Z calibration issues
I have 3 printers all running on Duets and all run ok except for my last build which is a Ratrig Vcore Pro. It's the only printer running on RRF3.2 beta 3.2.
On this printer I just cannot get a stable bed height. Every time i set Z, if i am lucky i can get the first print to work but there after Z is not at the correct height. The variation is only very small but small enough to disallow anything sticking to the bed. I can then adjust the height with baby stepping but even then, the Z height changes for the next print.
I have studied my config.g and other settings until i am blue in the face and cant find the answer why.Here's my config.g:
; Configuration file for Duet 3 (firmware version 3.1.1)
; Modified config for Ratrig Vcore with single extruder 23/08/2020; ###General preferences###
M42 P8 S255 ; Power up relay
M555 P0 ; Set Reprap-style output
G21 ; Set dimensions to millimetres
M83 ; ...but relative extruder moves;###Network###
M550 P"V-Core Pro" ; set printer name
M669 K1 ; select CoreXY mode; ###Drives###
M569 P0.0 S1 ; X physical drive 0.0 goes forwards
M569 P0.1 S1 ; Y physical drive 0.1 goes forwards
M569 P0.2 S0 ; Z0 physical drive 0.2 goes backwards
M569 P0.3 S0 ; Z1 physical drive 0.3 goes backwards
M569 P0.4 S0 ; Z2 physical drive 0.4 goes backwards
M569 P0.5 S0 ; E0 physical drive 0.5 goes backwards; ###Set drive mapping###
; For tripple Z make sure drive 2 is left hand Z and 3 is right hand, 4 at back
M584 X0.0 Y0.1 Z0.2:0.3:0.4 E0.5 ; Drive mapping for single extruder
;M92 X80.00 Y80.00 Z400.00 E136 ; set steps per mm (clone titan = 425)
;M92 X80.00 Y80.00 Z400.00 E424 ; set steps per mm for volcano 0.8
M92 X80.00 Y80.00 Z400.00 E466 ; set steps per mm for volcano 0.4
M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation; ###Accelerations, speed and jerk###
M98 P"print_settings/default_speed.g"
;M98 P"print_settings/E3_Fast.g"
;M98 P"print_settings/E3_T1.g"
;M98 P"print_settings/E3_T2.g"
;M98 P"print_settings/E_T3.g"M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
; V-Core steppers are 1.68 amp so 80% = 1.32amp
M84 S30 ; Set idle timeout; ###Leadscrew positions###
;M671 X-35:535:245 Y116:116:560 S6.0 ; The measurement is taken from X=0, Y=0. Therefore X will be negative, Y positive
M671 X-35:535:245 Y92:92:560 S6.0 ; The measurement is taken from X=0, Y=0. Therefore X will be negative, Y positive; ###Mesh Grid###
; The following M557 commands are not needed if you are using a bed.g file to perform bed compensation
;*** Adjust the XY coordinates in the following M557 commands to suit your build and the position of the Z probe
M557 X20:480 Y20:480 S100 ; Define small mesh grid - 25 points
;M557 X10:480 Y20:480 S50 ; Define large mesh grid - 50 points; ###Axis Limits###
;M208 X495 Y485 Z500 ; set axis maxima
M208 X492 Y495 Z500 ; set axis maxima
M208 X-6 Y0 Z0 S1 ; Set axis minima (adjust to make X=0 and Y=0 the edges of the bed); ###Endstops###
M574 X1 S1 P"!io0.in" ; configure active-low endstop for low end on X via pin io0.in with internal pull-up
M574 Y1 S1 P"!io1.in" ; configure active-low endstop for low end on Y via pin io1.in with internal pull-up; ###Z-Probe###
M558 P8 C"io2.in" H5 A2 F120 T3000 ; Z probe is type 8 in RRF3
; G31: the P is the reported Z value when triggered. X,Y are offset coordinates. Z is trigger height, you can decrease value if nozzle is too close
; or increase if too far away.
;G31 P500 X0 Y-25 Z1.80 ; set Z probe trigger value, offset and trigger height 2.07
G31 P50 X-22 Y0 Z2.32 ; set Z probe trigger value, offset and trigger height 2.07 ########changed P500 to P50; ###Push buttons###
; create e-stop microswitch
M950 J3 C"!io3.in" ; Input 3 uses io2 pin, inverted
M581 P3 S1 T0 R0 ; configure enstop as e-stop; filament unload button
;M950 J4 C"!io4.in" ; Input 4 uses io4 pin, inverted
;M581 P4 S1 T2 R0 ; configure button for filament unload; filament load button
;M950 J5 C"!io5.in" ; Input 5 uses io5 pin, inverted
;M581 P5 S1 T3 R0 ; configure push button for filament load; M581 P"!io6.in" T0 C0 ; configure active-low endstop to perform an e-stop (on panel)
; e-stop button
;M950 P6 C"!io6.in" ; Input 6 uses io6 pin, inverted
;M581 P6 S1 T0 R0 ; configure push button for e-stop; bed levelling button
M950 P7 C"io7.out" ; Input 7 uses io7 pin, inverted
;M581 P7 S1 T4 R0 ; configure push button for Bed Levelling; shutdown switch
M950 P8 C"io8.out" ; Creates output on io8 to use as alternative power off switch; Filament Run Out Sensor
;M591 D0 P1 C4 S1 ; Code requires conversion Filament runout Sensor for Extruder E0 P1 = signal HIGH.;Magnetic Filament Sensor
;M591 P3 C"e0_stop" S1 ; filament monitor connected to E0_stop; ###Bed thermistor/heater###
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; bed thermistor
M950 H0 C"out0" Q100 T0 ; bed heater H = heater no. C = output Q = PWM frequencyT = temperature sensor no. defined above.
M143 H0 S120 ; set temperature limit for bed heater 0 to 120C
M143 H0 P0 S105 A2 ; switch off bed heater temporarily if it exceeds 105°C
M143 H0 P1 S110 A0 ; raise a heater fault if it exceeds 110C; ###Extruder thermister/heater###
; H Heater number to monitor (default 1 which is normally the first hot end)
; S Maximum permitted temperature
; P Heater monitor number, default 0
; T Sensor number used to monitor the heater. It default to the sensor that controls the heater (as was specified in the M05o command when the heater was created).
; A Action to trigger (0: Generate heater fault [default] 1: Switch off permanently 2: Switch off temporarily)1
; C Condition for temperature event (0: Temperature too high [default] 1: Temperature too low, -1: Monitor is disabled)M308 S1 P"temp1" Y"thermistor" T100000 B4138 C7.06e-8 ; extruder thermistor
M950 H1 C"out1" T1 ; ext heater H = heater no. C = output T = temperature sensor no. defined above.
M143 H1 S280 ; set temperature limit for extruder heater 1 to 250C
M143 H1 P0 S290 A2 ; switch off extruder heater temporarily if it exceeds 250°C
M143 H1 P1 S285 A0 ; raise a heater fault if it exceeds 255C;###CPU Temperature Calibration###
M912 P0 S1; ###Fans###
M950 F0 C"out7" Q100 ; create fan 0 on pin out7 and set its frequency (parts fan)
M106 P0 S0 H-1 C"Part Cooling" ; set fan 0 value. Thermostatic control is turned off
M950 F1 C"out8" Q100 ; create fan 1 on pin out8 and set its frequency (ext fan)
M106 P1 S0 H1 T45:65 C"Extruder" ; set fan 1 value. Turns on at 45 degrees and full speed at 65 or over
M950 F4 C"out5" Q100 ; create fan 2 on pin out5 (bed cooling)
M106 P4 S0 H-1 C"Bed Cooling" ; set fan 2 value. Thermostatic control is off;###Hardware temperature control###
;CPU fan
M950 F2 C"out9" ; create fan 2 (CPU fan)
M308 S3 Y"mcutemp" A"MCU" ; set up a virtual sensor for cpu fan
M106 P2 T35 H3 ; set fan 2 value. Fan comes on when cpu temp is above 35 degrees (Cool the pi as well!)
M308 S4 P"drivers" Y"drivers" A"TMC" ; Create sensor for drivers;###Led Lighting###
M950 F3 C"out4" Q500 ; create a fan 3 output to use for led lighting control on pin out4
M106 P3 S0 ; set output default to off; ###Extruder setup###
M563 P0 S"Extruder0" D0 H1 F0 ; define tool 0
G10 P0 X0 Y0 ; set tool 0 axis offsets
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C;### FW Retract ###
M207 S0.5 F3000 Z0 ; max recommended retraction for V6 is 2mm (plus take in account length of bowden tube); ###Custom settings###
;M593 F50 ; anti-Ringing
;M572 D0 S0.800 ; Pressure advance = 0.8
T0 ; select first tool
M501 ; read parameters in config.overide
M98 P"/macros/Bed Levelling/lead_screw_level.g" ; perform bed levelling if ok'd on startup and then activate the mesh gridhoming files:
; homex.g
; called to home the X axis
; generated by RepRapFirmware Configuration Tool v2.1.1 on Mon Nov 04 2019 16:21:57 GMT+0000 (Greenwich Mean Time)
G91 ; relative positioning
M913 X70 Y70 Z80 ; reduce the motor current
G1 H1 X-600 F2800 ; move quickly to X axis endstop and stop there (first pass)
G1 H0 X5 F6000 ; go back a few mm
G1 H1 X-600 F360 ; move slowly to X axis endstop once more (second pass)
G1 H2 Z-5 F6000 ; lower Z again
G90 ; absolute positioning
M913 X100 Y100 Z100 ; reset motor currents
; homey.g
; called to home the Y axis
G1 H1 Y-600 F2800 ; move quickly to Y axis endstop and stop there (first pass)
G1 H0 Y5 F6000 ; go back a few mm
G1 H1 Y-600 F360 ; move slowly to Y axis endstop once more (second pass)
M913 X100 Y100 Z100 ; reset motor currents; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v2.1.1 on Mon Nov 04 2019 16:21:57 GMT+0000 (Greenwich Mean Time)G91 ; Relative positioning
G1 X245 Y247.5 F4000 ; Go to centre of bed; Probe
M558 A1 F350 ; Set single probing at faster feed rate F350
G30 ; Do a single probe to home our Z axis
M558 A10 F100 ; Set triple probing at slower feed rate
G30 ; Probe again to get a more accurate position and set Z to trigger heightM913 X100 Y100 Z100 ; reset motor currents
set Z macro:
; My macro to set Z probe heightM291 P"Bed compensation and height map will be deleted. Ok or Cancel?" R"WARNING" S3 T0; Click OK or Cancel.
M561 ; cancel any existing bed compensation
G29 S2 ; Clear bed height mapM291 P"Checking for homed axis!" S0 T2 ; Display on DWC
; If the printer hasn't been homed, home it
if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
G28M291 P"Heat the bed and extruder, home X and Y then find Z" R"WARNING" S0 T3
M208 S1 Z-5 ; Allow Z moves down to Z=-5mm.
T0 ; Activate extruder
M190 S60 ; Heat bed to 60 and wait
M109 S190 ; Heat nozzle to 190 and wait; Reset Z=0
G31 Z0
M564 S0 ; temporarily disable axis limits; Move Z down to find Z=0
M291 P"Jog the Z axis until the nozzle grips a peice of paper and click OK" R"Move Z" Z1 S2
M291 P"Click OK to set Z=0" R"Setting Z=0" S2
G92 Z0 ; Set Z to 0M291 P"Z is now set, starting multi-probing" R"Done Z" S0 T5
; Get trigger heights
M291 P"Trigger height will now be measured 10 times. Heights will be found in gcode console" R"ZProbe Trigger Height Calibration" S0 T5; G30 S-1 10 times
;; 1
G1 Z5
G30 S-1; 2
G1 Z5
G30 S-1; 3
G1 Z5
G30 S-1; 4
G1 Z5
G30 S-1; 5
G1 Z5
G30 S-1; 6
G1 Z5
G30 S-1; 7
G1 Z5
G30 S-1; 8
G1 Z5
G30 S-1; 9
G1 Z5
G30 S-1; 10
G1 Z5
G30 S-1M291 P"Probing finished. All heaters off, homing all axis. Check log for trigger heights and enter into config.g" S0 T5
; Turn off heaters
M104 S0 ; Set nozzle to 0 and release
M140 S0 ; Set bed to 0 and release
G28 ; Home ZStrange thing is here is a typical result from set Z macro:
BUT here are results from 10 separate G30 S-1 commands:
Can anyone help?
Thanks in advance.
After doing the 3 lead screw bed leveling are you re-probing the center of the bed to re-establish Z0?
What kind of probe is it?
@chas2706 said in Z calibration issues:
RRF3.2 beta 3.2
3.2 Beta 4 is now out, may want to update.
Sorry about the late reply.
Yes, after bed levelling I home the probe in the center of the bed.
It is DC42's ir probe.
Are there improvements regarding probing etc in RRF3.2 beta 4?
Cheers.
What do you have in that single_probe_check macro? How does it differ from the macro you did post?
No, but other bug fixes
The single probe check just contains:
G30 S-1 ;Probe the bed at the current XY position. When the probe is triggered, do not adjust the Z coordinate.
G1 Z5Looking through the documentation again I found I did not have a M574 Z1 S2 ; configure Z-probe endstop for low end on Z
in my config.g for endstops
Now if I do multiple single probe checks the results are consistent so I will re-calibrate Z and see if the problem has gone away.
In the meantime thanks for your help.
