after power failure?
No, you just need to be able to send the command to resume the print.
https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure
You'll need to follow the actual instructions for updating the paneldue firmware using USB and Bossa.
This post is deleted!
@Phaedrux I can’t get resume after power failure to work. This is in my config M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E5 F1000" ; set voltage thresholds and actions to run on power loss.
I also created a resurrect-prologue file M116 ; Wait for temps
G28 ; Home all
M83 ; relative extrusion
G1 D2 3600 ; undo retractionIt creates a resume.g file when I run M916 it says error file not found
At one point in time this worked for my duet2 has any of the commands changed? I print for 100-200 hours at a time so this is very important.
Can you post the file that gets created when power is lost?
Post your resurrect.g and resurrect-prologue.g as well.
@Phaedrux This is what gets created after power failure ; resume.g
; called before a print from SD card is resumed
; generated by RepRapFirmware Configuration Tool v3.1.10 on Fri Dec 11 2020 20:02:22 GMT-0800 (Pacific Standard Time)
G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move
G1 R1 X0 Y0 ; go back to the last print move
M83 ; relative extruder moves
G1 D2 F3600 ; extrude 10mm of filament0:/sys/ressurect-prolague.g
G28 ; Home all
G1 D2 3600 ; undo retractionThis is in my config M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E5 F1000" ; set voltage thresholds and actions to run on power loss.
no ressurect.g file is created only resume.g
Does that typo exist in the actual file name?
Or that one?
@Phaedrux the actual file name is ressurect-prolague.g
and yes G1 D2 3600 ; undo retraction D2 is my extruder pin there is no E on Duet3
If that's the case then the spelling is wrong and that's why it can't find the file.
